Question about DCS RGS-364GD Kitchen Range
Dcs 485gd flame adjustment:
How do I adjust the intensity? I replaced the burner jet and now the flame is too high
3 Suggested Answers
  • 205 Answers
SOURCE: DCS 305 cootktop: one
Hello- What is probably happening is that the simmer orifice is clogged. If this gets clogged-up and not enough gas comes out to the burner it will continue to click. This is usually pretty easy to remedy. Take off the burner cap and you will see two holes, one in the center for the main burner and a smaller one that is on the perimeter of the burner. Look down that small hole and you should see a bronze orifice, it is pretty small, about 1/8" in diameter on the outside, looks like a nut. Most likely you will see grease or charred bits on the top of it (you can use one of the other burners for a reference if you are having trouble seeing it clearly) In the center of the orifice is a tiny hole, this is the part that is likely clogged. Now, you'll need to find something really skinny, like thin sewing needle and poke it into the orifice opening. Sometimes it is necessary to hold onto the needle with needle-nosed pliers in order to get it far enough in. Just be gentle with it and if what you are using seems too large in diameter then it probably is, you don't want to dent or cause any damage to the orifice opening. Once you get it cleaned out it should work ok. Let me know if you have any questions. Best regards.
Posted on Sep 29, 2010
  • 4736 Answers
SOURCE: Portable patio heater is a
The regulator covered with frost is the problem. It freezes the gas and the gas line up. But, usually this only occurs when it has been exposed to subfreezing (in the teens) temperature for a long period of time. The quick fix, is to soak a bath towel in hot water, ring it out and quickly wrap it around the regulator. Once it thaws, the gas will start flowing again and you can light the burner. Generally, once it's flowing and being used, it won't freeze up again, right a way. Most propane companies add ethanol to the propane in the winter, to help keep it from freezing in the lines and the regulator.
Hope this helped answer you question and provided, at least a quick fix solution.
Posted on Apr 21, 2011
8" yellow flame shooting out of ignition tube when running. No adjustments that I can see on the (Honeywell) gas cut off/pilot valve.
yellow flame is an indication of incorrect air mixture
as it is gas I would suggest that you seek the services of an accredited gas specialists to do any adjustments or repairs
Nov 06, 2015 | Heating & Cooling
Control knob doesnt adjust flame height?
Use a manometer to insure lp gas pressure is correct. The regulator for the stove may need adjusting. The air mixture adjustment may not be correct for PL as well.
Aug 18, 2014 | DCS Professional RDU305N 30" Pro-Style...
Gas flow burner
try adjusting the gas/ air ratio shield. that is the tin collar over the opening where the gas jet is . moving it back or forward varies the amount of air available for the mixture and alters the flame height. and colour.
May 27, 2013 | Weber Genesis Silver B Grill
Adjusting front (most powerful) burner on kitchenaid (Left front)
There is an air port near the adjustment knob. Open for a more blue flame and close for a yellow flame. If these haven't been moved before, you probably have a clogged jet at the burner. Just clean it out with a pin.
Feb 04, 2012 | KitchenAid Blenders
When this range was installed the installer removed the natural gas orifices and installed the supplied propane kit. Upon use we discovered that the lowest flame positions for all burners was still quite...
call in a gas fitter as the jets for the propane are probably incorrect.
the jets for lpg and nat gas are different in size and they may not have needed changing at all
Mar 11, 2017 | Frigidaire FGDS3065KF Stainless Steel Dual...
Can't get even flame on burners
Natural gas and Propane operate at different pressures known as WATER COLUMN INCHES and require different jets to work properly.
If you have changed the jets ( installed in the correct direction) and are using a new LP regulator You should be good to go. If you are using the old Nat Gas regulator it just ain't a goin a work
Feb 15, 2010 | Grilling
BO696 problems-burners too high on lowest position (propane used)
Remove knob, with flashlight look down top of shaft see a slotted screw that screw is flame adjustment.
To adjust, light burner, turn flame to low, with screwdriver turn screw rite till flame is at desired hight (aprox 2mm). now turn up to high check that high is satisfactory if high is to low then adjust screw. check low again. adjust till both setings are acceptible.
do for all burners
Feb 28, 2009 | Explorer Appliances BO696 Gas Kitchen...
do for all burners
As for holding the knobs that is common with this stove, you could check to see if flame is hitting sensor the burner hole that lines up the sensor may be dirty.
Flame way too high and yellow-Frigidaire Model #FGF328GM
call an approved frigidaire gas technician as it is possible that the jets in use are not for the propane gas
they are probably natural gas jets which have a larger jet size
the air shrouds around the jets have to also be adjusted to get the blue flame
you may be able to have it checked out under warranty as it is new
if you touch it your self , the warranty will be void
Mar 11, 2017 | Kitchen Ranges
DCS FREE STANDING RANGE
This should be fairly easy to do. You will have to get new jets that are sized for propane. These should be readily available. The jets on the stove top are located under each burner in the top of the pipe that delivers the gas. Remove the burner and you should be looking at a small hole in the center of a brass fitting, that's the jet. It unscrews and the new jet screws in. You may also have to adjust the simmer. This adjustment is located on each burner valve. When you pull of the knob, the adjustment will most likely be in a hole on the shaft where the knob came out or as was the case with my stove, it was behind and beside the shaft, just visible with a flashlight. This adjustment is done with the flame on in low medium. You may need to hold the shaft with pliers to keep the valve from opening. Turn the screw a half turn or so until the flame simmers to your liking and is not so thready tat it wants to go out.
For the oven, this will either be an adjustable jet, or you will need to replace it with one set up for propane. Either way its a doable project.
Mar 07, 2008 | Kitchen Ranges
DCS RGS-364GD Kitchen Range Logo
13 people viewed this question
Top DCS Kitchen Ranges Experts
John Tripp
John Tripp
paulcarew
Sal DeAngelo
Are you a DCS Kitchen Range Expert? Answer questions, earn points and help others
