Question about Panasonic KXDT346 Phone
Kx-dt346 change ringtone
No one can hear my voice when I make a call.
I would closely check out my "speaker" button. It may have been pressed just enough and gotten stuck, but you didn't notice it.
Feb 26, 2015 | Panasonic Kx-dt346 - 24 Button 6-line...
How to change the ringtone
http://service.us.panasonic.com/OPERMANPDF/KXTGA101.PDF
When you get to ringer settings press select, then using the arrow keys scroll to ringer tone, choose one of the tones or melodies then select save and then select off to get out of the menu you should have chosen a new ring tone.
Jun 05, 2014 | Panasonic KX-TGA101S Cordless Handset
How can we change the ringtone on Panasonic KX-T7730 phone?
You don't. Panasonic analog system phones have one ring tone. You can change the cadence (single double or triple) ring from outside calls, but not the tone.
Carl
Oct 26, 2011 | Panasonic KX-T7730 Corded Phone
How do I have moved office and have connected my phone (panasonic kx-dt346) but I do not have an extension number, how do I program on in for my phone line? as no one can call me, but I can call out?
You have one, press the INFO button up to 3 times and your extension number will show on the display. A 6-line display phone is pretty unusual to be moving from one place to another as it's the control phone. If it was the only one in your system, MOVE IT BACK.
There is a manager's guide in the Operating Manual for your system that will give the instructions for changing extension numbers. It starts by going into manager programming (PROG **1234) and choosing program 004. In Panasonic land, you don't "swap" extenson numbers, you do a double change as in change 102 to 200 105 to 102 and 200 to 102.
Carl
Jul 04, 2011 | Panasonic KXDT346 Phone
How do i cahgne the ring tone on the panasonic kx-t7565 phone. I have changed it but it only appears to have chagned if ring ring the number internally. we need the ring tone to change from external...
The ringtone for the CO or outside line buttons can be programmed by pressing program then press the
CO button twice, enter the ringtone you want by dialing 01 to 08, press enter or store then program to end. This will set the ringtone for that line assuming it is programmed to ring at that phone. Transferred calls will use the ringtone of the intercom button which can be set by the same procedure. Use the same procedure if calls ring to a Group Directory Number(GDN) on the phone. The 7600 series of digital phones have ringtone settings of 01 through 30.
Dec 15, 2010 | Panasonic KX-T7565 Corded Telephone
Panasonic model kx-tg1311nz how do i change
Is it possible to change the ring tone on my pnasonic digital KX-TG1311NZ cordless phone? I would appreciate if anyone can help me on this one.
Oct 14, 2009 | Panasonic KX-TG1033S Cordless Phone
Change the ring tone of Panasonic KX-T7730
I think it can be done. Just exchange the phone for a 7633 and change out the TA for a TDA-50.
Piece of cake.
Carl
Aug 25, 2008 | Panasonic KX-T7730 Corded Phone
Panasonic KXDT346   Phone Logo
Top Panasonic Lands Phones Experts
john milligan
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
