Question about Danco Faucet Stem
How to put together 9S-3H/C
There are several parts that go with the package. I dont know which one goes where.
09 dodge caravan BCM LOCATION dont know where its at everyone says under dash but i cant find it theres no fuse box there
The bcm is usually located on the backside of the under-the-dash fuse box. They are actually joined together mechanically and electrically with the plug-ins for the bcm on the backside of the package. You can separate them by removing several screws and sliding them apart.
Feb 12, 2015 | Dodge Cars & Trucks
HOW DO YOU ASSEMBLE AND INSTALL A DANCO 9S-4H/C
Turn off the water supplying the faucet. Now open the faucet. Remove handle by taking off index button and removing screw. You may need to purchase a handle puller, 10-15 dollars, and a stem wrench set. After removing handle, place appropiate sized wrench on stem and turn counter clockwise. Before installing stem, make sure it is in the open position. You may need to use the handle to turn the new stem. Screw in clockwise.
Jul 05, 2014 | Danco Faucet Stem
I bought a 3h-10h/c but it only works for hot. do you have the same product for the cold side?
The same part works for both Hot & Cold sides. Usually preset to work on Hot (counter clockwise on, clockwise off). To set for Cold, simple remove the plastic clip from the top, slide the ring tab off, flip it over and put back on (you can only put it on one way since there's a flat "key" in it matching the stem) Now its set for Cold (CCW of, CW on). HTH
Aug 05, 2010 | Danco Faucet Stem
Part fell out of gun dont know where it goes
is it the carrier support spring or the trigger spring?
go to www.winchester.com look for owners manual for model 94 come times the site dont work well.you may have to call them and ask for a schematic parts break down they will send it to you or e-mail it.
Oct 28, 2009 | Sport & Outdoor - Others
How does a 9s-4h/c danco stem install.
the spring goes in first then the rubber seat goes on top.put them together first on a small screwdriver,insert on hole push down on rubber into hole it should stay.replace stem in reverse order of takeing off.
Apr 08, 2009 | Danco Faucet Stem
Putting back together a poulan 1500le leaf blower
went to weedeater website and found a picture on how it goes back together
Oct 10, 2008 | Poulan Featherlite Gas Blower, with Low...
Danco Faucet Stem  Logo
65 people viewed this question
Top Danco Home Experts
Andrew Bugbee
richie46
Joe Olszewski
Level 1 Expert
Are you a Danco Home Expert? Answer questions, earn points and help others
