Question about Hotpoint HSS25GFP Side by Side Refrigerator
Evap fan stops turning
The first we knew of this problem is when you used the water/ ice maker the lights on display would blink, then there was a clicking noise coming from the mother board on back of refrigerator. we then noticed that the clicking noise coincided with the evap fan barely moving. we moved the fan with a butter knife and the fan would take off. the fan will run all day but when checked in the morning it will be barely running with clicking sound.
  • mark r Nov 05, 2007
    i replaced the mother board and it fixed the problem for a day, the next morning the problem is back!!
  • mark r Nov 08, 2007
    i got a lifetime warranty on the mother board , should i go ahead and get another one and replace it along with the fan motor?
  • 290 Answers
It sounds like the sensor circuit in the motor is out or the motor is binding slightly so that the motherboard can't tell what the fan rpm is. Replace the motor and you should be ok. This is a common failure I have run in to.
Post back if you have any questions.
Posted on Nov 07, 2007
  • Michael  Lindley
    Michael Lindley Nov 08, 2007
    The motherboard will usually be ok unless the motor shorts out completely, but if you can get another one at no charge I would say go for it.
How do I fix ghe lglsc 36905tt blinking light problem on ice maker.
if an LG easiest thing is try defrosting... also sounds like the water filter is due to be replaced.
Oct 02, 2014 | LG LSC26905TT Side by Side Refrigerator
Ice maker making clicking noises even though water and ice working
Hi orangebomber, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
Feb 03, 2014 | Samsung RFG297AARS (285 cu ft) Bottom...
Samsung fridge RS2555SW is not working. all temp lights are blinking. can you help
May be it needs reset. Unplug the unit for 12 hours and then reconnect to see if that makes any difference.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
Both refrigerator and freezer not cooling properly in refrigerator?
The ice maker not working: ---
Compressor not running on refrigerator?
Water dispenser not working on refrigerator?
Ice maker stopped making ice?
Water Overflows in Ice maker and freezes inside?
How to replace Ice maker assembly?
These will help.
Dec 22, 2012 | Samsung Refrigerators
How do you flush water thru the water filter of my refrigerator
ice maker does not come out water to water hose and ice maker on/off switch red light two times blinking how can i repair to ice maker?
Jan 21, 2012 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Ice maker is not making ice
Even though the water dispenser is OK you need to make sure the tray(s) in the ice maker are filling. The filter valve, located to the rear of the ice maker can freeze over and stop water flow. Check the supply line for the ice maker, it may be separate from the water dispenser.
Mar 24, 2010 | KitchenAid Superba Architect KSCS25INSS...
Ice maker not working andred light blinking
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 16, 2009 | Refrigerators
Optical sensor or valve problem
Your ice maker has an automatic shutoff. The ice maker sensor passes a beam from one freezer wall to the other, automatically stopping ice production when the storage bin is full. When you open the freezer door, you should see a red light on the top right freezer wall.When the freezer door is open or the ice storage bin is removed, the sensor cover or "flipper door" on the left wall of the freezer stops the ice maker from producing ice by blocking this sensor, When the beam is blocked, the red light on the right will blink twice. This is normal operation. as for the blink twice and pause I'm still checking on that. Make sure the water flow is coming from the solenoid valve located on back and bottom of refrigerator to the ice maker. Check the solenoid to see if the magnetic field is pulling the internal plunger open when ice maker ask for water. That can be checked with a multi meter at the wireing going to the solenoid and if the ice optics are telling the tray to fill voltage should be present. Insure that water supply is not restricted before it comes to the solenoid , like a bent line or clogged piercing valve.  Check that an ice cube is not jammed in the ejector arm of the ice maker. Remove jammed ice from the ejector arm using only a plastic utensil so the ice maker is not damaged. Call toll free in USA and a trained consultant will be happy to assist you. 1-866-698-2538
Oct 22, 2007 | Whirlpool GC5SHEXN Side by Side...
Clicking noise
Jul 07, 2007 | Whirlpool GS6SHEXMB / GS6SHEXMQ /...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
80 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
