Question about Motorola Mobility MBP36 Digital Video Baby Monitor - 2.4GHz Wireless Technology
Mbp36 ir lights not working
Ir lights not working
How do i check if the (ir system ) works on my ac unit that i have no remote for so i waste money on a new one??
IR Remote controls use invisible Infra Red light
I often use the camera on my iPhone (in Camera Mode) to see the invisible light.
A computer Camera should work too!
The camera see's the IR as a white light on most cameras
Check it out.
Or the Expensive
infrared viewer
SIMPLEST IR REMOTE TESTING CIRCUIT
Computer Camera
How to test IR remote controls
Make your Own
Remote Controller Tester An Amazingly Simple DIY
Feb 13, 2016 | Audio Players & Recorders
IR light doesn't work on security camera.
nitevision is in monochrome.. but if the irs dont work in that camera need to either get an ir light for that unit or replace that specific camera..the ir board is burnt out..or disconnected..I have several systems in use at different locations and I do installs for residential locations..I get some of my units off ebay..
Jan 20, 2014 | Zmodo Surveillance CM-S38901SV 540TVL High...
Ir sensor is not working
check to see if your remote is actually working, If you have a digital camera with an lcd display point the remote at the camera and push a button on the remote, if the remote IR light is working you should see it light up thru the camera when you press the buttons.
Dec 20, 2013 | Vizio M420SL 42 in. HDTV
What is the difference between a simple day/night IR cameras and day/night IR cameras with IR Light?
The IR lights light up your subject with light that they can't see but the camera can in order to get higher quality recordings
Oct 16, 2013 | i-rocks IR-3230 Webcam
Just purchased a new 3V CR123 battery for the prowler. The lights are working whenever i click ON or IR, however when looking through the lens nothing is visible. It's just all black. I removed the...
Jello, you meam that IR isn't emitting red light? If the IR isn't working then it has a bad IR luminator, broken wire, bad switch. Now the on/off switch get it power from battery to IR, it just one simple circuit. Also don't look at the IR light if it's on. Also don't point or look at bright lights with this NV devices, it will destroy the image intensifier tube. stewbison
May 30, 2011 | Bushnell Prowler 26-4050 Monocular
Dish IR Remote 20.0 has problems after sunset.
The problem for me was the TV giving off IR signals that interfered with DISH's poorly designed remote. When the TV's room ambient light sensor was turned on and it became dusk outside the DISH remote would stop working. Moving the receiver away from the TV helps but the problem is not eliminated until the light sensor is turned off.
Until DISH corrects this poor design there may be no other viable solution.
Jul 09, 2009 | DISH Network IR Remote Control
Samsung LN46A550 TV with a Xentech IR receiver 291 Series
Just got a new Samsung Flat screen today and am new technology challenged. Cannot sleep because the red light is still on on the tv set, read the instructions, and would this red light mean that it is in standby mode? Do I unplug the tv from the wall? I am getting very sleepy.
Jun 05, 2008 | Televison & Video
IR frequency determination
The remote could be using RF, which is why your Niles equipment cannot handle it. There is no way to duplicate the RF or convert it to an IR signal.
If the remote is using IR, make sure the batteries are full and the light is low when you are learning the codes with tne Niles equpment. There is no way if it's IR that the freq is > 100.
Apr 22, 2008 | Televison & Video
IR Receiver
Are you serious?
In case you are serious, IR=infrared.
When you point your TVs remote control toward the TV and press a button, it is the IR receiver on the TV which receives the IR signal which is transmitted from the IR LED (Light Emitting Diode), which is the small bulb like part, on the front end of your remote control.
Any device using a IR remote control, must have an IR receiver to gather the siganl being transmitted. The IR siganl is a coded message of instructions for the device.
Dec 08, 2007 | Jazz DV-179 Digital Camera
IR Reliability--Intermittent
The Kenwood VR-510 does indeed respond to IR remotes. I now use a Logitech Harmony H659 which is IR only.
Your issue is a problem with the VR-510, actualy the whole series had a problem with cold solder joints on an assembly behind the front panel. Fix that and fix the problem. It frustrated me for 5 yrs.
Go here for the fix:
This site has the fix well documented: http://resnet.uoregon.edu/~gurney_j/kenwoodrepair/.
All is working great now!
Jun 08, 2007 | Kenwood VR-510 Receiver
Motorola Mobility MBP36 Digital Video Baby Monitor - 2.4GHz Wireless Technology Logo
62 people viewed this question
Top Motorola Mobility Baby Gear Experts
Motorola Mobility
Motorola Mobility
John Gardner III
John Gardner III
Level 1 Expert
Are you a Motorola Mobility Baby Gear Expert? Answer questions, earn points and help others
