Question about Home
Can you buy parts
Stem
How to change tyre valve stem core
Sometimes you can start turning them out (they unscrew) with a tiny flat blade screwdriver. Or you can go to a parts store and buy a small package of tire valve caps that have the two small prongs for removing valve cores. Walmart probably has them, too.
Jul 06, 2012 | Cars & Trucks
I have an American Valve M72AS Frost Proof Sillcock that is leaking around the stem when turned on. I replaced the packing under the handle with no fix. Is there another packing/seal deeper inside? How...
AMERICAN VALVE 1/2-in Dual Pattern Brass Sillcock Valve M72AS...
Do NOT purchase this product... Mine lasted about four years for me before the internal stem/rod cracked. This caused a constant leak when it was turned on. Doing research for parts... I've noticed a lot of reviews on the internet about this same problem as to it leaking through the handle. I thought it was a gasket problem but after analyzing it, it turned out to be the "Integral Vacuum Breaker" system malfunctioning after a few years of use. The tip of the stem is a moveable item loaded on a spring and if it gets stuck closed, the water in the stem/rod does not drain out causing water to stay in the center stem/rod and of course freezing during the winter. When Spring comes and you turn on the system, that's when it leaks in and around the handle.
Another important note: I could NOT find replacement parts i.e. center stem/rod therefore causing me to buy another new Freeze-Proof Sillcock. It doesn't stop here yet....The newer ones are mostly made of aluminum and the center stem/rod is all aluminum...NOT copper!!! This part being all aluminum which I believe will be a major problem to come!!! As you know aluminum creates lots of oxidation with layers of white aluminum powder. This will now be going through your hoses that might feed your garden/food, your pets water bowls outside and your pools!! This is not good. They need to keep this stuff copper or CPVC but NOT ALUMINUM.Look up "Aluminum poisoning"
I have pictures of this (center stem/rod) and how I fixed the old copper center stem/rod for a back up when my aluminum one I just bought from Lowes fails in a few years. I tested it and it works (my old copper stem/rod)!!! I fixed mine by removing the spring in the tip and putting the tip back in the stem and filling the center of the stem/rod with Liquid Nails adhesive. If I was to do it again, I would use a Rubber Silicon via a tube gun.
My suggestion is to go to the old type of Frost-Free Sillcock "BRASS" NOT ALUMINIUM and doesn't have a hollow center stem/rod for water to freeze in and also doesn't have the anti-Siphon design. It might be a neat design but when the parts start to oxidize/rust etc. it then will stick and keep the water from being aloud to leave the stem/rod therefore causing a crack and WILL leak when opened during the Spring.
Jun 10, 2011 | Home
The compressor continues to run but no air enters the tire, the tire just seems to get more and more flat.
Hi, I suspect the plunger for the valve stem connector on the pressure head is not depressing the air release pin in the head of the valve stem.
I have a Black and Decker and have to use a valve stem seat removal tool to quicky unscrew about 3 to 4 turns the stem seal and then connect the air hose head. After the tire reaches the correct air pressure I have go thru the tighten the valve stem seat drill.
You can buy the vavle stem seat tool at any auto parts store. I keep mine with the compressor.
I don't want this to sound bad but... is the air hose supply vavle turned on? Some have a slider button on the valve you have to push to charge the hose. If the hose is charged then see above.
Thanks for using FixYa.
Kelly
Feb 10, 2010 | Campbell Hausfeld 02-Gallon Air...
Can't find parts
There are many manufacturers that do not have parts available and you will have to purchase another valve. What you can try is going to the nearest Lowe's. Lowe's has a plumbing parts section where another company manufactures parts for several makes and models. Turn your water off and take the stem with you so that they can see what they are trying to match. GOOD LUCK
Aug 06, 2009 | Globe Union Lavatory Faucet
Broken part on coffer maker
Replace it with the same sized tubing that you can buy at the Hardware store. just get the length you need they sell it by the foot. DFD
Apr 20, 2009 | Gevalia CM-500 12 Cup Coffee Maker
Jeep LIberty 2006 valve stem broke off
Just go to a tire store. They can resolve your problem quickly. A valve stem is a common item.
Dec 08, 2008 | 2006 Jeep Liberty
I need a part!
Try this page, and feel free to have it shipped in. Also, the exploded parts view will help you find your part number.
http://www.mtmc.co.uk/prodtype.asp?cookiecheck=yes&PT_ID=12706282
Feb 29, 2008 | Black & Decker FP1000 PowerPro Food...
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
