Question about Car Audio & Video
Error 2 on usb reading - Car Audio & Video
  • 3 Answers
I have also been experiencing the very frustrating "Error Code 2" issue half way thru the calibration process. Sometimes the error occurs during measurement No. 1; other times on the 2nd or 3rd measurement.
I am running a MacBookPro running OSX 10.7 (Lion Server) w/ Vmware Fusion v4.1.1 and Windows XP (SP2).
After experiencing over a dozen of failed attempts to calibrate, I started to tweak the Windows setup.
I found out after some experimentation that the issue is not so much the Alpine Imprint S/W, but much so with the USB/Serial interface hardware. The S/W has issues with error recovery, which forces the user to close and restart the application if an exception is encountered...but if the exception can be avoided in the first hand, it runs fine!
Would suggest to try the following tweaks to address the Error Code 2 issue:
(1) If using Vmware Fusion, ensure that the USB/Serial is connected. On the VMWare Fusion menu, select Virtual Machine->USB & Bluetooth->Connect Future Devices USB<->Serial. Ensure this is connected first before launching the Alpine Imprint Sound Manger (v2.10) application;
(2) The USB cable that comes with the calibration kit is quite long and I am not sure the shielding is that good. So try to straighten the cable out and not allow it to coil when connecting to laptop; this should reduce any potential interference and signal degenerating issues;
(3) Within XP, open up Control Panel->Administrative Tools->Computer Management->Device Manager, locate under "Ports" the corresponding port that the USB<->Serial interface emulates. Usually this is USB Serial Port (COM3).
Open up the Port Settings under its properties menu.Apply the following override settings:
Bits per second = 921,600 (or 115,200 is fine as well)Parity=EvenFlow Control=Hardware
Click "Advanced" button and override the following settings:Minimum Read Timeout (msec) = 10,000Minimum Write Timeou (msec) = 10,000
These simple override setting works like magic for me.I was able to complete all the 6 measures without a glitch.Hope this works for your setup as well.
PS. For subwoofer calibration I also found useful tuning down the gain beforehand on the amplifier. On the Alpine head unit, set the Subwoofer output level to very low (close to zero). On the amp-side (I am using 3 x Pioneer PRS-D4200F) set the gain switch anti-clockwise to a voltage slightly above 2V (do not over do this). Then after the calibration has completed, set it to just below 2V (clockwise rotation) to slightly elevate the output. The remaining subwoofer gain adjustment can now be done comfortably from the head unit's subwoofer output control.
Cheers,Damo
Posted on Dec 04, 2011
  • 365 Answers
Insufficient ground
Posted on Jun 14, 2009
I can't add files to my USB stick, it gives me read only error. I'v done running Using Registry Editor and diskpart,still the error is present. What will I do?
it is write protected which means that you cannot add anything to the usb stick
you will have to get the administrators permission to change to edit the usb stick
if you are the originator of the original entry , then go to the permissions section and change to read and write
Jun 30, 2017 | The Computers & Internet
Mazda 2 check cd
Rip it out and dump it ,fit a new one that reads a SD card and USB and dont bother with a cd player
Jul 25, 2013 | Cars & Trucks
ON MY SLICK MP3 PLAYER ,WHEN PLUGGING IT INTO A DESKTOP , WHEN TRYING TO DELETE A CERTAIN FOLDER , A POP UP STATES .. ERROR DELETING FILE OR FOLDER , A BIG X THEN SAYS CANNOT DELETE FILE CANNOT READ FROM...
This sounds like you've got one of three things happening:
1 - Your USB cable is dying slowly. Over time connections become seperated within the cable. This causes data loss and all sorts of funny errors. Try a different cable and see if that helps.
2 - Your USB plug is malfunctioning or underpowered. If you are attempting to use a USB 2.0 device on a 1.1 connection, errors may prevent you from doing what you want to do. Try a different USB port, see if that helps.
3 - Your MP3 player has a setting somewhere locking files to the device itself. If windows tries to delete a locked file, you will receive an error. Browse through the manual of your device or the settings on the device itself and see if there's a lock or protection or USB mode somewhere.
Because you're getting the "cannot read from source or disk" error, I am strongly geared towards #1. Get yourself a new cable and see if that doesn't solve the problem.
May 04, 2011 | Audio Players & Recorders
I bought an USB Celcom Broadband (HSUPA USB Stick (Model: ZTE MF190) a few days ago. I installed to my Ftec laptop (OS : Windows XP Pro SP3), but can't use. There are messages appears : (1) Exception...
hi sir,
i got a problem regarding the celcom broadband. the problem was happen since yesterday. i left my notebook for along time (may be about 20 hours) where i am not to turn off the celcom broadband. when i come back and see to my laptop, it's already shutdown. when i turn on the laptop.. the error problem pop up at my laptop screen. the error shows :
access violation 004A1170 in module UImain.exe. Read of address 0000051c'
please help me to solve the problem. i cannot access the broadband as previously. Thanks :(
Oct 08, 2010 | Microsoft Windows XP Professional With...
Kingston USB DTI/1GB Malfunction error
your USB Flash Disk is damage already, you need to be repaired your Flash Disk to read again in your PC.
Jul 22, 2009 | Computers & Internet
Error on screen
deanno
Check the product with a different make of flash drve. Yours may be drawing too much current.
deanno & Guest
Check that none of the four connector pins in the USB socket are bent or touching another pin or the surround.
Dec 28, 2007 | Philips HTS3450 System
USB Power Surge Error
normally usb ports are plug/play it could be tht there is something wrong with your usb cable if i knew your mailing address i could send you a usb cable i have tons..
Sep 26, 2007 | Vivitar ViviCam 5385 Digital Camera
IRiver E10 - Error screen - Emergency USB
Hi There,
There are 2 conditions related to the e10 Emergency USB message.
1. If your PC does NOT recognise the iriver as a USB device/drive, there is an issue with the Hard Drive.
2. If your PC DOES recognise the iriver as a USB device/drive and can read the files, there is an issue with the Circuitry in your e10.
In either case, your iriver needs to be returned to the manufacturer. If in warranty you can get this repaired at no cost (of course).
Sep 06, 2007 | iRiver E10 Digital Media Player
Car Audio & Video Logo
127 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
