Question about Magellan RM5295T-LMB 5" Smart GPS, Cloud Connected, WiFi
Roadmate 5295 locks up
CD spins but no sound on GE space save 7-5295
It happened to me too, I was listening fine some cds but then when I turned on later it does the same thing you wrote, how you solve the problem? Pls write
Jun 10, 2012 | GE 7-5295 Undercounter DC /Radio Combo -...
GE Spacemaker, Model 7-5295 the cd light blinks and the cd spins but it does not play. After a short period of time nd flashes.
ND means "No Disc". It's probably a newer CD - one that's been copied, perhaps? It's got a format newer than what the CD player on that unit will recognize. Try an older CD.
Oct 02, 2009 | GE Slim Spacemaker 7-5295 CD Shelf System
My Magellan Roadmate 700 is locked.
it can be bcoz the satellite is not working a the moment. or the computer navigation is broken.
so check both things
Jul 22, 2009 | Magellan RoadMate 700 GPS Receiver
Cd player keeps showing nd cannot play any type of Cd at all
Hi Tony,
Your GE 7-5295 keeps showing nd (no disc), this simply means that your lens has been damaged. Please replace the lens and you would enjoy listening to music once again in your kitchen.
Kind Regards
May 30, 2009 | GE 7-5295 Undercounter DC /Radio Combo -...
I'm trying to find a User Manual for a GE Spacemaker 7 5295
Right after I posted my request, I managed to find a suitable Users Manual on the web. Thanks for your help.
Apr 14, 2009 | GE Slim Spacemaker 7-5295 CD Shelf System
GE Slim Space Saver CD and Radio #7-5295
1. Press the SET button 2. Use the TRK (SEARCH+TUNE) buttons to move the time forward or backward. 3. Press SET again. Note: While you are in clock-setting mode, there's a red clock icon that will show up on the LCD display.
Nov 05, 2008 | GE Slim Spacemaker 7-5295 CD Shelf System
Magellan roadmate 800 unlock code
turn off your unit with the slide switch on the top. Hold down the repeat button or the one beside the slide switch and then put the slide switch back to the on position. Then select hdd tools then format. exit out and turn the switch off and back on and it should work
Apr 02, 2008 | Magellan RoadMate 800 GPS Receiver
Roadmate 700/760 freezing/locking up
i use to own a 700, i advise you to get the new magellan mastreo 4000 or higher,i did my research and the magellan700 roadmate is no longer being serviced.that is what the magellan website has had showed and someone on here also has said it and they start to have alot of problems.i own now a mastreo 4000 so far so good no problems.
Feb 29, 2008 | Magellan RoadMate 700 GPS Receiver
GE 7-5295 CD error
i have the same problem exept that also the eject button is not working or the stop buttton.
Sep 25, 2006 | GE Slim Spacemaker 7-5295 CD Shelf System
Magellan RM5295T-LMB 5" Smart GPS, Cloud Connected, WiFi Logo
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
