Question about Canon MG3170 INKJET COLOR ALL-IN-ONE PRINTER, COPIER AND SCANNER WIRELESS N
Mg3170 reset
Why when wireless printing using same hardware worked fine, now not responding.
Unless it is the EXACT same wireless router from your service provider it could be the router. I mean that if you have moved and your provider gave you another router (same make and model) then it could be the wireless router. I struggled with this myself and after having the provider change the router, the problem disappeared immediately with the printer connection. The problem was only with the printer (HP in this case) as other wireless devices worked okay. Strange but true.
Sep 09, 2014 | Canon MG3170 INKJET COLOR ALL-IN-ONE...
Why is it that wireless printing using same hardware and service provider will no longer work at new address and SP account?
When you say :"identical" do you mean the same unit, or another unit of the same model? I experienced the same issue after moving, with a new "identical" model modem/router provided by the ISP. Until the provider replaced the router with another "identical" one I couldn't get the wireless printer (HP in my case) to connect no matter what I did either using the WPS function or entering my network settings manually. Other wireless devices worked okay.
Setting up wirless printer
What is the brand/model of the printer you want to set up? Please clarify. I have Canon MG3170 wifi printer and it need USB cable to connect with PC to set up the wireless thru its software (IJ Network Tool).
Please clarify your printer and I will try to help if I can. Good day!!
Mar 12, 2013 | Office Equipment & Supplies
Cant set up cannon mg3170 wirelessly
Hi Rachel,
I know this isn't exactly help, but I thought I should say something.
I had a similar canon printer which connected to my wireless network and then after a few days decided that it had had enough of wireless printing. I did everything including a reinstall. I then took it back and got a new one. This strangely did exactly the same thing, so I took it back and got a refund and am now happily wirelesly printing on an Epson printer.
Sorry this isn't a solution,
Darren
Aug 13, 2012 | Canon Office Equipment & Supplies
Canon MX330 Error 5800 or 5B00, what is it?
Error 5B00 refers to the ink absorbers being full. This is not a job for a home user and you would be best taking the machine to a repairer for new absorbers to be fitted. If you dont then ink will start to flow out of the printer onto the table!!
Jul 15, 2011 | Canon PIXMA MX330 Multifunction InkJet...
Canon MG3170 INKJET COLOR ALL-IN-ONE PRINTER, COPIER AND SCANNER WIRELESS N Logo
54 people viewed this question
old marine
old marine
