Question about HP LaserJet Pro 300 color MFP M375nw
LaserJet Pro 300 MFP M375nw Printer always goes offline
Can someone please tell me why is my printer seems to go offline every few minutes. It is connected through network.
SOURCE: Printer status offline
I just ran into the same problem. The computers on the network that were running XP were showing the printer as "Ready", but all of the computers running Vista were showing the printer as "Offline".
After trying a number of solutions that I found on other message boards, I accidentally discovered that the problem was an IP address conflict. It seems that the server changed the address on the printer, which didn't bother the XP machines but brought the Vista machines to their knees.
Press and hold the blue button (HP called it the "Go" button) for 5 seconds, which will print a configuration report. In the TCP/IP section you will see the IP address for the printer. Next, open the Printers window, right-click on the P2015 and click Properties. Click the Ports tab. Find the port that is checked and click the "Configure Port..." button. If the "Printer Name or IP Address" field differs from the IP address on the configuration report, change it to the one on the report. It took a few seconds after hitting OK for the computer and prrinter to link up again, but that solved the problem for me.
Posted on Dec 03, 2008
  • 102 Answers
SOURCE: how to intalling network sanner HP LaserJet M1522nf MFP
If your printer is connected in the Network and you are able to print fine than there is no communication Error.
In htan case if you are not able to scan then you need to upgrade the firmware of the printer and install it and i m sure your printer wiill scan scanning on the Network.
Mentioned below is the link to download the latest firmware of the printer.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=3442750&prodNameId=3442754&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=ma-70811-2
However before you start sending firmware to the printer you need to make sure that printer driver is installed on the PC.
Thanks and Regards
Neeraj Sharma
Posted on Jul 01, 2009
YourZEN
  • 820 Answers
SOURCE: how do I install a hp laserjet cm 1312nfi MFP
There's Windows 7 support for the CM1312 series, see next site:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=uk&prodNameId=3562006&taskId=135&prodTypeId=18972&prodSeriesId=3558902&lang=en&cc=uk
Pay attention to downloading and installing the matching bit-version (32 or 64) for your system.
Posted on Nov 03, 2009
brett207
  • 231 Answers
SOURCE: the printer (hp laserjet p2015) appears offline
Press and hol the green 'go' button until the lights flash, (about 4-5 seconds) and release the button,
Wait for the config pages to print out, and then check your network configuration, i.p address, Subnet mask and gateway.
If no network page prints out, you might have a dead Network Interface in the printer.
Posted on May 11, 2010
  • 1382 Answers
SOURCE: How can resolved Scanner error 12 in Hp Laserjet
Try to uninstall the software of your scanner and reinstall it again. Also
check your cables for loose contacts.
Thank you!
Posted on May 18, 2010
Problem hp pro 300 don't copy black
Check your black cartidge even if it's new. Take it to a refill site,
they may unstuck it using utrasound
Oct 24, 2015 | HP LaserJet Pro 300 Color MFP M375NW...
Printer ink doesn't appear to be dry on colour printing.
Dripping is impossible with laser as the toner is dry. A bad cartridge may cause the color shift. Print the demo page to confirm whether the problem is the printer or your program. Remanufactured cartridges provide very poor results with this model of HP.
Jun 24, 2015 | HP LaserJet Pro 300 color MFP M375nw
Copies are real light but prints fine if sent from my pc
Hi, you have to correct your settings, on the ectiol printer it self, just go THRUE the manual if you saying it far lie new..
If you get stuck, as quik way out, set all settings in your printer to "Defoult Setings" it will fix your problem..!
Hope it helps. Good luck
Tony. :))
Dec 05, 2014 | HP Hewlett-Packard - LaserJet Pro 300...
Need to clean the ITB (Transfer Belt)
The wipes contain chemicals some of which will have remained on the belt. Whether they will ultimately dry off is a wait-and-see.
It may help to try copying and printing a couple of dense A4 photos, then check a normal page of script after.
Otherwise it's a new belt I guess!
Feb 26, 2014 | HP LaserJet Pro 300 Color MFP M375NW...
Printer says remove packing stuff on inc
Check again. There may still be some piece of tape fastening a moving part. Follow the instructions in the owner/user manual.
Dec 18, 2013 | HP LaserJet Pro 300 color MFP M375nw
HP LaserJet Pro 400 MFP showing offline when printing
My computer says that the printer is offline and my printer will not print idk what to do... suggestions????
Oct 10, 2012 | HP Laserjet Pro 400 Mfp M425dn...
HP LaserJet Pro 300 M375nw keeps saying paper jam in drawer 2 but there is no paper anywhere.
My problem was the rollers at the top of the printer where the paper feeds out of the unit. I had printed some labels and some sticky material from the labels stuck to the rollers and metal fuser unit. I cleaned off the sticky strips from the rollers and fuser roller and the unit works fine now. You may have to let the printer cycle several times so it turns the rollers so you are sure to remove all the sticky stuff or paper. I also used a can of the compressed gas to spray out all the dust, paper and sticky stuff after I scrapped off with envelope opener.
Jul 24, 2012 | HP LaserJet Pro 300 M375nw All-in-One...
HP LaserJet Pro 300 color MFP M375nw Logo
381 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
