Question about HEWLETT-PACKARD Pavilion a6700f (FQ565AA#ABA) PC Desktop
Code purple error code
    Master:
  • 269 Answers
This is from a user called DOGSNAKE
Did some research for this and here is a suggestion that has worked for others:
Code Purple is a problem exclusive to HP's, the easiest solution is to avoid them. However, it's already too late for you. Basically it's an attempt to force you to pay them to service or upgrade your PC, or if you didn't learn the first time, buy another.
***PLAIN ENGLISH QUICK AND EASY FIX FOR ALL SYSTEMS****
***Windows 7 code purple or Windows Vista code purple***
With the code purple error on the screen, press shift+f10 (the shift key and the F10 key (at the top of the keyboard) at the same time) to open a little screen called a command prompt. (So, you get a little black screen with white text that says something about your Windows verison first and a little ways down you'll see "C:\>". It's all ready for you to start typing.)
Type the following line, just as you see it here: notepad C:\hp\bin\checkdmi\checkdmi.cmd
It will look like this: C:\>notepad C:\hp\bin\checkdmi\checkdmi.cmd
Press Enter.
You will see the text for the file listed in a window using a simple text editor.
Go to the beginning of the text. Press enter to make a space.
Type this: goto cleanup
So, whatever comes after, the first line looks like this: goto cleanup
Save the file and exit notepad and restart your PC. You are good to go.
You are creating a small batch file that will clear the error code. Seems there is no true system error (windows) but it is generated to drive you to some sort of paid HP support or hardware replacement.
Posted on Aug 04, 2015
Code purple when turning on computer
Code Purple is a problem exclusive to HP's, the easiest solution is to avoid them. However, it's already too late for you as it was for me. Basically it's an attempt to force you to pay them to service or upgrade your PC, or if you didn't learn the first time, buy another. Here is the most concise answer I found, tried to translate into plain english.
Type the following line, just as you see it here...
so it will look like this C:\>notepad C:\hp\bin\checkdmi\checkdmi.cmd - Note the space between notepad and C:\
Press Enter.
Go to the beginning of the text. Press enter to make a space. Type this...
goto cleanup
So, whatever comes after, the first line looks like this...
goto cleanup
NOTE: From my experience. If you received the Code Purple error during the restore process; after saving and exiting notepad, press and hold the power button until the PC shuts down, wait 15 seconds then restart. If you get a message during start up select "start windows normally". If you don't shut down using the power button and wait for the "windows was unable to finish........", you will likely get the same error again when the system boots. I don't know how to get back to the Code Purple error without doing the restore process again.
Feb 10, 2013 | HP Computers & Internet
How to fix code purple error
"code purple"? In what kind of computer?
Dec 24, 2012 | HP Hewlett Packard Pavilion A6200N PC...
The code purple shows up on my computer hp desktop
The following error message opens after the PC is started after a recovery: Your system has detected a configuration error. Please call your Customer Care Center number, located in your Warranty and License information, for technical support. (Code Purple) contact hp tech support...meder's tv service Figure 1: Code Purple error c00372799.jpg
Aug 29, 2012 | HP Computers & Internet
The code purple on my computer
Code purple is because an O.S other than a genuine HP has been installed and as it is HP it would have to be HP as it is designed especially to run HP computers only, For example if you try to install an O.S from a Compaq even though Hp and Compaq have merged it is written for Compaq computers not HP and vice/versa. Re-Install your original HP O.S and this should sort out the code purple error. I hope this helps.
The computer is saying purple error code
code purple error is related to the problem in the mother board so it needs to be replaced there is no other way. if someone agrees to repair it then i suggest not to go for it because there is no gurantee for the long lasting. get *********** board replaced.
May 15, 2010 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
Code purple error after system recovery on windows xp how can i fix im a green hand but follow clear instructions very good
There is no way to fix a Code Purple error on an HP computer.
Basically what has happened is that there is a Hard Coded Information "Tattoo" on the motherboard that tells the computer what hardware should be on this machine.  The Hard Code and the hardware do not match.  It is kind of a known fault by HP.
But there is some good news.  No matter long your computer has been out of warranty, this problem IS covered.  The wrong hardware was put into your machine and no matter when this error occurs, HP will support it.
Call HP's tech support and when you speak to a Technical Agent, you let them know you got the Code Purple Error, and they should immediately escalate your call to their Hardware Specialists and set up a service repair where they send you a box and paid shipping label to ship your computer to one of their repair facilities where they will fix it and send it back to you at no cost.  Call 1-800-HP-INVENT.
I used to work for HP tech support and we would see a Code Purple case about once every few months, even on computers 3+ years old.
Mar 26, 2010 | HP PC Desktop
Configuration error on windows xp code purple
if its a code purple error on ur hp computer and its a blue screen error message then the issue is with the motherboard of your computer...and in this case nothing can be done.If your computer is only 4 to 5 years old or less than that call to HP they will replace your free of cost,HP's phone number is 18004746836
Nov 28, 2009 | HP Pavilion m7560n PC Desktop
Code purple
code purple is a hp and compaq term meaning the machine has detected an error in hardware(adding card etc) the mb's are tatooed and usually the machine is sent back to be re tatooed.sometimes installing the microsorft version of the software, after a format (no restore disk) will stop this from happening.
Jul 21, 2009 | HP Computers & Internet
HEWLETT-PACKARD Pavilion a6700f (FQ565AA#ABA) PC Desktop Logo
71 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
john smith
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
