Question about Korg TR76 76 Key Synthesizer Workstation
Water spilt on Korg TR rack module
I stupidly spilt some water on my TR Rack, and it's got inside the case, not loads but enough to fizz, smell of burning and go off. Have left to dry out but now not working at all - is there anywhere i can send my beloved rack to be repaired or should i bite the bullet and buy another? HELP! Got a gig looming!
Thanks,
John
Not play korg TR keyboard,,,
Posted on Mar 28, 2010
Need a sound/presets for the Korg Tr rack
http://www.korg.com/SupportResults.aspx?productid=191
Feb 07, 2012 | Korg Music
TOP RACK OF KITCHENAID DISHWASHER NOT WASHING
check to make sure that there is enough water in the dishwasher. if not then take a container and pour some water inside, place a cup right side up in the top rack. close door and and set the machine to wash. wait about 30 seconds, then open the door, if the cup is half full or better, then your pump is good. and your problem is with your water inlet valve. the mesh probably needs cleaning, better yet just replace it.
Feb 03, 2011 | Dishwashers
Top rack of dish washer does not have enough water
Trouble shooting here... but the same pumb that circulates water... vents it.... So, if the vent valve is clogged with food debris, then you would not retain enough water to wash all the upper rack dishes...
I recommend inspecting the exhaust tube port of the pump (a selenoid is the operating device for that valve). Be sure that it is able to operate freely (close all the way. Otherwise, it is just the pump intake!! only choices...you have already eliminated the rest (GOOD JOB)
Dec 31, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Does not remove all food some residue remains after wash cycle
check and make sure that you are getting water too the top rack place a cup or mug upright in the top rack turn the dishywasher on for about 2 minutes you should a least have filled the cup up half way if not to the top. if you are not getting water to the top rack check to make sure that you have enough water in the unit. also before starting the wash you want to point the wash arm in the same direction to make sure that they are turning. Do they turn? when you are finished with a cycle do you see steam or is it cold inside. let me know what you find.
Sep 07, 2009 | Kenmore Dishwashers
Top shelf dishes are not washed
possibly low water pressure...
racks might be in backwards if it's an older model with wheels on shelf system... rubber bumpers should face out...
could be a blockage in the upper sprayer arm... or the upper arm had come off and was remounted in a position that doesn't line up with the jet of water from below...
could be bad loading technique... sounds simple enough but you should never put large bowls or pots that lay horizontally on the lower rack because it really screws up the cleaning effectiveness. Large items should always go on the top rack or be washed by hand if they don't fit on the top rack.
Sep 02, 2009 | Whirlpool Dishwashers
My dishwasher is leaving a lot of residue on dishes
I had the same problem and fixed it by disassembling the lower spray arm and return filter, and cleaning all the junk out.
Most dishwashers have 'risers' that bring the water up to the top sprayer or arm located under the top rack. If the recirculating pump is plugged even a little there won't be enough volume or pressure to get the water up there.
Test this by putting a dry muffin pan in the top rack, flat, and running the dishwasher for a bit. If there is no water on the top (or the bottom) either the top sprayer or the sprayer arm underneath the top rack is not getting enough volume.
To fix this you need to clean out the screen and filter, where the water returns to be recirculated. If you don't have any confidence to remove the parts and clean it out yourself, get an appliance repair person to do the job.
Aug 26, 2009 | Dishwashers
Our GE Potscrubber 640 isn't cleaning the top rack items. They are neither cleaned nor rinsed. Does it have something to do with the "Rinse Dispenser" knob on the door? It's always been fully screwed in.
likely not .....the problem may be how you stack the dishes ....try doing a load with nothing on the bottom rack ....if the top rack items come clean then you may be stoping the water from reaching the top rack with the dishes on the bottom rack ....it's important to keep the center of the bottom rack free this is where the water comes from (on most models). to clean your upper rack .....have a close look at the inside of the machine to try and figure out where the water comes from ...it helps a lot to understand this ....good luck
Jul 25, 2009 | Dishwashers
Will not clean dishes on the upper rack
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
Jun 16, 2009 | KitchenAid KUDR01TJ Dishwasher
Only some cups on top rack are getting cleaned
It sounds as if you have some rollers missing on the bottom rack which lets the rack sit on the sprayer therefore not letting it spin. You should have 4 rollers on front and 2 on back of rack. If you are missing two on one side, take one from the other side until you can get some more. Just make sure you have a roller on all four sides of the rack
Jul 18, 2008 | GE 24 in. GSD4030Z Built-in Dishwasher
Water not going through spray arms
1.does motor run? no. replace motor. 2.open door and leave the bottom rack inside dw.spin the spray arm underneath the bottom rack by hand. it should spin freely without binding. if it doesnt spin freely take out the bottom rack and try again. if it does spin freely then your bottom rack is laying on your sprayarm preventing it from rotating. 3.you could also not be getting enough water into your dw.
Mar 21, 2007 | Frigidaire 24 in. FDB421RF Built-in...
Korg TR76 76 Key Synthesizer Workstation  Logo
212 people viewed this question
Top Korg Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Dennis Gutowski
Dennis Gutowski
Hardware and...
Are you a Korg Computer and Internet Expert? Answer questions, earn points and help others
