Question about Haier HSU09XCA 9000 BTU 10 SEER Rating Cooling Only Mini Split Air Conditioner With Remote Control
Why does my a/c unit keep freezeing up?
  • 614 Answers
Dirty filter,dirty evap coil or low on refrigerant. Rus. The first you can handle the last call a service tech
Posted on Jun 14, 2009
Dca213d window unit keeps freezing is it thermostat?
Check for badly bent fins or obstructed/dirt impacted fins on the outside of the unit. Could also be low on gas. Try setting the t/stat to various settings see if its turning off/on at higher settings, if it does most likelt stat is OK. Also make sure you drian is clear.
Aug 12, 2014 | Carrier Heating & Cooling
We have a Goodman AC Unit and the pipe continues to freeze.
either the inside coil is dirty or system is overcharged.
May 14, 2014 | Goodman CLQ36AR49 Air Conditioner
Ac unit in the house keeps freezing up, not a window unit, central unit. The entire part inside keep freezing up, making knocking noise, and not blowing cool air. The out side part is fine, no problems...
There is a coil out side in the unit , it needs cleaning, there is an acid that is used to clean it. Its an easy job, pull the top open and use a stick or something to keep it up so you can spray the coil, with the unit off let soak 10 mins then spray wash with water hose. done
Sep 29, 2013 | Heating & Cooling
Keeps freezing
low air flow or low on refrigerant.
Jul 24, 2013 | Goodman Heating & Cooling
Fridge keeps freezing up have replaced motherboard
What is the model number of your unit?
Nov 23, 2012 | Refrigerators
My A/C freezing its coils, while the fans keep running. The AC unit (outside) keep running and never stop caused the coils freezing. It doesn't matter when I turn off or set it to Cool position, the...
Sounds like the contactor in the condensing unit is stuck. That is why it will not turn off when the thermostat is satisfied. If the inside air handler is not blowing and the outside condensing unit is running, then this will cause the inside coils to freeze up rather quickly.
The contactor is located in the outside condensing uni in the electrical compartment.
If it is sticking it will need to be replaced.
Sep 07, 2011 | Heating & Cooling
Wha is a warmer
A warmer can mean two things when considering a refrigerator. The first will be a evaporator core warmer or heater. This device is essentially an element that keeps ice from forming on the core. It is controlled by a defrost timer and a thermostat. Once the timer reaches a set interval, it will initiate the warmer/heater to defrost the evaporator core. This mechanism will keep the core free of ice, which in return, keeps the unit operating as designed. The second type of "warmer" is a water line warmer or heater. This is a thin copper or steel line that is wrapped around the inlet lines inside your unit. This type of warmer/heater keeps the inlet lines from freezing over inside the unit. If the line freezes, they cant transfer water to the dispenser and ice maker. This style of warmer prevent s these important lines from freezing over.
Additionally; some side by side units have divider warmers to keep the condensation down that can form in the summer months. This type of warmer is mounted inside the frame, near the divider, and is an automatic functioning device.
Jul 23, 2010 | Refrigerators
Evaporater freezes up after running for aa short while
HELLO THERE:
When you set the temperature settings down around 64 or lower the unit will freeze up so i recommend to keep it at around 68 or 70 ok this will keep it from freezing also make sure that the unit is free of any obstructions so the air can freely get to the unit ok?
best regards michael
Aug 27, 2009 | Whirlpool ACM184XP Air Conditioner
Unit freezing up
It will not hurt the unit if you let it thaw out and then run it again. However, if you keep doing this on a regular basis, you can burn out your compressor. What are the conditions that the unit is being run under that is causing it to freeze up? Make sure that you run the unit on high cool on warm days so that it will not freeze.
Hope this helps,
Jeff
Jul 03, 2009 | Heating & Cooling
Liebherr fridge 3150 keeps freezing
The problem is the thermostat, not the drainhole. The thermostat should stop the compressor when a setpoint temperature has been reached, this gives the unit a chance for a small defrost.
Mar 03, 2009 | Liebherr KELB 2840 Premium biofresh...
Heating & Cooling Logo
345 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
