Question about Sanyo Dp32640
Tv shuts off
TV will just shut off randomly. Sometimes it will come back on in 2 hours, sometimes it takes 24 hours
    President:
  • Sanyo Master
  • 775 Answers
You may want to check the below article for a wide list of Sanyo models exhibiting "random turn off" problem along with repair options for them.
http://blog.coppelltvrepair.com/2012/07/sanyo-dp47460-dp42840-dp46819-and.html
All in all the first thing you need in order to get meaningful help is providing information about which particular model and chassis is your TV.
Both are on the label at the back.
Posted on Mar 21, 2014
jerryg50
  • 1689 Answers
SOURCE: TV Just shut off
This may be a power supply failure. The set would have to be troubleshooted to determine the exact cause, failed parts, and replace them. It is also possible that there is a short somewhere else that caused the power supply to shut down or be damaged.
Jerry G..
Posted on May 17, 2008
praky16
  • 744 Answers
SOURCE: Green tint
It sounds like the color wheel has gone bad and needs to be replaced. This is located behind the back panel... replacing a new colour wheel will solve ur problem
thank u
rate me
Posted on May 29, 2009
MNfisherman
  • 11896 Answers
SOURCE: My tv just randomly shut off. I unplugged it for a
Sounds like a faulty power supply. You can test wires from power supply to main board with a voltmeter to see if it is sending power
Posted on Nov 19, 2009
ginko
  • 19396 Answers
SOURCE: TV shut off randomly. Unplugged
Hi.
Random shut down can be caused by faulty power adapter, faulty inverter and faulty controller board, add buttons, shorts, bad fan and IR sensor.
The TV must be tested to find out the problem.
I suggest contacting Sanyo by calling the number listed on the owners manual.
Parts and part price available here.
  • 12 Answers
SOURCE: 3 YEAR OLD SANYO DP 32746. SHUT ITSELF OFF, CAN NOT TURN BACK ON
If you leave the tv unplugged for 2 days (atleast) then plug it back in and try to turn it on and if it comes on its the power supply board. If it comes back on it will probably shut off between 30min to 4hrs and you would have to unplug it for 2 days again. All the power needs to drain out of the tv. If thats the case take the back pannel off and check the part number out on the internet. Not hard to do becarefull touching things the power supply does store a little bit or shock in it. Good Luck.
Posted on Dec 16, 2009
Testimonial: "while we did not unplug the set, we let it sit for 2 days and we were able to turn it on by the remote & manually....does that still sound like P/S"
We have the RCA HD52w59 projection tv. The tv shuts itself off at different intervals. It takes approximately 1 minute to be able to turn the power button back on, however, I have to do that many times...
A problem in the deflection board. Could be a Cap. Resoldering the deflection board may take care of the problem. You need to call a TV man to do this kind of work.
Best of luck
Nour Sabre
WWW.AAATVSERVICE.COM
Jul 28, 2011 | RCA HD52W59 HDTV Projection Television
I have an older i think its a sanyo big screen tv and i can watch it for miniute sometimes or hours other times and then it randomly shuts off. it might come right back on or right now its been off all...
Hi Friend,
Please folliow the below steps one by one
Step 1: Turn on the TV
Step 2: Hold the ON/OFF Button for 10 to 20 Secs
Step 3:Without taking the hand from the ON/OFF button unplug the power cable connected to the wall outlet from the TV
Step 4:Without taking the hand from the ON/OFF button put the power cable back to the outlet
Step 5:Now take the hand from the ON/OFF Button and try to turn it ON again and check
If you have any Clarification please feel free to contact us
Regards,
Ayyasam
Apr 02, 2010 | Televison & Video
I'm having difficulities with a RCA entertainment series television. A little while ago my T.V started going crazy. For example, Sometimes when i go to turn it on to change the channel it will say panel...
Best Way reset the set,U right it well reboot itself,before u go to sleep unplug the tv,take out the bateries to remote.Morning,plug in and put the bateris back might reset it self.
Aug 17, 2009 | RCA 32F531T 32" TV
LG 52SX4D turns off randomly.
My Lg 52"tv turn off and on
Apr 29, 2009 | Televison & Video
PRO 510HD PROBLEMS
if you know anything about the tv, take off the back and remove the power supply board. Reflow or resolder the solder points, takes like 2 hours, but is well worth it as my tv works fine now. make sure to use rosin core solder and good luck
Sep 11, 2008 | Pioneer PRO-510HD 53" Rear Projection...
TV randomely turns off
it may just be a static buildup from the dust.
open the tv and blow it out with a air compressor.
if that doest not work then the circuit may be overloading.
remember it stores a charge for days.
Feb 17, 2008 | Philips 30PW9817 30" TV
Viewsonic N3000w LCD TV randomly shuts off...
It seems that the power fails quite often with this one burning the Inverter boards transformers. OZ960G chip may not be broken, so try getting a new power from somewhere. Measure the transformers. suppose to be somewhat 5 ohms. tolerance is +-1.5 ohm. of more, replace.
Nov 21, 2007 | ViewSonic N3000W 30 in. HD-Ready LCD...
Sanyo Dp32640 Logo
160 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
