Question about Husqvarna Garden
334t fuel line
Remove fuel lines from fuel pump housing
You may need a fuel line tool that compresses a spring in the collar. You can get them at any auto store..
Apr 28, 2013 | Cars & Trucks
Replace fuel lines on model no. 358.797931
Hi.
Before you remove any fuel lines, make a drawing or take a picture of how the lines are connected to the tank for later reference.
You will need to remove all the old fuel lines and fuel filter out of the gas tank.
Clean and remove all trash, broken lines,etc. from the fuel tank.
After you have all the trash,fuel lines and filter removed.
You will trim the end that goes into the fuel tank to a point.You will lubricate about 1 inch of fuel line with a small amount of vasoline or light machine oil...
Now using your fingers or small needle nose pliers push the fuel line and insert it into the hole in the fuel tank.
After you have the fuel line in the tank, extend enough fuel line into the tank to exit the fill spout of the tank .
You will insert the new or cleaned fuel filter into the line and pull the fuel line to pull the filter just back into the tank.
Hook up the fuel lines to the carburator and you should be good to go
Please take time to rate me
Bud
Apr 21, 2013 | Garden
How to change fuel lines
There should be only 2 fuel lines and a vent line coming out of the tank. The vent line is for fumes that are routed to the charcoal canister-part of the evaporative emissions system, and the two fuel lines are the main feed line to the filter and then on to the engine, and the other gas line is the return line from the engine back to the gas tank. All fuel injected systems have a feed line and a return line. The return line is for fuel not used but sent back to the tank by the fuel pressure regulator.
Nowadays, rather than replace metal lines, shops can use the plastic fuel lines (they don't rot!) and special connectors to fit new fuel lines. YouTube has lots of videos on replacing fuel lines.
Apr 23, 2017 | 2004 Buick Rendezvous
How do I replace a broker fuel line? The one broken has a filter inside the tank.
Hi doug c197...
I will also include a fuel routing drawing.
After you have all the fuel lines and filter removed.
You need a piece of wire...smaller diameter than the inside of the fuel line, insert the wire into the fuel line until it exits the fuel line then bend a hook on the end of the wire to hook over the fuel line.
Now using your fingers or small needle nose pliers collapse the fuel line around the wire hook and insert it into the hole in the fuel tank.
After you have the fuel line in the tank, extend enough fuel line into the tank to exit the fill spout of the tank and remove the wire from the fuel line.
Sep 24, 2011 | Garden
Have 2 gas lines dangling in gas tank, mcculloch 42c, 36cc, older, one line has filer other for primer????? or did it come disconnected
Hi perfecthelme...
Those are broken fuel lines your are seeing and a fuel filter inside of the tank
I will include a fuel routing drawing.
Clean and remove all trash,broken pieces of fuel line,etc. from the fuel tank.
How do i remove the fuel delivery and return connectors at the engine
go by the auto parts store, buy fuel line disconnect tools.you take the fuel line disconnect tool, place it on fuel line push tool in the fuel line connector to seperate fuel lines.make sure when you get ready reconnect fuel lines back together you should hear fuel line snap back in place.make sure fuel line in place dont come apart. to be on safe side dont crank car first just turn ignition to the on position for few seconds check for fuel leaks.
Jul 31, 2011 | 2000 Buick Century
What are the carburetorr pin settings for a 334t tree saw
hi there
the base settings for hi and lo are 1 & 1/4 turn out from lightly seated
but make the hi setting just a fracrtion richer at top speed no load it should putter or 4 stroke slightly and the lo one should be about right buyt should pick off nicly when you stab the throttle quickly with no hesitation
note do not sett hi mixture setting to lean 2 top nol load or when you place it under lood it will lean out further and destroy the piston and rings
cheers pauly46
May 29, 2011 | Husqvarna Forest & Garden No.967012396 345...
My Toyota Sienna keeps stallling
If the car stalling then the owner of the car should check on the fuel pump assembly. prepare the tools and equipment in servicing the fuel pump,the fuel lines and the fuel filters.In the fuel pump you have to locate the fuel pump,disconnect fuel lines from the fuel pump,remove fuel pump from the engine,dis-assemble fuel pump, check the diaphram for defect , replace defective parts,assemble and install the fuel pump.
In checking the fuel lines : prepare the tools or equipment in servicing the fuel lines .So that the fuel will flow freely and no abstraction within the fuel lines.locate the the fuel lines ,visual inspection on dual line for leakage, disconnect lines at fuel pump and fuel tank .use compress air to remove sediment on fuel lines,re-install fuel lines to the unit.
the fuel filters :prepare the equipment or tools in checking the fuel filters that is going to be used.So that when fuel filters is removed ,no fuel will spill on the vehicle and no parts are lost or broken.Locate fuel filter,disconnect lines at fuel filter ,observe safety practices ,If the fuel filter is dirty then you have to clean it but if it is worn out and not anymore to be used then install new fuel filter.
Sep 24, 2009 | 2008 Toyota Sienna
Finding were a filter is
On these vehicles, the fuel filter is located on the fuel line to the carburetor. Special care should be taken when removing and installing the fuel filter, not to bend or distort the fuel line in any way.
  1. Remove gas cap to relieve any pressure that may be present in the fuel system.
  2. Remove the air cleaner bonnet assembly.
  3. Using a backup wrench on the return line fitting on the top of the fuel filter, remove the fuel line with a flare nut wrench.
  4. Using a backup wrench on the fuel filter inlet fitting, remove the fuel line from the fuel filter with a flare nut wrench.
  5. Using a backup wrench on the fuel filter outlet fitting, loosen the fuel line and remove the fuel filter from the engine with a flare nut wrench.
To Install:
  1. Apply a drop of engine oil to all the fuel line nuts and flared ends.
  2. Position the fuel filter with flow arrow on the filter directed towards the fuel line going to the carburetor.
  3. Finger-tighten the fittings at the fuel filter outlet, inlet and return line into the top of the filter.
  4. Using a backup wrench on the fuel filter fittings, tighten the fuel lines in the following sequence:
    1. Tighten the outlet and inlet line nuts to 15-18 ft. lbs. (20.0-24.0 Nm)
    2. Tighten the nut on the return line at the top of the filter to 6-9 ft. lbs. (15-18 Nm).
  5. Inspect the fuel lines and carefully adjust if they are interfering with the carburetor, air pump, or fuel filter housing.
  6. Start the engine and check for fuel leaks at all the connections. Retighten if necessary.
  7. If removed, install the air filter bonnet assembly.
Jul 26, 2008 | 1993 Ford Tempo
Garden Logo
78 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
