Question about GE 3.9 cu. ft. Stainless Steel Capacity Washer GHWN4250DWW
How do i remove agitator ge model GHWN4250DOWW
How do I remove agitator ge top load washer
SOURCE: removing cover assembly on GE top load washer
Is your washer a GE Profile Harmony? Do you want to know how to take the top off or the top of the agitor (pulsator)? The top of the washer has four screws in the back top behind the screen once you unscrew them the front of the washer has two clips one on each side and you have to kinda tap it with your palm to get them to pop.
Posted on Jan 13, 2009
  • 6 Answers
SOURCE: Agitator is slipping- GE model WJRR4170G top load washer
IF the agitator is like the ones in the older models, it will just pull straight up and off of the transmission shaft.
Inside the agitator there is a rubber splined insert with an aluminum center. The soft aluminum strips out causing the grinding sound. Very common to happen.
We used to use a special puller to remove that part and then press a new one back in.
Voila! Repaired agitator!!
Most any appliance parts store should be able to look up your model # and tell you if that agitator can be resplined.
Posted on Feb 20, 2009
Macintoast
  • 4 Answers
SOURCE: GE washer won't agitate
I had this same problem with our GE top load washer.  I just needed to pull harder.  (Note: The agitator is held in place by about a dozen L-shaped clips in a ring around the agitator's base that will release more as you pull harder on the agitator.)  Everything from the base below the large fins on up comes out together.  Grab the shaft above the fins and pull slowly and hard. I had to take the entire tub out, lay it on the porch, put my feet inside of it, and pull the agitator assembly out.  I wasn't able to pull it out while it was still in the washer.  BE CAREFUL! DON'T **** IT OUT; that might injure your back; just pull out slowly and as hard as you can without hurting yourself.  I was able to get it out successfully, but I am currently stuck at removing the bell below the agitator.  Good luck!
Posted on Feb 28, 2009
  • 4 Answers
SOURCE: GE WHDRR418G1WW Washing Machine will not agitate or spin/rinse cycle
Tell me more Is there voltage to motor? The transmission makes it agitate .
Posted on May 30, 2009
  • 82 Answers
SOURCE: Washer only spins
Have you tried to unplug the machine, sometimes the control boards can get stuck and if you unplug it for say 30 seconds then plug it back in, it may reset itself. otherwise you may have to call someone these are very complicated machines.
Posted on Jun 19, 2009
Gtwn3000mows ge washer need to replace the washer drive block and cant figure out how to remove the agitator from this particular model
On my top-load GE HydroWave washer the agitator just snaps in with a bunch of tooth-like clips in the center of the inside of the agitator. To remove it, grab it on the very bottom of the agitator by hooking your fingers underneath the bottom flange (using two hands evenly spaced) and just lift hard to yank it out. The clips will unsnap and then it just lifts out. Really bad design IMHO but that's how it comes out. I thought I was going to break something doing this but it came right out.
Aug 04, 2013 | GE WBSR3140DW Top Load Washer
NEED TO REMOVE AN AGITATOR FROM A WASHING MACHINE
  • 1 First you must determine the brand of washing machine you have.
  • 2 To remove agitator on a whirlpool washer, remove top cap from agitator, Next you will find a translucent cap, remove this with your pliers. Then you will see a 3/8 inch nut, Back this nut out and you can then remove the agitator. Be Careful though, inside the agitator where the bolt has been removed is a white piece of plastic that holds the "dog ears". These dog ears are what lets the agitator move in one direction and locks when the transmission moves back in the other direction.
    Maytag and Admiral washers are very similar to remove. General Electric, (GE) is different, To remove a GE agitator simply pull upwards very hard, GE agitators snap on. Be careful not to pop it into your mouth, that really hurts.
  • 3 Remove agitator, repair or replace and reset, GE just push on, you will be able to see the groves to line up the agitator to the hub. For whirlpool place bolt into dog ear guide, and set down on top of transmission post and tighten, be careful that dog ears, do not get out of alignment. That's it.
    Buy F150 parts.
    Jun 03, 2012 | GE Washing Machines
    How to take out the agitator on ge top load washer
    Normally you can remove the top from the agitator, where you would normally put conditioner, and look down the centre of the agitator and should see a retainer of some description that should be able to be undone by hand.
    Feb 23, 2012 | GE WBSR3140DW Top Load Washer
    Ge top load washer won't agitate or spin after
    what is your model number is then we can started then okay
    Sep 15, 2011 | GE Washing Machines
    Coin stuck in agitator. how is agitator removed
    Normally you can take the top of the agitator off with the use of a screw driver or by turning couter clockwise. Once the top is off you should see a nut or bolt. Removing this will allow the agitator to be removed.
    Nov 12, 2010 | GE Profile WPRE6100G Top Load Washer
    How to remove agitator from GE washer? Model WHDRR418G1WW.
    how to remove agitator from GE hydrowave washer machine?
    Feb 27, 2010 | GE WBSR3140DW Top Load Washer
    GE top loader not agitating
    Your agitator splines are probably stripped out.
    Remove the agitator and check the spline grooves.And the agitator coupling on the shaft.
    Mar 04, 2009 | GE WBSR3140DW Top Load Washer
    GE topload washer Agitator
    theres no nut and bolt,,only a cam or bell ..you have to roch agitator back and forth,,until it losens,,and pull up reall hard..or put your belt under agitator and yank up..onthejob
    Jan 23, 2009 | GE WBSR3140DW Top Load Washer
    The ge wcxr1070t uses a coupling under the agitator . There is a cap on the top pop it off and remove the screw if you see one , otherwise just pull up , the coupling is under the agitator check to see if it is stripped . dr fixit in the repair service directory will have it if bad
    Dec 03, 2008 | GE WBSR3140DW Top Load Washer
    GE washer WWSR3090T6WW
    I DONT KNOW HOW TO REMOVE MY AGITATOR PARTS TO PUT IN THE NYLON COUPLING I GOT THE TOP PART OFF BUT THATS THE ONLY PART COMES OFF
    Oct 22, 2007 | GE WDSR2080D Top Load Washer
    GE 3.9 cu. ft. Stainless Steel Capacity Washer GHWN4250DWW Logo
    78 people viewed this question
    Top GE Dryers Experts
    Dave Harrison
    John Tripp
    John Tripp
    JP Services
    JP Services
    Are you a GE Dryer Expert? Answer questions, earn points and help others
