Question about Delton Clear Call Wireless Bluetooth Headset - Retail Packaging -
Delton 10X headphones stopped working, I charged them earlier. I plugged them back in and the red and blue light started flashing back and forth rapidly. I could not shut it off?
What if my uproar wireless headphones are flashing red and blue ?
The headphones flash blue when u switch it on.If it flashes blue and red, it means that it is in bluetooth connection mode.So u can connect it with bluetooth devices by switching on bluetooth on your phone or pc.After connecting the red light stops flashing automatically and blue light starts blinking.Hope you understood. :)
May 04, 2016 | Audio Players & Recorders
Wont turn on keeps flashing a red light
The batteries may not be able to charge or charge completely.
Jan 29, 2015 | Aftershokz Sport Bone Conduction Headphone
Why does my kinivo bth220 headphones have a flashing red light on them no matter how long i charge them and they will not turn on
The batteries won't charge. You might want to google around for replacement batteries.
First I'd try a factory reset. PRess the +, - and multifunction button for 6 seconds until the blue light flashes and it shuts off. When you turn them on next, it's in pairing mode and try again.
Aug 10, 2014 | Kinivo Bth220 Bluetooth Stereo Headphone -...
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
My sms audio by 50 cent wireless dongle stopped working after putting it for charging
When I plug in my dongle to charge the blue led light comes on but when I want to use it, it won't turn on??
Mar 08, 2013 | SMS Audio SYNC by 50 Wireless Headphones...
They Won't Charge!
Try to press the power boton in the same time you plug the charger, after this action mine is working and charging perfectly, maybe this is the "reset" solution... Hope this helps you.
Nov 17, 2009 | Motorola Mobility S9 Headphones
Flasing red light
The flashing red indicates that either the fileter cover or the lamp cover is not installed correctly. If both are installed properly and secured, the unit will require service.
Dan
May 09, 2008 | Sharp XR-10X Multimedia Projector
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
Mar 11, 2008 | Logitech FreePulse Wireless Consumer...
The peaice that goes into the headphone jack isnt working
i researched the logitech website and found the solution.
you must turn both parts on, but instead of letting go after 3 seconds, you keep holding until the lights start flashing red and blue on both pieces. Once BOTH pieces flash ONLY BLUE they have re-paired themselves, and they should work fine now.
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/fattach_get.php?p_sid=kPXUPeRi&p_li=&p_accessibility=0&p_redirect=&p_tbl=9&p_id=2883&p_created=1125080596&p_olh=0
Oct 06, 2007 | Logitech Bluetooth Wireless Headphones
Delton Clear Call Wireless Bluetooth Headset - Retail Packaging - Logo
89 people viewed this question
Top Delton Radio Communications Experts
eradiostore
eradiostore
Are you a Delton Radio Communication Expert? Answer questions, earn points and help others
