Question about GE Toaster Ovens
Does not cook food
Elements do not work
What setting should i use to cook food in the oven,
pick one and go,you see,we dont know what stove you are talking about or what settings because you failed to tell us these things in both questions
Apr 23, 2015 | Better Toaster Ovens
How to change the lower element on a delonghi AD 699 toaster oven?
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Hope this work ..........
    Jul 07, 2010 | DeLonghi AD699 Airstream Digital 1500...
    Top element not working all wires are connected
    Very possible the element on top has a break some where but maybe small enough you cant see it or could be hiden. If you have access to a multimeter put it to ohms and with it unplugged from the outlet take the wires off the element and check the element itself if the multimeter reads OL the element is bad.
    Mar 08, 2010 | Black & Decker TRO651 Toast-R-Oven Toaster...
    Bottom elements on DeLonghi AD699 failed.
    Solution: buy a new toaster oven. I determined that the manufacturer stopped selling replacement heating elements in 2006, three years after the model year (2003). After market parts makers don't sell the elements for safety and liability reasons. So I got a new one.
    Nov 17, 2009 | DeLonghi AD699 Airstream Digital 1500...
    Burnt pie
    YES YOU ARE your trying to bake something in a toaster oven :) toaster ovens have two modes toast /bake in this mode top and bottom elements get hot .and broil in this mode only the top elements get hot . the problem is the marketing the word OVEN makes you think of a normal oven that the bottom elements do all the work . toaster ovens work well melting stuff and toasting . thats about it . if you must bake in it try placeing a sheet of foil on top of your baked goods it might insulate the top of you food . good luck ... if this answer helped please rate it a 3 or 4 stars , this high rateing will help keep me in the paid answer department , thank you
    Apr 13, 2009 | Toaster Ovens
    The lower heating elements do not heat up enough.
    Hi sibboah,
    Go to
    http://prc.prodregister.com/prodprotect/applica/
    And click on "George Foreman" (lower-right portion of the page), it redirects you to a secure webpage where you can register.
    https://secure.prodregister.com/prodprotect/applica/gf.shtml
    Part of the page reads:
    "Call toll-free or visit our websites for assistance if you need more help.
    Parts & Accessories:
    Phone: 1-800-738-0245 (Monday–Friday, 8:30 a.m. to 8:00 p.m., ET)
    Product Warranty:
    Service: 1-800-231-9786 (Monday-Friday, 8:30 a.m. to 8:00 a.m., ET)"
    If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
    Thanks in-advance for using Fixya.com,
    Jon
    Dec 05, 2008 | George Foreman GRV660 Toaster Oven with...
    Broiler element
    Its an on or off thing. No way to control the flow of electricity.
    The elements are bigger than necessary to heat the unit quickly, the problem you have is a bad thing with food that burns easily but a good thing that makes these units come up to temp so quickly after turning on.
    Unfortunately the only thing you can do is put more space between the element and your food or use aluminum foil (not suggested, its too close to the burners).
    Eventually the contacks will fail (unless you are one of the lucky ones).
    Good Luck
    Feb 03, 2008 | Cuisinart TOB-30 Toaster Oven with...
    Heating elements
    I think this is a common problem with these kind of toaster ovens. Mine isn't a Toastmaster - mine is Cook's Essentials (from QVC), and my upper elements have also warped and split, although mine are curved downwards.
    Dec 12, 2007 | Toastmaster 328 Toaster Oven with...
    Half working
    see my above comment for suggestions on how to fix it...
    Jun 18, 2007 | Black & Decker CTO6300 Toaster Oven with...
    Toaster Ovens Logo
    27 people viewed this question
    Top GE Toaster Ovens Experts
    Mack Baxter
    Tom Chichester
    Bill Boyd
    Are you a GE Toaster Oven Expert? Answer questions, earn points and help others
