Question about GE Dryers
Tinny noise in ge dryer
Newith a tinny noise from the rear area of the dryer
2 Suggested Answers
  • 12104 Answers
SOURCE: what could cause a tinny rattling noise coming
check the heat covers on the exhaust system-from manifold down to cat converter on may be loose or damaged also check cover plate /inspection plate for bellhousing
Posted on Mar 14, 2010
How to adjust alignment on dryer door?
GE Dryer door area making a noise....
Most likely your sleeve bearing housing is cracked. Need new bearing housing and front sleeve bearings.
Jul 24, 2014 | GE Dryers
GE 5 Cycle Automatic Heavy Duty Extra Large loud noise
All ge dryers have a center bearing on the back side of the drum and drum glides on the frontside. The glides make a scrubbing sound when bad and the drum is hard to turn. The rear bearing does a squeak thang when the plastic bearing wears thin and begins to make metal to metal contact between drum mount and rear bulkhead mount. It is an easy fix but the drum gotta come out. here is my pictorial page that shows how with videos and repair pix:
Paw Paws GE dryer repair page
http://appliancejunk.blogspot.com/2011/09/late-model-hotpoint-dryer.html
http://appliancejunk.blogspot.com/2011/08/hotpoint-dryer-eating-clothes.html
Jan 09, 2013 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Loud rumbling noise with slight vibration
Normally the noise you hear is caused by the drum rollers having flat spots on them or needing lubricant.
If this is what is wrong It will make a kind of thumping noise.
When they need lubricant they will normally make a squealing noise also. You would lube the shaft and bearing area of the roller, using a good machine oil...something like "3 in One" oil.
Sep 26, 2009 | GE DBXR463ED Electric Dryer
My ge dryer makes a swalling noise when i
The rear bearing is noted for this. oiling will delay the inevitable unless it has already gone too far. the repair kit has a teflon sleeve in it.
Eric
Jun 08, 2009 | GE DCSR473EV Dryer
Ge dryer squeeking
HI,
For a pictorial troubleshooting please open the link:
http://www.applianceaid.com/my_own_dryer.html
You will be looking at the front glides that the drum rides on, the glides are probably gone and the drum is rubbing on the plastic glide holder....if it is damaged will need to replace the front drum bearing/glide holder and all of the glides, usually about 4 of them.
If it is the drum front glides the noise will be from the front area, right behind the front panel at the top. If the noise is from the center rear of the dryer your drum bearing is gone, need to replace this also if you have to take this dryer apart..
Thanks
Apr 08, 2009 | GE Dryers
Ge dpsr475gwoaa gas dryer.
rear bearing is dried up needs to be taken apart and re-greased with high temp grease
Feb 17, 2009 | GE DBSR453EBWW Electric Dryer
GE Dryer DPSR483GA2WW too noisy
Remove the rear panel from the unit. This should expose the motor, drive belts, and the drum bearings. Now turn on the unit and your may be able to determine where the noise is coming from. Keep your hands away from moving parts and electrical connections!!
Ray
Dec 14, 2008 | LG DLE3777 Electric Dryer
Dryers Logo
16 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Sal DeAngelo
Are you a GE Dryer Expert? Answer questions, earn points and help others
