Question about Roper RAB2121KW Top Load Washer
Drum My drum has become loose from what it holds it in place. How do i put it back into place.
  • 481 Answers
You need a special tool for this job, you may need to call a service co.
Posted on Jun 27, 2008
The belt came loose and now the dryer wont turn how do i put the belt back on track?
Check if the screws that holds the motor becomes loosens and cause the motor to move from its original position. If you found out that it has moved towards the spinner just bring back the motor to its original position and tighten the screws that holds it. If you found out that it is in place, you will have to replace the belt.
Jul 14, 2011 | Kenmore 500 6952 Dryer
Drum light flashes
This means that you will need to replace the drum soon. Order a new drum and when the light becomes steady or the print quality becomes poor, replace the drum. The drum should last ~12,000 pages. The part number is DR350. You may be able to order this from your Office Supply store; otherwise try the Brother Mall site: .
The procedure is similar to replacing the toner but instead of putting a new thing of toner inside the drum, you remove the toner and put it in the new drum. Open the front cover and pull out the drum and toner assembly. Place on newspaper or other disposable material (toner may spill). Push down the blue lever to unlock the toner cartridge. Remove the cartridge from the drum. Unpack the new drum (keep it out of the light until ready to replace the drum). Push the toner cartridge into the new drum until it locks into place; the blue lever should lift automatically. Put the assembly back in the printer. Clean the printer as recommended in the manual while it is open; this includes cleaning the corona wire before replacing the drum assembly.
After replacing the drum, reset the drum counter: with the printer on and the drum light blinking, open the front cover and press and hold the GO button until all of the LEDs light up (about 4 seconds). Then release the GO button and close the cover. Check that the drum light is off. (The manual says you should do the reset first but I tend to avoid this in case of distractions.)
I hope this helps.
Oct 06, 2010 | Brother HL-2040 Laser Printer
Brakes seized on ford ranger
A drum brake shoe lining may have become separated from the metal pad that holds it in place and will cause the wheel to lock. The only repair necessary is to replace the brake linings with new ones. The loose piece of brake lining, if this is the cause, will not likely cause any difficulty removing the drum.
Jul 25, 2010 | 1992 Ford Ranger
My creda simplicity t622cw condenser dryer wont turn
Broken or belt has come off. If can open back and fix or replace. You may need to remove the top. Careful of the heat element, lift out drum and place new belt on motor holding it while you put the drum back keep hold of belt and place around drum replace top and should be ok. Hope this Helps
May 25, 2010 | Dryers
How do you remove the backing plate from an '05 Chev Venture rear hub so the hub can be replaced?
The 4 Bolts that Hold the HUB in Also Hold the Backing Plate
Hub Replacement - Rear (Front Wheel Drive/Drum)
Removal Procedure
  1. Raise and support the vehicle.
  2. Remove the tire and wheel.
  3. Remove the brake drum.
    1. Remove and DISCARD the wheel bearing/hub bolts.
    2. Remove the wheel bearing/hub.
    3. Disconnect the wheel speed sensor electrical connector (2).Installation Procedure
    4. Connect the wheel speed sensor electrical connector (2).
      1. Install the wheel bearing/hub. Caution: These fasteners MUST be replaced with new fasteners anytime they become loose or are removed. Failure to replace these fasteners after they become loose or are removed may cause loss of vehicle control and personal injury. Notice: Refer to Fastener Notice in Service Precautions.
      2. Install the NEW wheel bearing/hub bolts.
      1. Install the brake drum.
      2. Install the tire and wheel.
      3. Lower the vehicle.
Nov 07, 2009 | 2005 Chevrolet Venture
I have a Whirlpool side by side with an ice dispenser. The little door that closes on the outside opening of the ice dispenser has come loose from its bracket. I cannot get to it to reattach it, or even...
if it has become loose, the pin that holds the disp door came be put back into place. if the plastic tab that holds the pin into place broke, you will need to have a kit installed that has a metal bracket. that should be done by a tech. hope this helps.
Oct 21, 2009 | Whirlpool Refrigerators
Banging noise on spin cycle
My beko washing machine was making a racket like this. What it was was the large blocks of concrete bolted to the drum had come loose. Solution was to get a 13mm socket with a bar and extension and tighten them up really hard as far as I could manage. THen the probelm dissapeared no more banging. Worth a try if your has similar blocks attached to outer drum
May 09, 2009 | Washing Machines
Make noise like animal being killed,also leaks from left side bottom. (only 2 years old)
check bearings by placing your palm on inside drum and rotate in an arc back and forth and check for roughness,you can also check for noises such as an element,wire,nail etc clipping the drum ,you could also check if balance brick has become loose hope this helps
May 07, 2009 | GE Washing Machines
Drum disconected from washer
The wash tub is suspended by two large support springs from the top and 2 to 4 shocks (depending on model) from the bottom. It sounds like one or both of your upper support springs may have come loose for some reason. You will need to remove the top panel of the washer by removing the three screws that hold it in place in the rear. With the screws removed, the panel will slide back, then off. You should be able to see the support springs easily at this point. There is one connected to the drum on the left and right side of the tub. If the drum has come loose, all you should have to do is have someone assist you by lifting the tub up high enough to reattach the spring(s). CAUTION: The tub is very heavy due to the fact it has counter weights on the front and rear of the tub. Lifting may take some effort. Now...these springs usually have a small bracket covering the upper end that prevents it from coming loose. It is not normal for them to become detached unless the drum cracks at the spring support, or if you had a severely off balanced load that may have shaken it violently. In addition, if the support springs did come loose, you will need to inspect the perimeter of the door bellow (rubber boot) to ensure it did not become ripped or come loose from the tub as well. This will cause leakage. Please inspect your washer and get back to me on what you found, so that I may assist you further if needed.
Feb 18, 2009 | Kenmore Elite 45986 Front Load Washer
Baffle came loose from do I
there are 3 Tork screrws on the back panel that will allow for you to slide the top back and get access to the top of the drum
May 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Roper RAB2121KW Top Load Washer Logo
37 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
