Question about Bosch RS20 Reciprocating Saw
Twisted the chuck to far and can't install blade
Tried to install blade and twisted the chuck and now can't twist back to install the blade
2 Suggested Answers
  • 37 Answers
SOURCE: blade vibrating
Hi, put a new blade on and try it again
If you need more help please write again
Was this solution helpful? Show your Appreciation by rating it:
Posted on Nov 21, 2008
How do I remove the blade clamp to remove broken blade?
Some reciprocating saws have a spring-loaded chuck you twist to release the blade.
Jul 26, 2015 | Saws
How do I install a blade
Your Ryobi saw may have a twist-type chuck. You twist it and hold it twisted open to insert the blade, then release it secure the blade.
Nov 17, 2014 | Ryobi Reciprocating Saw Rj160v
How to remove the chuck on a makita or other hand held electric cordless drill
usually with a special tool to hole the drive, if you look at the back, if the chuck, where the shaft mates you will see it has two flats or a profile on it, you make get a tool that can grip that and twist the chuck. If it hasn't you have to somehow jam the Motor, or the shaft, and again twist.
Mar 25, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
How do I ''unlock'' and twist to change a drill bit
hold the drill so the handle is facing you and the drill bit is facing away then twist the chuck clockwise. some quick chucks have two halfs in which case you hold the back collar (nearest you still)
if its really tight it the drill bit into the chuck with something soft like a piece of wood so as not to damage the drill
Jan 10, 2010 | Dewalt Drills
How to remove bit retainer or chuck from drill
Grasp the chuck and twist the sleeve counter clockwise and pull up.It will come off. To replace the chuck slide it back onto the drill shaft, grasp the chuck collar, twist it counter clockwise and push down on it, it will slid back onto the shaft and lock into place.
Nov 20, 2009 | Bosch 11222EVS 1 1/8" Sds Plus Rotary...
How do i remove the chuck from an dv 18 dl cordless drill
Most drills have the chuck secured with a screw. Twist the chuck to open jaws fully. Look into the chuck to find a screw head - it may be a straight, phillips, allen or other type blade to engage so that it may be loosened and removed.
If unable to remove the screw - it may have left-handed threads, so try turning the screw in the opposite direction.
I hope this helps!
Oct 26, 2009 | Drills
How do I replace the blade?
Hi rq,
Look at the base of the blade, there is either a half twist quick disconnect or an allen screw.
Safety first: Unplug the saw.
If its the allen screw it will be located to one side of the blade. Just loosen it , pull the blade out.
The half twist ring doesa what its name implies. Twist it as far as you can (holding the saw with the bladed to the ground allows it to drop out) to free the blade.
Best reqards
Mike
Sep 11, 2009 | Porter Cable Variable Speed All-Purpose...
Chuck came off of drill on a Bosch 11236VS hammer drill
Have you pulled the collar to release the pressure on the steel balls. Just pull the collar usually forward and slide on the shaft and then release and twist till it locks. Let me know if I can help further
Jan 07, 2009 | Bosch 11236VS Rotary Hammer
Bosch RS20 Reciprocating Saw Logo
27 people viewed this question
Top Bosch Saws Experts
Parson's Repair...
Parson's Repair...
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
