Toner printer is printing pages with a white line from the top to the bottom of the page
It looks like the toner is not making contact with the paper in one place which leaves a line on the page of empty space. What do I need to clean/ how do I clean it? Also, I changed the toner cartridge and printer about 30 pages with the new cartridge and it still has the same problem.
  • Joshua Emison
    Joshua Emison Mar 23, 2014
    I unscrewed the carriage holding the toner and cleaned everything that I could reach with a microfiber cloth. There was a lot of dust in it. After I put everything back together, the line went away and it has been printing well ever since.
  • 10 Answers
Need to clean a scanner
what model of your laser printer
Posted on Mar 19, 2014
JOHNNY2hotty
  • 41 Answers
SOURCE: missing 3 mm of print from top to bottom
try goign to print settings, and there you can change the setting for margins and headers and footers.
Posted on May 13, 2008
SOURCE: poor printing quality on text
so, what sort of text is it you are attempting to print? what program is in use?
Posted on Aug 19, 2008
SOURCE: Vertical black line on all print outs
1) Check the cartridge. Look at the egg color drum and see if there is any built up toner. If there is then wipe off with soft cloth and reinstall.
2) Does this happen when coping from the flat bed and the doc feeder at the top?
If it it's only from the top then there is a glass lense that might have white out on it.
This is common when using white out and not letting it dry long enough.
To get to the lense it my be tricky but if the top of the feeder open a little from the top pop it open and
the glass is a thin 1/4 strip. Wipe it clean then try again. Hope this helps. Boats
Posted on Oct 07, 2008
SOURCE: Faint vertical lines on Samsung ML-2010
Was the toner remanufactured/ compatible?
Sounds to me like the doctor blade in the cartridge is 'gummed' up and not allowing the toner to flow evenly across the Developer roller......try another cartridge
Posted on Apr 11, 2009
SOURCE: My fax Machine has lines going each page that prints out
Get a can of air, open the unit and blow it out.
Also, clean the glass.
That should help solve the problem
Posted on May 01, 2009
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
Canon i3235
Are the lines across the page, in the direction of text, or from top to bottom. If from top to bottom, watch the scanner bar with the cover up, see if anything looks odd. If the paper moves in this machine, like from an auto feeder, it could pick up a streak from something in the path.
Checking, this unit is a laser printer. When replacing toner, there usually is a little tab thingy that is supposed to be moved back and forth over a little wire. The wire must be kept clean, too. Also, there may be a white bar with a glass cover that is to be cleaned very carefully every time toner is changed. Find this piece of glass, a speck of dust is probably your culprit.
Nov 26, 2013 | Office Equipment & Supplies
Hp 8000n is ghosting excess toner on prints. Why?
Perhaps, but first clean up the exposed parts of the printer where the toner may travel before it makes contact with the paper. Also, the fuser may need to be cleaned or replaced. Post your problem directly with HP on the HP website.
Feb 16, 2013 | HP LaserJet 8000n Printer
HP 2840 printing two thin black lines from top to the bottom of the center of the page is that a fuser kit problem?
It could be a fuser problem.
Put paper in the manual feed tray. Print a few pages. As the paper gets
1/2 way into the printer, open the cover. Look down at the paper in the printer.
If it has 2 thin black lines, the toner cartridge needs to be replaced. If there are no lines the fuser is probably bad.
Jul 22, 2011 | HP LaserJet 2840 All-In-One Printer
When you print each page has a gray/black line running down the page from top to bottom about 2.5 inches from the edge of the paper. Sometimes it is darker and other times it is lighter. We have tried...
While the line is showing up on the output pages.
Stop printing and put paper in the manual feed tray (tray 1).
Start printing again. As a page gets pulled into the printer about 1/2 way open the top cover.
Pull out the toner and look at the page inside the printer. If it doesn't have the grey/black line, get the fuser replaced. It is defective.
Jun 09, 2011 | HP LaserJet 1300 Printer
I am getting a white line on my pages that go from the top of the page to the bottom. What could cause this?
A line all the way down the page means you have something blocking the imaging module like a bit of dirt or a piece of torn paper. Look in the area where the white line is, or it also could be toner being scraped off the page near the fuser, in that case you may see a smudge next to the line.
Dec 19, 2009 | Konica Minolta magicolor 2430 DL Laser...
Jan 08, 2009 | Brother MFC 4800 All-In-One Laser Printer
A pink line is on every page printed
This is a very common problem with this model printer, it is caused by toner on the scanner mirrors. You need to clean the scanner assembly unfortunately it isn't very easy to dissemble the printer to get to it.
Aug 12, 2008 | HP Color LaserJet 2600n Printer
White band on photo glossy output
Open printer, remove drum, clean laser lens with soft dry cloth, reinstall drum.
Manufacturer's Instructions
website: printer.konicaminolta.com
white vertical line (s) / how to clean the laser lens
Cleaning the printer. (5 pages)
Worked for me
Watemusic
Nov 13, 2007 | Minolta magicolor 2400W Laser Printer
41 people viewed this question
jasbo
jasbo
