Question about Primo 900172 1.0 Gallon Industrial Water Dispenser
My top load primo water cooler nozzle is clogged. How do I unclog it?
It barely dispenses water and the small amount that comes out sprays everywhere
I have this same problem...any answers out there?
Posted on Oct 04, 2014
  • lflores
    lflores Nov 29, 2014
    In the end of the nozzle has a small filter, remove it and clean it or better remove it form the end. You really do not need it
I have a primo bottom load water cooler model # 900130 the pump is not working. How do I fix it
I have missing or damaged parts. + - Select parts are available for your dispenser. Please complete the Contact Us form and provide the dispenser model number, serial number, and note the replacement part needed in the comments field. A Care Specialist will follow up with your request. A replacement fee will apply to out of warranty part requests.
900130 Primo Water Store
Dec 26, 2015 | Unknown Primo Deluxe Stainless Steel...
Tip
PRIMO BOTTOM LOAD WATER DISPENSER, BLINKING LIGHT
We started getting a blinking light... indicating the jug needed replacement... after installing a full jug. The unit would cycle, then the red blinking light would come back on. Upon careful inspection of the feed tube and lines, it was realized that the plastic line on the intake of the pump body had been inadvertently pulled out just slightly (presumably from jostling the jug around during replacement). I believe that this breaks the seal the unit requires for suction, and caused the fault. I simply pushed the (white) plastic line back into pump body and heard an audible 'click'. Unit works fine now. I hope this helps, as these units are not exactly cheap.
on Oct 30, 2013 | Primo Grills And Smokers Primo Bottom Load...
What causes ice makers to spray water all over freezer?
Sometimes the water chute that puts the water into the dispenser is too long and it hits the panel and it sprays everywhere.Just cut it a little shorter.
Apr 16, 2015 | Kenmore Refrigerators
Primo water cooler red light blinking
What do I do with my Primo water dispenser whenever the red light keeps flashing I have a full bottle of water in there but it just keeps flashing I can turn it off and turn it back on or I can push the button in the door and it'll go off within the next 20 minutes it will come back on and the water's cold and then the water goes to lukewarm
Nov 25, 2013 | Unknown Primo Deluxe Stainless Steel...
Bunn hot water heater has a slow flow of water
Try brewing a few pots of white vinegar solution, no coffee in the system.
Jan 22, 2013 | Bunn 125000024 Hot Water Dispenser 5...
Maytag side by side refrigerator with freezer on the bottom water is spraying everywhere when the ice machine comes on. It has the ice / water dispenser on the front. Any ideas?
Check the water line leading to the ice maker for kinks. Also check the filer and ice tray end of the waterline for obstructions or ice that might be deflecting the water to areas other than the ice tray. Let me know how you make out. :^)
May 01, 2012 | Maytag Refrigerators
Primo water cooler
I JUST BOUGHT A PRIMO BOTTOMLOADING WATER DISPENSER AND ITS BEEN ON ALL NIGHT AND THE WATER IS WARM. I LOOKED ON THE BACK TO SEE IF THERE WAS A WAY TO TURN IT UP BUT FOUND NOTHING. PLEASE TELL ME WHAT TO DO. RNMALIN@ COMCAST.NET
Jan 06, 2012 | Primo 900172 1.0 Gallon Industrial Water...
GE refrigerator water dispenser not working
The water control valve has two side's, one controls the water to ice maker and the oher side controls the water dispenser. Most likely the water dispenser side has become defective and can no longer open the water valve to let water come to dispenser. You can test the voltage to the water dispenser side by useing a multi meter set for 120 volts and have someone press dispense water while watching the test meter. Use care not to be shocked while testing by not touching any bare probes or wires during testing. The coils can also be ohm test and both sides should be near to the equal amount of resistance. The location of the valves are listed as part 800 in this photo=> PSS26MSRASS Rear Parts Photo
Here is a Service Manual=> HERE
If you have any questions I will be here to answer them for you, Thanks Sea Breeze
Oct 27, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Only one winshied wiper spray works
Check the rubber hoses to the sprayers. If they are on the hood they can come unplugged when you open it. Have a friend work the sprayers as you watch for leaks. An old toothbrush can be used to clean spray nozzles by scrubbing over the hole.
Feb 13, 2011 | 2004 Chevrolet Cavalier
When printing, the top half of page prints normal... bottom half of page very faint...
Your ink cartridge has about 9 very small nozzles that spray ink to complete a letter the upper nozzles complete the upper half and the lower half is done by the lower nozzles. The lower nozzles are stopped or clogged up by dried up ink or the control resisters in the firing circuit are burned out. some times you can unclog the nozzles by soaking the lower part of the cartridge in hot water for a half hour and drying it well ,replace it in the carrier and try it again. However you will lose a lot of ink and it may be more prudent to replace the cartridge.
Dec 02, 2010 | HP inkjet 2280 Printer
Primo 900172 1.0 Gallon Industrial Water Dispenser Logo
698 people viewed this question
Top Primo Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Primo Kitchen Appliances - Other Expert? Answer questions, earn points and help others
