Question about Rowenta DG-980 Iron
What color connector wires connect to dg-980 power switch?
Power switch has 3 connectors, what color wires connect to which connector?
I have a power strip that keeps tripping its safety switch even though only one electric oven is plugged into it. What do I need to do?
did you try to plug directly in to a plug ?
maby your strip is defective or has a 10 amp overload protector this will trip with heating devices of your nature.
Oct 20, 2013 | Rowenta DG-980 Iron
How to bypass power switch wireing
What you will need to do is to take the switch out, and join the wires that are connected to it. If you do this the iron will be on as soon as you plug it in.
Mar 27, 2011 | Rowenta DG-980 Iron
What should I do ?
The old Rowenta DG-980 is a consumer grade machine but with commercial quality function and features. My gal who worked at a dry cleaners many years ago loves the DG-980. Here is the scoop on how to get it going if just cleaning it is all it needs (our used one had the same problem and I fixed it by doing the following:
Rowenta recommends that you use clear filtered drinking or bottled water only. I believe them because the system uses brass & aluminum throughout, so salts or acids would cause corrosion.
To clean the system totally, after each ironing session before I put it away, I remove the blue reservoir completely, and run the burst of steam several times until the boiler is empty, and red light indicates it is out of water. I shut the power off and unplug. Wait at least an hour or so, access the boiler tank plug on side & if it is cool to the touch, remove it using a coin (quarter), drain and flush the tank several times with the cleaning tube that came with unit or filtered/drinking bottled water several times over the kitchen sink. Finally, drain all the water completely out of the boiler (I leave the plug & cover off to making sure it is completely dry before putting everything back together, ready for the next time).
After several use cycles of the above should clear out the debris. My 1st experience with a used DG980 had exactly the same problem. P.S. before ironing the first article, use several bursts of steam away from the ironing board surface to clear out any standing water and debris that was is in the system. Hope this helps :O)
Aug 12, 2008 | Rowenta DG-980 Iron
I need a new chrome water stopper that screws onto the drainage hole at the side, where can i get this
I am in California, so I use the website below for DG-980 parts:
California Electric Service
(925) 827-1011
1170-G Burnett Avenue
Concord, CA 94520
http://www.californiaelectricservice.com/
Hope this helps, good luck and keep in touch.
Jul 06, 2008 | Rowenta DG-980 Iron
Stean escaping around cap
If you need a new sealing plug or parts, since I am in California, I use the website below for DG-980 parts:
(925) 827-1011
Concord, CA 94520
Jun 28, 2008 | Rowenta DG-980 Iron
Steam escaping around the cap
If new parts are needed, and I am in California, I use the website below for DG-980 parts:
(925) 827-1011
Concord, CA 94520
Does not steam. No pressure being built up.
I do not know if you did clarification request prior to ordering the new part.
Since I am in California, I use the website below for DG-980 parts:
(925) 827-1011
Concord, CA 94520
Apr 14, 2008 | Rowenta DG-980 Iron
Rowenta DG-980 Iron Logo
43 people viewed this question
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
