Question about Samsung LA22A450 22 in. LCD TV
No sound on la22a450
The sound has died - however the picture is OK
Have reset samsong la22a450 and still no channel
SAMSUNG LCD 22IN MODEL LA22 A45OC1LXL MOTHERBORD MY PH9030932645 CALLME
Jan 13, 2014 | Samsung LA22A450 22 in. LCD TV
Tv seems to be locked, cant access the program settings has it got a hotel lock?
hi,
u can remove the lock by fallowing settings.
1. press menu button and select channel and press enter.
2. select channel manager and press enter.
3. select channel lock then press enter.
4. select off and then press enter.
ok
Dec 15, 2010 | Samsung LA22A450 22 in. LCD TV
Picture turns off but sound is ok.
Tv turn now,pictures only flashes a few sec. than died,than have sound left only?Yes than ur tv have those 1 or 2 long board call the LCD inverter boards are dead.These 1 or 2 long LCD inverter boards job are to help the LCD picture screen panel to have a backlight to produce a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those long refurbishes 1 or 2 LCD inverter boards for the replacement.
Nov 21, 2010 | Digimate DGL32 32 in. LCD Television
My problem is there is no picture appeared but sound is ok.
Tv turn on now,have picture just flashes a few mins. than dies have sound left only?Yes,than those 1 or 2 long board call the LCD inverter boards is dead.These 1 or 2 long LCD inverter boards help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes 1 or 2 LCD inverter boards for the replacement.
Nov 12, 2010 | Televison & Video
I have a dell inspiron 1525 - when playing a dvd the picture and sound jumps and stalls
ok, well... i hate to say it, but it sounds like your dvd drive is about to give up, and die.... if its a new one, return it under warranty. if its an older one..., You might want to consider buying a new one.
Feb 23, 2010 | Dell Inspiron 1525 Notebook
Sony model KP-53V80 wont show picture or sound
YOU LOST VERTICAL DEFLECTION THIS WILL REQUIRE PARTS REPLACEMENT
Dec 25, 2009 | Sony KP-53V80 53" Rear Projection...
Picture lost sound still ok 42" LG
Since it is coming back after a union-like break, it is probably the inverter for the fluorescent backlight rather than the light itself; they can flicker and die but normally don't recover after a rest. The inverter may be a separate board in the unit and you should be able to recognize the right board due to its relationship to the backlight.
This kind of problem will not repair itself but decay further with time.
Sep 04, 2009 | LG 42LC2D 42 in. LCD HDTV
No picture
phillips 17in lcd no picture
Oct 29, 2006 | Philips 17PF9945 17 in. LCD HDTV
Samsung LA22A450 22 in. LCD TV Logo
19 people viewed this question
Jerry Greenberg
Jerry Greenberg
