Question about Kenwood KAC-7204 Car Audio Amplifier
Setting the sound from my amp
How to I set the correct sound levels
  • Kenwood Master
  • 637 Answers
I would need to know exactly what you are connecting this amplifier too. Is this going to run your subs? Your highs? Or your entire system? This amplifier may be used to run stereo and mono speaker components at the exact same time.
Posted on Nov 21, 2014
Hi My problem is that my Jamo 200 sub sounds very
Is everything hooked up correctly sounds off I know also could be your amp is going on you cold be a multitude of problems or one of the simple ones i stated
Oct 26, 2013 | Jamo SUB 200 Subwoofer
Hi, I have a Yamaha HTR - 6130 that seems O.K. until loud action scenes & explosions,then it shuts itself off.
There are two causes for this. One that there is a fault on the amp that is causing an overload circuit to trip and shut itself down. Or the settings of your speakers levels are wrong. So you are turning it up to hear the quiet parts of movies and therefore when louder sections come along your are driving the amp too much.
Some DVD discs that have THX on them have a sound set up on them. If you have one access the THX sound menu on the disc and adjust your speakers to produce the correct levels. If it does happen after that there's a fault.
By the way most of the George Lucas films (Star Wars) will have THX on them.
Aug 05, 2013 | Yamaha HTR-6130 Receiver
Do i need a amp to connect equalizer to car stereo
hello yes but you will get the same audio output as you would without using an amp iff you are using high watt speakers it would be best to give them a bit of power you may connect the amp in line with the equalizer hence giving them the boost make sure you set the sound levels correctly on your stereo first like ballance both speakers then you can ajust the equalizer with your amp remember 2 /500watt speakers in line will accur a 500 to 1000 watt amp nothing more or you will blow your sound system
goodluck
Mar 29, 2011 | GPS
I do not know how to set the settings on my new amp i have pioneer speakers but i don't want burst them how far can i turn up my amp
if the amp is for speakers, i would set it around +4, for boost, just have the head unit sound level on low before you turn your music on, it won't burst your speakers, your ears will give out way before your speakers does, if the amp is for sub woofer, I have it a little more than my speakers level, because i prefer more bass
Dec 10, 2010 | Kenwood Car Audio & Video
I have a volume problem. When I adjust the volume at a listening level, a high pitch sound can be heard then the volume turns low and goes back to the set level. It happens in every channel (Direct TV)....
No ,replacing speakers will not fix the problem these sets are very well know for Poor Solder and connection ,resolder signal,Audio,& power supply boards this should correct the problem and alot of future ones too.
Sep 16, 2009 | Mitsubishi WS-65711 65" Rear Projection...
No sound from my record turntable into my computer.
If you're certain there is no sound going out of the TT...
Setting the Pre-amp Switch
For increased flexibility of use, this turntable has an internal
stereo phono pre-amplifier. The Pre-amp Selector Switch
is located under the turntable platter, in the rear-center
(Fig. 1). If the system amplifier you are using has a PHONO
input, set the Pre-amp Selector Switch to the “OFF”
position. If your amplifier does not have a PHONO input,
set the Pre-amp Selector Switch to the “ON” position and
connect the turntable’s output cables to the AUX or other
high-level input on the amplifier (described later).
Turntable operates, but no sound at all
1. The stylus guard is still in place.
2. The tone arm Lift button is pressed in.
3. Amplifier controls set incorrectly: wrong input selected,
tape monitor on, speakers switched off, etc.
4. Check the stylus on phono cartridge for correct placement.
Refer to the instructions for replacing the stylus
on page 5.
Turntable operates, but no sound, or sound not loud
enough
1. If the turntable is connected to an AUX (high-level)
input: The Pre-amp Selector Switch may be set to the
“OFF” position (phono-input level).
2. The input gain of the amplified speaker or similar
device may be too low.
3. The stylus assembly may not be fully seated in the
cartridge body.
You could also isolate the problem to either the TT or the PC by trying the TT on some other sound device like a receiver. Make sure the PreAmp Selector switch is ON and plug the TT into any AUX, CD or TAPE input.
Sep 02, 2008 | Nakamichi AV-7 Receiver
Help setting up Yamaha RX-V461
Typically, only stereo inputs exist on any comsumer-grade receiver, and the actual decoding to 3, 4, 5, 6, and even 7.1 is done internal in the receiver. When a "placement" signal is detected by the receiver, the sound is routed to the correct speaker.Please refer to a user manual
..accordianman
May 01, 2008 | Denon AVR-4802 Receiver
Sound level unstable
Hi there!
You may have a button stuck either on the remote or on the TV itself. If this does not solve the problem, you may have to refer to a service technician. The IF Amp or the sound stage may be at fault. Good Luck, Regards, JUS004
Mar 25, 2008 | GE 32GT740 32" TV
Two amp
I don't know why you'd set the Peavey to 2 ohm to drive 8 ohm speakers??? My other thought is... I wonder if the phase is correct. try reversing one of the speaker wires Left or right side.
Geno
Feb 27, 2008 | Harman Kardon AVR 630 Receiver
Kenwood KAC-7204 Car Audio Amplifier Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
