My Digitel HD3300 set top box cannot get Channel 7
With recent re-tune, my Digitel HD3300 set top box cannot get Channel 7 or SBS
SOURCE: I have a centrex CTDV100
HI
I have a remote that stopped working could I purchase yours, alternatively I could email pages from my manual so you can try to have your box work again
Lindsay
Posted on Mar 15, 2009
SOURCE: LCD-32 TV.Can not tune in channel 7
81CM HD Sanyo LCD: Was still under warranty, took it recommended repair man and he simply tuned it at his shop!. Perfect when I connected it at home...Bob Tape
Posted on Jul 29, 2009
SOURCE: we cannot get our hdb841 to tune into our awa hd
Hi! I believe you have some concern on how to get good picture on your hd tv. I will be more than glad to assist u.. on your teac hdb841- there is a port connection - ant in, you have to connect the ant cable from your off the air tv antena to the ANT IN of the Teac HDB841. then on the back of your Teac HDB841, you have several output connection there like component, coax, s-video, rca and hdmi. since u have the hdtv u need to use the hdmi or the component cable whiich is the red blue and green then access the menu of the teac hdb841 and do a scan for the local channels.. ur tv should tune in to hdmi if u use hdmi cable or component if u use the red blue and green.. i hope this will fix the problem..
Posted on Aug 24, 2009
SOURCE: cannot tune channels eg channel
i had same prob untill i pluged it into a wall antana went auto setup australia DTV only and i got 7, 73 ,70, 71 , 90, 99,9,10,1,11, when pluged into a portable tv antana i lost 7, 73 ,70, 71 so that how i fixed my problem
Posted on Jan 08, 2011
  • 115 Answers
SOURCE: i need to tune my
I have no idea what an antennae connection is. I assume you are talking about a Coaxial cable converter (large box that connects in line on the cable input). If this is the case, the box is override either channel 3 or 4. It either has a switch to pick which one of these to use or it is written on the box which one it uses.
If you are using a VGA connection (3 pins with 1 yellow, 1 white, and 1 red connector), then you have to find the AV channel. Every TV has one, unless it is like 4 decades old. If the TV is a few decades old, it may not have a channel called "AV" or "AUX". For example my dad's 25 year old TV uses 91 as the AUX channel. It is common for channels in the 90's to be used for this or channel 0. Best to just turn all the manually add/remove channels while the box is on. Then you can spot the right channel and add it to the listings.
Posted on May 09, 2011
I'm looking for the code for my digital plus hd3300 set top box to program a universal remote mine went missing
Use code search to find something applicable to your STB. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not store all possible codes.
Jul 21, 2016 | Televison & Video
Will this model receive 7flix and other new channels? If not can we get a set box to get them
if your tv is already receiving digital stations the it will receive 7 flix
If you are already using a set top box it will get 7 flix and all the channel 9 station as well
all you have to do is use the remote to get the on screen menu up, (press the menu button) --navigate around until you get the auto tune in channel selection auto or manual---select auto tune and let it go and all the extra channels will be programmed in
Mar 10, 2016 | Televison & Video
CANNOT GET PHILIPS DVDR3305 TO RECORD ON PANASONIC TV.TX-L37D25B WHILE WATCHING ANOTHER CHANNEL?.
What is your source? Since the DVDR3305 has an analog PAL tuner and most TV stations are broadcasting in digital, you probably have some sort of set top box connected to the recorder. If you change the channel on the set top box, you will record the program on the new channel. If you are recording PAL and your TV has a PAL tuner, you should be able to just record one show while watching another with the DVDR3305 daisy-chained to the TV. Just make sure to change the TV channel not the channel on the DVDR3305.
If your TV has a digital tuner, you can split the signal before the set-top box to record one channel and watch another. (Note: basic splitters will cause some extra loss of signal and may reduce a digital signal below the threshold needed to tune in the signal. An amplified splitter can avoid this - when the amplifier is working properly.) Otherwise, you need a second set-top box (or a dual tuner set-top box).
On my set-up with an aerial antenna, I would put the splitter between the wall jack and the electronics. The incoming cable goes to the splitter, then cable 1 goes to the TV. Cable 2 goes to the set-top box. Tune the set-top box to the channel to record and check the settings with the TV set to the DVD source. (DVD set to record on Tuner (and the specific channel of the set-top box output) or front s-video or EXT1 or EXT2.) Then change the TV back to the TV source and change to the channel for the second program.
The manual for the DVDR3305 is available from Philips. The link to the manual is http://download.p4c.philips.com/files/d/dvdr3305_05/dvdr3305_05_dfu_eng.pdf .
I hope this helps.
(I actually use an A/B switch and do not try to watch a second program on the TV connected to the DVD recorder. However, most of my recordings are for time-shifting of programs that air when I can't watch any TV program.)
Apr 29, 2012 | Televison & Video
I just bought a teac HDB849 set top box and when I do the automatic channel search I only get 9 digital, GO and Gem. No other channels are found. when I manually key in 72 for 7two or any others I get...
I find that with my HDB849 I have to be very carefull with the positioning of the aerial/rabbit ears to get all the channels to (ABC, 7, 9, 10, SBS and their sub cahnnels) to recieve them at all. Also once you get all the channels it is prone to digitization or pixilation at times due to bad weather/very overcast days.
Try the Teac.com.au for a firmware upgrade as this also solved not being able to view avis & images, listen to mp3's etc.
Overall the majority of reviews say the HDB849 is to be avoided.
Once set up correctly through trial and error and an absolute shitload of patience and re-tuning it seems to operate fine. Just pray you do not get a power outage or you have to start all over again.
Last point, try the teac 1300 number in Australia (or relevent country) and harras them for info whilst trying to stay calm and nice with the unlucky "tech support" person
Feb 08, 2011 | Televison & Video
Cannot tune channels eg channel 9 10 7 only gets sbs abc nu-tec mod NUE 1958 18.5 " lcd
Jan 06, 2011 | Televison & Video
No sbs didital channel coming up
You first need to ensure if you have any SBS digital signals in your area. I take it that you are in Australia. Go to this website for more info. If this is not what you are looking for let me know.
http://www20.sbs.com.au/transmissions/
http://www20.sbs.com.au/transmissions/index.php?pid=1
If you have received SBS signals before and now you aren't there may be a setting on your tv that changed the component input from SBS to something else. Check to make sure the component inputs that the signal is coming in on is selected on the tv. I sure hope this helps you. If not, give me a little more info and maybe I can help a little more.
Mar 08, 2010 | Vizio VX37L Television
Turn on goes blue then turns off
The most common reason for a TV to display a blue screen with no picture is because the source device has not been set to the proper mode.
If you are using a cable or satellite set-top box, ensure that it is turned on and set to an active station. If the set-top box is connected to the television using a coaxial cable, then the television should be set to Channel 3 or 4 to receive the signal.
If you have are using a VCR that is turned on, but not playing a tape and not tuned to a receivable channel, then a blue screen will be displayed on the TV. To resolve this, turn off the VCR or tune it to a receivable channel. If a cable or satellite set-top box is connected to the VCR using a coaxial cable, then the VCR should normally be set to Channel 3 or 4 to receive the signal.
If the blue screen is not because of a connected VCR or set-top box, the TV may require service.
Sep 22, 2009 | Sony KP-57WS500 57" Rear Projection...
Jul 29, 2009 | Sanyo Televison & Video
VCR will not record with new digital cable box
The short and simple solution is to tune the VCR to the channel that the cable box is set to (4), and then tune teh TV to the VCR's output channel (3). If you do this you should be able to see the Cable channel through the VCR tuner and then record. Any other solution would require figuring out how to set both the VCR and the cable box to the same channel, but it sounds as if you have ruled out any possibility of being able to do that.
Feb 18, 2009 | Emerson EWV403 VHS VCR
Tuning channels for a Centrex DVB - T
what codes do i use for my sonyo tv. i have a universal remote
Jun 17, 2008 | Televison & Video
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
