Question about Dehumidifiers
Touch point dehumidifier
I need the manual
What is wrong with a Westpointe dehumidifier when it stops removing water and displays P1? It will run this way for hours and kick in and work briefly once in a while on continuous.
Usually the P1 error indicates that dehumidifier needs to be defrosted. The unit has detected ice build-up on the condenser coils.
Unplug the dehumidifier for several hours. Then plug it back in. If the problem recurs, check that the fan that blows air across the coils is working properly. Make sure that the room is not colder than the operating range of the dehumidifier. If the problems continues to occur, you may have a refrigerant leak in the system. That will require a service call to repair the dehumidifier.
If the unit is under warranty, contact Westpointe. The manual I have for a Westpointe 65 PT dehumidifier, https://www.appliancefactoryparts.com/content/pdfs/136333-1.pdf, indicates the unit is covered through year 5 after purchase for a refrigerant system. For Warranty service, the contact point is Midea Consumer Service at 1-866-646-4332. If the unit is not under warranty, consider whether to replace the dehumidifier.
I hope this helps.
(I have seen a dehumidifier develop a refrigerant leak. It constantly froze before the leak was repaired and the refrigerant topped off.)
May 15, 2017 | Dehumidifiers
Dehumidifier service manual
Good Afternoon Friend,
I understand you are looking for a service manual for your Frigidaire dehumidifier. Typically, there are not service manuals out there for appliances. I suggest contacting the manufacturer directly. They will be able to point you in the right direction. Hope this is helpful.
-Best Regards-
WP
Jul 01, 2014 | Frigidaire Dehumidifiers
Do you have filters for Dehumidifiers
Fixya doesnt sell anything, they answer questions.
Jun 24, 2014 | Dehumidifiers
Vibration Noise Fix
Place the dehumidifier feet on foam or rubber vibration absorbing pads.
Touch all sides of the cabinet with the compressor running to see if your touch will dampen the noise. Once the noisy area is identified check that the fasteners are all in place and tight. Sometimes loostening and retightening a number of fasterners around the noisy area will cure this problem.
Apr 30, 2014 | Honeywell DR90A1000 TrueDRY Dehumidifier...
Direct drain
2 possibilities: #1The port that you plugged the hose onto need to be drilled so the water can come out and enter the hose. #2 The hose cannot be higher at ANY point than the bucket. Physics rules apply and the water will always fill the lowest point. Keep the hose low or raise the dehumidifier up.
Jan 06, 2014 | Danby DDR583R Dehumidifier
Cannot set humidity level to anything other than 50.
Is it reading the room humidity, rather than showing the set point? Check the manual.
Apr 21, 2012 | Soleus DP14503 Dehumidifier
My dehumidifier does not seem to be working properly. I can't find the manual to tell me what the settings should be. Would appreciate your help. It is a DeLonghi DE400P. Thanks Shirley
What is the specific problem? Is no water being collected by the dehumidifier or do you have another issue?
Make sure that the dehumidifier is in a room in the operating temperature range (at or above 44 degrees F). Make sure that the room door and windows are closed and that the room is not larger than 2200 square feet. Make sure that the collection bucket not full and is properly seated in the dehumidifier. Check and clean the air filter on the dehumidifier. (Vacuum the filter or rinse under running water three times. Then wait until dry to replace it in the dehumidifier.) Look at the coils of the dehumidifier. If you have ice on the coils, defrost the unit (turn off, unplug and wait for it to melt). If the ice reforms quickly, you may have a leak in the coolant system. Then the unit needs repair.
Next make sure that you have good air flow around the dehumidifier and that the desired humidity set point is lower than the humidity of the room.
Retrevo has the manual available: http://www.retrevo.com/support/Delonghi-DE400P-Heating-Cooling-and-Air-manual/id/19269bh037/t/2/ . You will need to enter a code to download the PDF.
I hope this helps.
Aug 09, 2011 | DeLonghi Dehumidifiers
My new LG "ld450eal" DeHumidifier
The switch that says 'Bucket is full' is not adjusted properly.
It will need to be adjusted, normally a screw driver or pliers,
so that when its empty the switch is not made or the contacts
are open.
If it is in adjustment properly, then the switch is bad and needs
replacing.
Before you replace it, check to make sure the wires leading to it
are not touching, it may be sending a signal meaning 'full' by
electricaly touching each other at the switch.
Feb 25, 2011 | LG Dehumidifiers
I have a dehumidifier (Emerson I believe - sorry don't have the model # right now) in a very cool basement (55-60 degeres). When I turn it on the coil quickly frosts up as expected and a while later the...
Dehumdifiers work by cooling a coil below the dew point temperature of the ambient air. When this happens frost or water will form on the coil. Most room dehumidifiers work with the room temperature above 65 deg F. It works well when the temperature of the room is 65 deg F or higher. But when the temp is below 65, it won't work because the coil does not reach the dew point.
There are cold temperature dehumidifiers that are designed to work in colder environments such as basements. They can work in a environment as cold as 40 deg F. Check your owners manual to see what type of humidifier you have to see what is the minimum operating temperature for you unit. Hope this helps you.
Dec 03, 2010 | Dehumidifiers
Dehumidifiers Logo
48 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
