Question about Caterpillar Backhoe Tractor
It would not stop running.
I ended up having to unhook the battery.
    New Friend:
  • 3 Answers
Could be a problem with the fuel shut off solenoid
Posted on Apr 25, 2014
Why does starter run with key off
What kind of vehicle are you talking about?
Jan 29, 2015 | Cars & Trucks
How do i test a stator on a 2009 skidoo tundra 300
Fire it up, then unhook battery while it's running.
If it stops, your stator needs to be replaced.
If it still runs whit out battery connected, you can test the stator by connecting your meter to the battery cables.
Dec 25, 2014 | Motorcycles
Blade stops while mower still runs
bad battery or bad voltage regultor test how much voltage at pos battery cable while runnig unhook it from battery for test 12.5 to 13.5 volts
Sep 10, 2014 | Garden
Is there a computer rest button on a 2011 dodge avenger
no but if you leave the key on and unhook the battery then hold down either the horn or breaks to get the remaining charge all cars store even after the battery is unhooked to drain away when either the break lights stop lighting up or the horn stops blowing leave it unhooked with the key on for ten to fifteen min then take the key out and hook the battery back up that should reset it
Mar 19, 2013 | 2011 Dodge Avenger Express
My samsung frontload washer stopped steaming at the end of cycle
Is your hot water valve open all the way? If you run the washer on a hot cycle only, does it fill up?
Nov 17, 2011 | Washing Machines
Going down the road runs great then starts loosing charge sit awhile and push off runs great. put new altenater on it i can reve motor up if running lights and starts running good
Either have a bad battery, sometimes they go bad and the symptom is a "self" discharge that will run it down in a few days..
or.
You have something inside the car that's running it down.
The way to check is to unhook the battery for the time that its down and see if the battery is dead when you return. If the battery goes flat unhooked, you have a bad battery. If the battey holds its charge while unhooked you have a drain from the car.
Your car I think was bad about one of the cooling fan relays sticking "on". Just something to be aware of.
Jun 06, 2011 | 1984 Porsche 944
I have a 95 cougar an the abs light came on an the motor won't stop runnig unless i unhook the battery. can i just unhook something an keep driving it?
IT IS IN THE POWER DISTRIBUTION BLOCK NEAR THE BATTERY. IF THE RELAYS ARE NOT LABELED, YOU WILL HAVE TO UNPLUG THEM ONE AT A TIME TO SEE WHICH ONE MAKES IT STOP. USUALLY THOSE RELAYS ARE FAIRLY CHEAP.
Jan 05, 2011 | 1995 Mercury Cougar
Battery not chargining andwhile runing if take the battery cable off the car stops runing i also put new alternator in it the car is only runing off the battery im also only getting 11 to 12 volts right...
To get an accurate voltage reading on the alternator, measure across the battery while the engine is running at 3000RPM. It should read between 13.5 and 14.5. If it's low then shut the car off and look on the back of the alternator for a large red wire ( it should be on a terminal marked B+) and make sure the terminal is clean and shiny with no trace of green gunk (corrosion). Clean up the small blue wire too. Do the same with both battery cables. Check the tension on the drive belt. It should only move about 1/2 inch when you push down on it. Retest for voltage. If it's still low then you have probably damaged the alternator when you unhooked the battery. NEVER unhook the battery cables on a VW when it's running. Hope this helps.
Nov 15, 2010 | 1992 Volkswagen Passat
Fan motor will not stop running
you have abad blower motor resistor, replace that and your problem is solved, it located under the dash on heater box on pass/side,
Jan 07, 2010 | 2001 Pontiac Bonneville
Caterpillar Backhoe Tractor Logo
105 people viewed this question
Top Caterpillar Toys Experts
fordexpert
DROPNDEAL
DROPNDEAL
Are you a Caterpillar Toy Expert? Answer questions, earn points and help others
