Question about Garden
RYOBI EX26 WILL NOT START
NEW RYOBI EX26 WILL NOT START - ONLY 2 WEEKS OLD.
  • 1 more comment
  • speedyskilz May 11, 2010
    is it a teimmer?
  • Jim Parker
    Jim Parker May 11, 2010
    Is it getting fire (spark)?
    Jim
  • Stacy Claypool May 11, 2010
    have you replaced the spark plug with a new one yet, also have you cleaned the air filter????
5 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: Ryobi EX26 will not start.
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
Posted on May 31, 2010
  • 59 Answers
SOURCE: New Ryobi EX26 Edger started twice and won't now.
turn the high mix screw just a little to the left it will have a letter H on one screw and L on the other
Posted on Jun 23, 2009
#1 Taper
  • 1041 Answers
SOURCE: Ryobi EX26 dies when hot, won't start, then when cool starts
This sounnds too good to be true, but believe it!
The next time you run the trimmer and it starts to die, loosen the gas cap. It should start to run again. This means that the gas cap is clogged. Either clear the gas cap or buy a new one. This should solve the problem.
If you need further assistance, just let me know.
Jim
Posted on Jul 03, 2009
jabbad
  • 17 Answers
SOURCE: can't locate H and L
you probably have the type that requires a special tool, poulon engines are known to need one. check with your local Lawn mower repair shop, they are the only ones that will have one
Posted on Sep 13, 2010
Can't locate H and L screws to tune Ryobi EX26. There's a screwdriver slot cut in the plastic cover, but screws have no slots, or are capped.
Sep 12, 2010 | Garden
Ryobi EX26 will not start. I replaced spark plug and primer bulb. Even used starting fluid. It will fire up for a few seconds and then die. Help please!
they were in/out.
May 31, 2010 | Garden
Ryobi blower will not start unless primed by
If it is under 2 years old, I would take it to a warranty repair center. The carburetor have been giving some problems so they have needed to be replaced because they are sub standard quality.
Sep 28, 2009 | Ryobi Backpack Blower 25.4cc
Jim
Jun 30, 2009 | Ryobi 15" Electric Factory Reconditioned...
Jun 23, 2009 | Ryobi 15" Electric Factory Reconditioned...
Ryobi PCN 4040 will not start up
When I was going to college I worked at a tool rental center and learned may tricks about tools. At this rental center chainsaws were seasonal thus sat in the warehouse probably as in your situation. Well one is supposed to store a chainsaw without any fuel and discard any old fuel mix because it will not keep. To easily start a saw that was in storage we would install a new spark plug, add fresh fuel mix and spray carburetor cleaner directly into the carbureter to get it started. Once started fresh fuel would be drawn into the engine from the tank and keep running. If you forgot to drain the old fuel, do it now and use the trick above. For best results, always use a fresh plug. Enjoy
Dec 15, 2008 | Ryobi Factory Reconditioned 18" 40cc...
Garden Logo
1,392 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
