Question about Cuisinart EM-200 Espresso Machine
My cuisinart em200 lost it's ability for programing a few weeks ago. Then, it just never stopped the flow of coffee unitl I would turn it off. Now it only makes a small amount then starts beeping
  • mama22qts
    mama22qts Jun 22, 2012
    It is 2012. I am having the same problem as someone was having in 2009?!? Seriously? No fix?
Same thing happened to us. The problem was that we used too fine coffee a couples of time.
The coffee was so much in powder that both filters, one and two cups, just jamed tight..
Use the small needle to clean the small hole at the buttom of each filter and then use the machine without coffee for four or five times and it will come just new.
Posted on Sep 10, 2009
  • 2 more comments
  • NoLatte Feb 02, 2011
    I tried running it with no coffee
  • Ecalan Nov 02, 2011
    I had exactly the same problem. I also tried with no coffee or filter. now, after the same progression as the first poster, it only runs for very short pull then flashes as if there is an error. Any real solutions?
  • yvahja Jul 20, 2012
    having the same problem as ecalan, any suggestions ?
  • John Nezic Dec 25, 2012
    Descale Descale Descale 2 to 1 vinigar then water.
My cuisinart em200 will not turn on.
Seems like this model has alot of issues based on what I am reading on the internet.
First thing you should do is make sure that your plug is working by moving your Cuisinart to a plug that you know is working or plugging something in that same plug that runs, so you know the breaker or GMI switch isn't tripped. Next, contact Cuisinart for assistance. I located the manual and it says nothing about troubleshooting issues like this. Contact information is included in the manual though, so here it is: https://www.cuisinart.com/share/pdf/manuals/em-200.pdf
Hope this helps.
Apr 29, 2018 | Cuisinart Coffee Makers & Espresso...
Espresso not hot enough
CoffeeGeek - Espresso: Espresso Machines, Need help with a ...
coffeegeek.com > Discussions > Espresso > Machines
Feb 1, 2010 - 10 posts - ‎4 authors Well, I'm throwing in the towel...or my Cuisinart EM-200 actually. ... coffee and it's not hot enough to even make me pull my finger out of my flat, ... Espresso Machines, Breville BES840XL Owner ...
Aug 20, 2013
Espresso Machines, Cuisinart EM-200 ...
Nov 14, 2011
More results from coffeegeek.com
Cuisinart EM-200 Espresso Machine Coffee not hot ... - Fixya
www.fixya.com > ... > EM > Cuisinart EM-200 Espresso Machine
Cuisinart EM-200 Espresso Machine, coffee not hot related issues. ... ...to "extra hot" If still not hot enough, try zapping your coffee for a few moments in the ...
Oct 29, 2015 | Cuisinart EM200 Stainless Steel Espresso...
My em 200 cuisinart espresso maker stops brewing and beeps
My em 200 Cuisinart express
maker start and stop and beeps what I do
Jan 14, 2013 | Cuisinart EM-200 Espresso Machine
The program light won't stop blinking
Same here. I'm dead in the water. This started happening a few weeks ago and with patience and luck and different combos of buttons I'd get it to stop and I was able to brew. Today it just stopped completely. The program light either blinks constantly or stays lit constantly, but I cannot brew coffee. I see lots of people online with this problem, but have yet to see a solution.
Dec 08, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee maker shuts off too soon after brewing.
Hello FloydBob, The Cuisinart DCC-1200 has the ability to program the auto-off function that keeps your coffee warmer plate on after brewing is complete.
The unit lets you select the time increments from zero up to 4 hours.
See page 6 of the attached manual for the full instructions for reprogramming the coffee maker.
To program the Variable Auto Off:
1. Turn the FUNCTION KNOB to the “Auto Off”
position. Press and hold the “Hour” button
for 2 seconds. The clock display will start
blinking.
2. Program the coffeemaker to shut off from
zero to four hours after brew cycle is
finished by using the “Hour” and “Minute”
push-buttons.
I figured you might also like to have a complete instruction/owners manual so you can have access for any other questions you might have about your coffee maker, in the future.
http://www.cuisinart.com/share/pdf/manuals/dcc-1200.pdf
I hope you find this Very Helpful and best regards!
Nov 09, 2009 | Cuisinart Brew Central DCC-1200W, 12-Cup...
Won't finish brewing
We were having the same problem of it quitting the brew cycle about 1/2 way through. We put a mixture of 5 cups vinegar & 5 cups water through followed by a pot of just water and now it works like new. The vineagr must clean some sort of built in sensor.
May 30, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Brews most of the water than stops and shuts itself off
Cuisinart Coffeemaker Decalcification Process
Run 2 cups distilled white vinegar and 2 cups water through the system - brew it like it was regular coffee. Then run plain water through the coffemaker to rinse the vinegar out and make sure the decalcification was successful. Repeat as needed. Don't forget to remove the charcoal water filters first.
-Tha Mp3 Doctor
Aug 27, 2008 | Cuisinart DCC-1200 Coffee Maker
Coffee pot
As long ago as you posted this, the unit has a 3-year warranty - call Cuisinart and redeem it.
Jul 24, 2008 | Cuisinart Thermal DGB-600 Grinder
Cuisinart EM-200 Espresso Machine Logo
1,940 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Marvin
Marvin
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
