Question about Copco Hydra Reusable Water Bottle, 16.9oz: Hydra Reusable Water Bottle Blue
Copco water bottle caps crack and break; need a replacement cap
Copco water bottles have caps that break. Someone needs to make a replacement cap.
My Chana Star bakkie 1.3 blows water out expansion bottle and then starts to get hot after about 25 km
Sounds like a cracked head or bad head gasket. Have it checked by a mechanic.
Oct 24, 2017 | Cars & Trucks
Whats causes coolant to stay in reservoir bottle and not return to coolant lines?
I would be looking at cracks in the hose to the reservoir to the radiator . Look for loose fittings. Check that if the hose is in the top of the reservoir in the filler cap that the pick up line is to the bottom of the bottle and not cracked . What you have is air getting into the line when the vacuum from a cooling engine starts to work and that prevents water being sucked back
Apr 28, 2014 | 2003 Dodge Caravan
Bmw water leak
First remove and check the bottle for cracks in the bottom and sides . Have a coolant system pressure test done and have a compression test done for head gasket and cracks. Have the radiator cap tested for correct operation
Feb 14, 2014 | BMW X3 Series Cars & Trucks
Water/coolant is being pushed in the expansion bottle,
Sorry almost certainly your head Gasket, sound like a break between a cylinder and the water jacket - hence the bubbles.
Jan 30, 2014 | Cars & Trucks
3 months ago i changed to a new radiator after going trough water bottle after water bottle.Things were fine.Now im over heating again with the problem being the pressure cap of the water bottle apparently...
There is no water bottle
All vehicles have a coolant recovery container
When the vehicle warms up ,some coolant goes
past the radiator cap into it
At night when cool, the radiator draws back what
it needs
Been that way for 50 years
That container isn't under pressure as you can see
You have to diagnose the engine overheating issue
You have a new radiator,I would assume new thermostat
& rad cap,so continue on
It is very old, so a head gasket wouldn't be a supprise
Aug 02, 2011 | 1990 Jeep Cherokee Limited
I have a 1996 Honda civic, it spits out water at the radiator after running for 10 minutes. What can I do?
If the radiator is leaking, put a bottle of radiator stop leak in it,fill it up the rest of the way with water, tighten cap, and run in idle for 15 to 30 minutes. If the leak is severe or one bottle doesn't work, use two bottles of stop leak and run for 35 minutes.
If it's the radiator cap that's leaking, replace the cap with a new one. Also check to make sure there are no loose cooling hoses.
Safety first: Use extreme caution to never remove the radiator cap when the engine is hot, severe burns from escaping hot water could result.
May 25, 2010 | 1990 Honda Accord
Overheating on a 1990 jeep lardeo new waterpump
Assuming you dont have a blown head gasket the most likely thing is a clogged radiator. Lee
Sep 29, 2009 | 1990 Jeep Cherokee Limited
Mi carro vw jetta se calienta y ya le cambie
remove upper hose on coolant bottle hold over bottle with cap off have someone in car hold rpms at 3000 if no coolant comes out you need a water pump
Jul 26, 2009 | 1998 Volkswagen Jetta
Copco Hydra Reusable Water Bottle, 16.9oz: Hydra Reusable Water Bottle Blue Logo
200 people viewed this question
Top Copco Dishwashers Experts
Are you a Copco Dishwasher Expert? Answer questions, earn points and help others
