Question about Garmin Alpha 100 handheld only
Garmin alpha shuts off when plugger into car charger
Garmin alpha does not charge when plugged into car charger. The alpha tries to turn off.
  • 7 Answers
SOURCE: Garmin car charger
There are thee ways to charge the Garmin 750, 1: thru a car cord that plugs into the base that your unit mounts on. 2. Thru an AC charger. 3: thru the USB port on the Garmin unit itself. In your case the car cord plugs into the base that mounts your unit to the window. If that is not working, check that you are getting power from your car receptical. Check by plugging your Phone in or buying an adapter at Radio Shack that checks it. Also check the plug that goes into your car recepticle. Your manual tells how to check the fuse that is located in the end of the plug. If neither of these work your mount connection is bad. Hope this helps
Posted on Sep 15, 2008
SOURCE: Garmin 750 - 90 days old
it's battery problem
make sure to charge it
Posted on Dec 25, 2008
ginko
  • 19396 Answers
SOURCE: Garmin Nuvi 255 won't charge with the car charger.
You may need to replace the battery.
The video on the link below shows how to replace the battery in a Garmin Nuvi:
How To Change The Battery On A Garmin Nuvi 760
Posted on Apr 10, 2009
bob_computer
  • 3153 Answers
SOURCE: Garmin C530 won't power up. I fully discharged
How old is it and does it get quite a bit of use
If so then consider replaceing the battery
Ebay has a good selection from a wide range of reputablesellers and very good prices
Check Here
Posted on Aug 26, 2009
SOURCE: How to charge Garmin 755t
I had the same problem with mine & it was only 6 months old. The battery needs to be replaced. This is a good site that shows you how to change the battery & you can order the new battery from them as well. http://www.newpower99.com/
Posted on Apr 24, 2010
I've been using after market chargers in car and on ac. They worked fine for a long time. Now, my Garmin NUVI 660 seems to turn off (goes into "charge mode" or something) when I plug my car charger into...
Yes, many aftermarket chargers are not wired the same as a Garmin charger and will cause your Nuvi to think it's connected to a PC. What happened to the original charger that plugged into the cradle (the part your Nuvi snaps into?)
Please see this link:
http://www.sharc.net/gps_charger_repair.htm
- Jim
Jul 15, 2010 | Garmin Nuvi 660 GPS Receiver
Turn on shuts right off already tried to reset?
The problem is either a dead battery - and the only way to know is to charge it for sure - in a wall charger. Many cell phone chargers etc will work- other wise - you must charge it in the car charger - this takes at least 20 minutes.
If your battery will not charge - I suggest you send it to Garmin for servicing.
Also a new Garmin 285WT is on sale at Tiger Direct dot com.
Gary
May 06, 2010 | Garmin nuvi 200W GPS Receiver
Garmin charger has red light on and wont charge
mine too. Its brand new. Worked OK in my car for a couple of small trips, and unfortunately I didn't notice the lights status on the charger. Then lost satellite reception (not being charged at the time). Now red light on car charger and kept turning off/won't turn on. I have an old mains charger from garmin 660 which has a malfunctioning antenna and this 1490 was meant to replace ! Its charging now anddoes turn on, but no answer yet I'm afraid. I intend to register it with garmin and log a call with them. Also looking at the manual, it says there is a fuse in the head of the charger which should be checked. I haven't done this yet, but not sure if red light would be on if fuse had blown ?
Mar 13, 2010 | Garmin nuvi 255W GPS Receiver
Garmin 200 won't turn on, flashes "Garmin" screen when plugged in
I connected the unit to the car charger instead of the USB charger and then held down the reset for 10-15 seconds, after which the system would show the computer connection on the charger and then boot up when not on the charger.
Aug 04, 2009 | Garmin nuvi 200W GPS Receiver
My new garmin 255w is not charging
I had the same problem. The plug wasn't sitting right in the charger hole.
Jun 25, 2009 | Garmin nuvi 255W GPS Receiver
Garmin died and will not turn on
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Mar 12, 2009 | Garmin StreetPilot C330 GPS Receiver
Dead Garmin c550
had same exact problem. my unit would come on for a minute and then go black. if you take the silver ring around the face you will see the four screws to take the unit apart if you do have to replace the battery. however first try hitting the reset button on the right side of the unit. remember the cover needs to be off. i hit the reset and my unit powered on with no problems
Oct 31, 2008 | Garmin StreetPilot c550 GPS Receiver
Internal battery won't charge
Common issue. Steps to troubleshoot/solve:
1. Pull off face, press reset tab.
2. If unit wont turn on or if turns off immediately, connect to home computer using mini usb on side of gps (any usb cord that fits will do). This will charge the internal gps battery, which is discharged.
3. You will not be able to see the gps charge indicator while the usb cord is plugged into the unit. To check charge level, disconnect it, turn it on, and note the large "battery" icon.
4 Do you have a dead internal battery? If the gps holds a charge from your computer usb port, you don't.
5. If you have a dead battery, Google DIY replacement. With some soldering it can done for $15 total.
6. If you don't have a dead battery, the issue is charging from the cigarette lighter socket. Your car socket may have blown a fuse (check car manual). Your charger unit may have blown a fuse (unscrew the tip, check fuse inside). Also, some car sockets don't work when the ignition is off. Test yours.
7. There is a good chance the connection of the charger wire to the gps cradle is the problem. Fiddle with that. Replacement cradles are available for the c340 at about $25.
8. If your unit is not charging from the cradle/socket, buy a 12v usb cord. Plug into socket and into usb port of the gps. This is a workaround or alternative to buying a new cradle.
9. IMPORTANT: observe the "battery" icon while driving, esp. if you have doubts about charging. Basically, if you can see the icon, you're not connected to an outside (car or computer) power source. That is, if you can see the battery-charge indication, it means your battery is currently discharging and unless you get another power source to work it will be dead in a few hours.
Aug 27, 2007 | Garmin StreetPilot c340 GPS Receiver
Garmin Alpha 100 handheld only Logo
24 people viewed this question
Top Garmin Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Garmin Kitchen Range Expert? Answer questions, earn points and help others
