Question about Nakajima AE-740 Typewriter
Swintec 2416DM no file memory
3 beeps on power up
Typewriter beeps incessantly, does not respond to input
First try a little WD40 on the shaft thatb the carrier slides on and look for debris in the carrier movement area,
DickyO
Nov 13, 2013 | Swintec 7000 Typewriter
Hi i just get 3 beeps gap then 3 again contuulsy
The beeps you hear are BIOS Beep Codes.
The computers way of telling you something is wrong, and an area to look into for it.
3 beeps, pause, 3 beeps, pause,......
The Gigabyte GA-6BX7 mobo, (MOtherBOard) has an Award BIOS.
3 continuous beeps indicate a Ram Memory failure.
1) Even if the ram memory modules seem to be seated, and locked in, remove, and reinstall.
2) Before you reinstall, it would behoove you to clean the gold plated contact pins, on the bottom of the ram memory modules, with a pencil eraser.
Doesn't take very much corrosion to make a bad contact. (In fact after you clean with the eraser it may look as though you've done nothing at all. You have) Gold makes an excellent conductor, but can corrode.
http://en.wikipedia.org/wiki/File:SDR_SDRAM-1.jpg
(You can click on the photo to enlarge. You can enlarge twice)
Use air to remove the eraser dust.
If you have a can of compressed air for computers available, use it.
If not air pressure from your mouth will be sufficient.
Reinstall the Ram Memory module/s.
3) Still no?
Computer off, unplugged from power, observe Anti-Static Precautions.
If you have more than 1 Ram Memory module, remove all of them.
Lay the Ram Memory module that was in Slot 1 on a wooden surface.
(Ram memory slot closest to the Processor)
Use one of the other Ram Memory modules, or the other Ram Memory module, and insert it into Slot 1.
Plug the computer back into power, WAIT 1 minute, turn the computer on.
4) Still no?
Turn the computer off, (Hold the Power On button in for a count of 10 seconds), unplug from power.
Remove the Ram Memory module, use the other one, or another one.
Repeat the steps above.
Post in a Comment as to your findings.
Oct 29, 2010 | Gigabyte GA-6BX7 Motherboard
How do I set the margins on my Swintec 2416DM typewriter? Also, how do I change impressions control?
Go to the margin you wish to change, touch don't hold the MAR REL key, space or backspace to the desired location, press R. or L. margin key.
I believe the impression control is a slide switch on the L. side of the keyboard.
DickyO
Oct 05, 2010 | Swintec 7040 Typewriter
What is the beep code asus p5ntws
AMI (American Megatrends International) BIOS Beep Codes.
AMI BIOS uses beeps of the same length and pitch. The error is displayed as a number of beeps. For example, 4 beeps indicated a timer failure.
BEEP CODE MEANING POSSIBLE CAUSE
1 Beep (No video) Memory refresh failure Bad memory
2 Beeps Memory parity error Bad memory
3 Beeps Base 64K mem failure Bad memory
4 Beeps Timer not operational Bad motherboard
5 Beeps Processor error Bad processor
6 Beeps 8042 Gate A20 failure Bad CPU or Motherboard
7 Beeps Processor exception Bad processor
8 Beeps Video memory error Bad video card or memory
9 Beeps ROM checksum error Bad BIOS
10 Beeps CMOS checksum error Bad motherboard
11 Beeps Cache memory bad Bad CPU or motherboard
Award BIOS Beep Codes
Award BIOS uses beeps of varying duration. A long beep will typically last for 2 seconds while a short beep will last only 1 second. Award BIOS also uses beeps of different frequency to indicate critical errors. If an Award BIOS detects that the CPU is overheating it may play a high pitched repeating beep while the computer is running.
1 Long, 2 Short Video adapter failure Bad video adapter
Repeating (Endless loop) Memory error Bad memory or bad connection
1 Long, 3 Short Video adapter failure Bad video adapter or memory
High freq. beeps (while running) CPU is overheating CPU fan failure
Repeating High, Low beeps CPU failure Bad processor
Phoenix BIOS Beep Codes
Phoenix BIOS uses beep code patterns to indicate problems. In the table below the '-' indicates a brief pause between beeps.
Example: 1 - 1 - 2 would sound like BEEP <pause> BEEP <pause> BEEP BEEP
1 - 1 - 2 CPU / motherboard failure Bad CPU / motherboard
1 - 1 - 3 CMOS read/write failure Bad motherboard
1 - 1 - 4 BIOS ROM failure Bad BIOS chip
1 - 2 - 1 Timer failure Bad motherboard
1 - 2 - 2 DMA failure Bad motherboard
1 - 2 - 3 DMA failure Bad motherboard
1 - 3 - 1 Memory refresh failure Bad memory
1 - 3 - 2 64K memory failure Bad memory
1 - 3 - 3 64K memory failure Bad memory
1 - 3 - 4 64K memory failure Bad memory
1 - 4 - 1 Address line failure Bad memory
1 - 4 - 2 Parity error Bad memory
1 - 4 - 3 Timer failure Bad motherboard
1 - 4 - 4 NMI port failure Bad motherboard
2 - 1 - 1 64K memory failure Bad memory
2 - 1 - 2 64K memory failure Bad memory
2 - 1 - 3 64K memory failure Bad memory
2 - 1 - 4 64K memory failure Bad memory
2 - 2 - 1 64K memory failure Bad memory
2 - 2 - 2 64K memory failure Bad memory
2 - 2 - 3 64K memory failure Bad memory
2 - 2 - 4 64K memory failure Bad memory
2 - 3 - 1 64K memory failure Bad memory
2 - 3 - 2 64K memory failure Bad memory
2 - 3 - 3 64K memory failure Bad memory
2 - 3 - 4 64K memory failure Bad memory
2 - 4 - 1 64K memory failure Bad memory
2 - 4 - 2 64K memory failure Bad memory
2 - 4 - 4 64K memory failure Bad memory
3 - 1 - 1 Slave DMA failure Bad motherboard
3 - 1 - 2 Master DMA failure Bad motherboard
3 - 1 - 3 Interrupt controller failure Bad motherboard
3 - 1 -4 Slave IC failure Bad motherboard
3 - 2 -2 Interrupt Controller failure Bad motherboard
3 - 2 - 3 <RESERVED>
3 - 2 - 4 Keyboard control failure Bad motherboard
3 - 3 - 1 CMOS batter failure Bad CMOS battery
3 - 3 - 2 CMOS configuration error Incorrect setting
3 - 3 - 3 <RESERVED>
3 - 3 - 4 Video memory failure Bad video card or memory
3 - 4 - 1 Video init failure Bad video card or memory
4 - 2 - 1 Timer failure Bad motherboard
4 - 2 - 2 CMOS shutdown failure Bad motherboard
4 - 2 - 3 Gate A20 failure Bad motherboard
4 - 2 - 4 Unexpected interrupt Bad processor
4 - 3 - 1 RAM test failure Bad memory
4 - 3 - 3 Timer failure Bad motherboard
4 - 3 - 4 RTC failure Bad motherboard
4 - 4 - 1 Serial port failure Bad motherboard
4 - 4 - 2 Parallel port failure Bad motherboard
4 - 4 - 3 Coprocessor failure Bad motherboard or CPU.
9 - 2 - 1 Video adapter incompatibility Use a different brand of video card
Apr 20, 2010 | ASUS P5NT WS (P5NT WS GREEN) Motherboard
I have a swintec 600 wont stop beeping
Usually means there is a problem on the main board. Could be the printwheel is not installed properly.
Jun 04, 2009 | Swintec 7040 Typewriter
Swintec typewriter 7040
Try spraying some WD40 on the silver shaft the carrier rides in and move it back and forth by hand with the power off.
DickyO
May 19, 2009 | Swintec 7040 Typewriter
Nakajima AE-740 Typewriter Logo
32 people viewed this question
Top Nakajima Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Are you a Nakajima Office Equipment and Supply Expert? Answer questions, earn points and help others
