Question about Mitsubishi WD-52631 52" Projection HDTV
Need to reset my tv after replacing bulb
Need to reset tv after replacing bulb
Samsung HL-S5087W DLP rear projection TV keeps shut off and won't stay on longer than 30 seconds.
your bulb has reached the end of its life (at least this is what your tv thinks) you need to replace the bulb and or make the think you did. (there is a reset in the service menu for the bulb)
Dec 14, 2010 | Samsung HL-S5087W DLP TV
I replaced bulb on LG tv but replace bulb light is still on
Its the fuse the is located beside the bulb housing. You need to replace this fuse. Its used almost like a timer. The TV detects a new fuse and blows it at this time it resets the bulb life.
Jul 05, 2010 | LG RU-60SZ30 60" Rear Projection...
I replaced the bulb in my tv. pt44lcx65. everytime i turn on the tv it says i need to reset the bulb timer? how is this done? thank you.
Instructions should be with new lamp. Press and hold volume down on TV front while pressing PLAY, or SPLIT, or PIP on PAN TV remote aimed at little window on TV front near front panel buttons for 5 seconds. Message will appear on screen saying lamptime reset. Press end to exit.
May 02, 2010 | Panasonic PT-44LCX65 Television
I have replaced the bulb but still keep getting a Reset Notice
Hold Vol - on tv and TV/Video button on remote same time for 5 seconds. serv menu will come up. select lamp time and reset with vol- on remote to zero. Turn off tv to remove menu.
Nov 22, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
Sony rp tv kp-53xbr35 wont turn on
YOu may need to replace the bulb in the unit, check the bulb and if blown, you need to replace and after replacing reset the lamp time hours. Good luck.
Nov 14, 2009 | Sony KP-53XBR45 53" Rear Projection...
52 inch zenith shuts down after 10-30 seconds
Bulb must be replaced before viewing will continue.
May 17, 2009 | Zenith D52WLCD 52" Rear Projection...
How to reset lamp timer
Go to the menu and you'll find lamp timer section.
Aug 27, 2008 | Vivitek V37835 46 in. LCD Television
DLP TV Blown Bulb: LG RE44SZ21RD
what kind of tv do you have I need that info so I can help you
Apr 10, 2008 | Televison & Video
Mitsubishi WD-52631 52" Projection HDTV Logo
43 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
