Question about Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0 Tecumseh Engine
Honda mini tiller tines won't turn. Clutch won't engage to start tines. Get a little action sometimes by pushing on ground but tines turn briefly and stop.
libaredneck
  • 119 Answers
SOURCE: Honda FG100 Tiller - Tines wont move
the worm gear in the lower unit is probably wore out. see it alot!
Posted on May 05, 2009
SOURCE: Honda GX25 HG110 mini tiller, tines won't turn.
Mine did the same thing....two things to check: 1) air cleaner, make sure that it is clean 2). gas filter in the gas tank. Take a short piece of wire and fish the black line out. On the end is a small fuel filter. After I flushed mine fuel filter out it ran fine.
Mark
Posted on Jun 01, 2009
  • 22 Answers
SOURCE: Troy Bilt Tiller tines do not engage
You likely have a clutch problem, never saw one that a simple adjustment would fix. I'd take off the tiller (there are two bolts that hold the tiller portion to the transmission, and check to make sure the clutch is sliding in and out. My hunch is either the lever is loose on the shaft or the allen-head little bolt that they use to shift the clutch has come out. Be sure to grease the clutch while you're in there.
This should be covered in your owners manual. Shame on them if they didn't mention this.
Posted on Jun 14, 2009
  • 221 Answers
SOURCE: mtd rear tines tiller won't engage tines. F and R
It sounds like the shift shaft or something in the gearbox the shift shaft engages. I know you didn't want to hear this but it is not uncommon. Most operators don't use the clutch bail when starting, stopping, and shifting as they should.
I hate to say it but this may require a trip to your service center for repair.
Posted on Apr 30, 2010
  • 149 Answers
SOURCE: Tines rotate slow when I try to till.
The clutch is non adjustable if the clutch fails you will have drive all the time or it slips. if the tines spin at the same speed with the engine at low and high speed the clutch might be slipping, the common cause for this is the gear box is partly siezed due to no grease being pumped into it, most ppl dont even know about this untill its too late. you have to remove the LH side tines to get to the screw.
Posted on Jul 02, 2010
HONDA HARMONY MINI TILLER STARTS BUT TINES DO NOT ENGAGE
either the clutch is shot or the cable is broken to the head
May 25, 2017 | Honda Garden
Tines
Either clutch is bad or teeth are striped in bottom gear box. remove tines run engine and see if you can feel movment in lower gear box, if yes the gears are gone. If no remove engine to expose clutch.
May 20, 2013 | Ardisam Inc Earthquake Mini Cultivator
The tines on a honda f220 always spin and don't change speed when clutch is engaged but speed up when throttle is increased. Adjusted cable with no luck.
I believe that unit utilizes a centrifical clutch. try decreasing the idle speed and see if the tines stop. They should then engage as throttle is increased.
Sep 24, 2012 | Honda 25cc 4-cycle Mini Tiller
Jul 01, 2010 | Honda 25cc 4-cycle Mini Tiller
Mtd rear tines tiller won't engage tines. F and R
I had similar problem recently with 2007 Huskee MTD series 410. The shift assembly bent and couldn't move the clutch collar all the way over on the drive shaft.
Apr 23, 2010 | Mtd Products Yard Machines 158CC Tiller
Tiller tines will not turn. Engine runs fine...
Well hopefully it's not the transmission, as sometimes these tend to go. Another common but cheaper repair are the two bearings where the tines connect to the unit.
MORE THAN LIKELY.. The bearing is located above the worm gear housing, the part connected to the tines beneath the guard. This removal can be somewhat frustrating but if you remove it and remove the engine flange you'll be able to manually spin the drive shaft and see if it's the worm gear housing/lower bearings or if it's the more likely bearing on the clutch drum or the clutch itself.
Apr 06, 2010 | Honda 25cc 4-cycle Mini Tiller
Grinding when Engaing PTO for the tiller-Troy Built Horse 8hp
It's likely that your clutch needs adjustment. To adjust, you just need to loosen the two screws on the plate and slide it a bit so the clutch better engages the rear dog clutch. Have you ever taken the tiller portion off the transmission to grease the clutch? If not, before adjusting it you might want to do that. It could be that the clutch isn't sliding back far enough to engage the rear end and a little grease is all it needs. This service requirement is explained in the owners manual for the tiller. One last point, the tiller must be in neutral when engaging the pto clutch. From your note, it sounded like you were engaging the clutch with the forward/reverse lever in the forward position. The lever must be in neutral when engaging the pto clutch.
Jun 14, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Stateman Tiller tine not engaging
Sounds like the worm gears are worn to the point they will not engage.
Feb 20, 2009 | Craftsman Rear Mount Tiller
Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0 Tecumseh Engine Logo
312 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
