Question about Wb Engineering/Rollift Hoisting
Shaft size and width for this product - Wb Engineering/Rollift Hoisting
4 Suggested Answers
SOURCE: I bought a 1984 full
I went to another company with real experts who can speak english and make sense. he found the answer right away and gave me some sources to purchase the right shaft.
Posted on May 06, 2009
  • 10 Answers
SOURCE: What is the proper way to attach the pulley to the
At the arbor end it should be a curved 3/16" key. At the motor it will be a square 3/16" key. I would guess these should be available at most hardware stores, but I would have both types & most other parts too. I sell craftsman table saw parts, you can contact me via email jimatcavanaungh@cs.com
Posted on Feb 12, 2010
  • 508 Answers
SOURCE: drive shaft
I AM ASSUMING YOUR VEHICLE IS A FRONT WHEEL DRIVE. SINCE IT IS AN IMPORT THE BOLT WILL BE METRIC AND AT LEAST A GRADE 5 BOLT TO THE AXLE HALF SHAFT. YOU HAVE TWO AXLES ONE LEFT AND ONE RIGHT UNLESS YOU HAVE A REAR WHEEL DRIVE NISSAN. EASY SOLUTION- GOTO YOUR LOCAL NISSAN DEALERSHIP AND GIVE THEM THE YEAR AND MODEL AND TELL THEM WHAT PART YOU NEED AND THEY WILL PULL THE CORRECT PART FROM THEIR PARTS SHELF. WORST CASE SCENARIO- GO TO A WRECKING YARD AND FIND THE SAME MAKE AND MODEL VEHICLE AND HAVE THEM GET THE BOLT FOR YOU. I HAVE A FEELING WHEN YOU SAID( BULB) IN YOU INQUIRY IT WAS JUST A TYPO ERROR.
Posted on Feb 05, 2012
How do you put a router bit in a Makita router model 3612BR
Inserting the bit should be the same on all versions of the Makita 3612 router. It does depend on the bit size. Press the shaft lock to keep the shaft from turning. I think the lock is close to the handle on one side of the router when you hold the router with the bit/collet up. For small shaft bits, insert the appropriate collet sleeve into the collet cone. Then insert the bit completely into the sleeve. For larger shaft bits, insert the bit completely into the cone. Use the wrench to tighten the collet nut securely. Unlock the shaft lock. Do not over-tighten or leave the bit loose in the collet cone/sleeve. Over-tightening can break the collet cone. Leaving it loose can result in the bit flying out of the collet cone. Either way, injuries can occur. To remove a bit, loosen the collet nut and then remove the bit (or bit and collet sleeve).
The manual is available on the product page: https://www.makitatools.com/products/details/3612 . The direct link to the manual is https://cdn.makitatools.com/apps/cms/doc/prod/361/df12a409-2bd0-48c3-aa38-d635a480a76e_3612_IM.pdf . See page 8.
I hope this helps.
Jul 11, 2017 | Makita Drills
How can I replace the motor in an Aerolatte?
The whisk shaft is glued to the motor shaft. I used needle nose pliers to pry whisk shaft away from motor shaft and it separated easily. Ordered D.C. Motor from china on ebay. 21 mm diameter case. 2mm shaft width. Motor was .99 cents freight prepaid from china to USA.
Feb 15, 2016 | Aerolatte Original Steam Free Milk Frother...
I need a new bolt (with handle) for the steering shaft. It is a bolt that holds the two parts of the shaft together, and when loosend it allows you to fold the shaft down.
Go t Ace hardware take your old bolt they'll probably have a bolt the same size, otherwise you'll need to contact the manufacturer of the item, Electric Strider, Call 1-800-555-1212 and ask for the 800 number of the company of manufacture... There should be a plate on strider with name of company of production.. May even have phone number on plate and possibly web site..
May 29, 2014 | Electric Strider Midi 4 Wheel Mobility...
The rear drive shaft carrier bearing has gone out on my 2005 6 cyl Touareg. I'm told that I have to replace the entire drive shaft, but my mechanic says that if I can find a bearing, he'll install...
SKF bearings is my first choice and any bearing stockist will get you one one you take the old one off and they measure it --width --inner shaft size --outer casing size
Sep 07, 2011 | 2005 Volkswagen Touareg
How to set wheels for longer grass
I LIKE TO CUT MY GRASS AT 5 INCHES HERE IN FLORIDA. IT HARD TO FIND A MOWER THAT CUTS OVER 4'' YOU MAY WANT TO LOOK ON EBAY FOR A LITTLE BIGGER TIRE, YOU WILL NEED YOUR SHAFT SIZE, WIDTH AND HEIGHT .. GOOD LUCK.. JAY
Jun 13, 2011 | Garden
Model f8z176 Need fuse size and spring.
fuse 1 Amp 250 Volt, available in any major auto or electonics store. Spring, I don't know. I need one too and can't find anything on it. My son and I made one from a spring from a ball point pen. It needs to be expanded out in width - I used a screwdriver shaft to help do this. It also needs to be cut down a bit. But it works!!!
May 01, 2010 | Belkin Car Audio & Video
97 vulcan 1500 d2 is leaking gear oil at the front shifter shaft, what the easiest way to fix it?
most gear shafts usually have a small replacable seal, that can be hooked out and replaced simply, I am not familar with your bike, but seals have a number on them like 10 20 8 which are the actual dimentions in mm 10mm shaft 20mm outside 8mm width, clean it up and have a close look, the sizes are sometimes available from bearing shops for a few dollars, compared to OEM bike shop prices
Apr 06, 2010 | 1996 kawasaki VN 1500 Vulcan Classic
Sears compressor Model 919.155730 flywheel/motor shaft not secure
It could be that you are missing a shaft key, look to see if there is a groove in the shaft and in the flywheel if so there should be a key in this groove to keep the shaft from slipping.
Your local hardware store should have one. You will need to Measure the keyway width and height to buy key stock of those dimensions then cut off the length you need.
If it is a Woodruff or Half Moon key 2ea7913.jpg it might be harder to find the right one but a good hardware can do it.
Hope this helps.
May 22, 2009 | Craftsman Air Tools & Compressors
The blade has come loose
Had the same problem myself - another example of a product made to break!
Red Caboose has it spot on. Just a couple of points. The thread on the motor shaft is a 4mm machine screw. the shaft thickens a little bit below the thread (very short) forming a slight collar. I put a washer (slightly larger that the width of the blade) onto this, followed by the blade. You''ll then need a washer to sit into the blade to centre it on the shaft. Follow this with a cup washer (as Red Caboose) suggests or a locknut. Working perfectly now!
Aug 03, 2008 | Bodum 's C-MILL electric blade coffee...
Hoisting Logo
474 people viewed this question
Top Wb Engineering/Rollift Hoisting Experts
Jerry Kramer
Jerry Kramer
FIREFOX ENGINEERING
Are you a Wb Engineering/Rollift Hoisting Expert? Answer questions, earn points and help others
