Question about Jaybird JF3MB Freedom Bluetooth Headphones JF3
How do you turn on bluejay earbuds
Ear buds do not connect to wifi
Connect a 3.5mm ear bud jack
Fair warning, this response may be a dead end & be a waste of time. I can only refer you. In attempting to find a fix to your problem I did a little research. I am not sure that what I am telling you is even allowed on this site. On YouTube, type in ' Connect stereo to earbuds on BMW1200LT'. there is a vid showing stereo install. It may help. Sorry, I am a hardwire tech not a wireless guy.
Dec 25, 2013 | 2000-2009 BMW K1200LT Brake Pads
How do I replace ear buds on electronics 520?
There are no replacement earbuds for Plantronics Voyager 520. You would need to replace the headset if the earbuds are making it uncomfortable enough that the headset is unusable. Link to Headsets Direct Bluetooth Headsets is included below.
Plantronics Bluetooth Headsets
Good luck from Headsets Direct!
Jun 28, 2011 | Plantronics Hama Voyager 520 Bluetooth...
I can not hear anything out of my right ear bud
Hi there thobe47!
Please test the pair with a different audio device and see if the problem goes away first!
Firstly, make sure you are pressing the plug all the way into your audio device jack. Most are designed with two tiers, so only one ear will sound if only one tier of the electrical connection is fully established. Once you've tried that, continue!
Most earbuds are created with very small working parts with equally small electrical connections. If you have lost sound in one side, the most likely cause is a loose connection somewhere.
If it still doesn't work, your options are sort of limited. I would recommend first gently "jimmying" the wire leading to the bad earbud around while it is in your ear and music is playing. If you manage to get the sound to be restored, wrap sticky tape tightly around the wire and the tapered part of the bottom of the earbud in an attempt to maintain the new connection. It is not a permanent fix but might buy you a bit of time with the pair.
If you can't get it to work in that way, your remaining options are pretty much to either open the earbud and attempt to reestablish the connection (difficult, small parts, and could damage the earbuds if you don't know what you are doing), or to buy a new pair. You can get some pretty nice earbuds for under $5 at most megastores, and anybody who could fix them and would charge you will charge you much more.
If you must try to open the earbud (I don't recommend it!), I have a generic set of steps here. I take no responsibility for damage of your earbuds or devices that may follow!
Gently peel back the gelly cover of the earbud, starting under the top seam and pulling it off.
Unscrew or "pop off" the portion of the earbud that has the small grating. There may be an inner retaining system involving more plastic rings. Just keep these safe and remember the order in which you took them apart.
You will now probably be seeing the speaker of the earbud, looking like what you might see on an uncovered subwoofer speaker (just much smaller!)
Being careful to not touch the flat portion of this disk and avoiding anything magnetic (including your laptop / desktop), see if you can pinch it by the sides and gently pull it out of the casing -- probably less than a quarter centimeter. If you can, look for any severed connections between the solder points on the bottom of the speaker and the wires coming from the bottom of the bud. Soldering these would be extremely difficult, but you can attempt to fix them with small pieces of tape.
Nestle the speaker back into the housing, replace any retaining disks in the correct order, screw/pop the outer clip back on, and slide the gelly back into place.
Hope this helps!
Mar 24, 2011 | JVC Gumy Ear Bud Headphone - Peppermint...
My right earbud stopped working and ive had the product for less than 2 months... all the wiring looks fine and no physical damage is noticeable
Unfortunately the ear buds are not made to be repaired, your best option is take them back for replacement "hopefully they are under warranty"
Mar 03, 2011 | Skull Candy LINK Earbuds Consumer...
Left earbud completely silent.
Hi,what makes the left hear completely silent it because the wire inside the left side ear bud might have cut and it's not contacting with the speaker inside the ear bud.
What you will do is this, open the left ear bud that is not working, check if the connection is not properly fix. Also after checking if the wires are intact, if the wires inside are intact with no trace of cut inside,that means that the speaker inside is damaged and will need to be replaced..
If you can't do it your self, I would advice you contact a skilled personnel for help.
Thanks for using fixya....
Oct 21, 2010 | Shure (E2G) Consumer Headphones
I have the GC-1020 Element mp3 player..i have had it for 3 months.All of a sudden i can only hear the music out of one ear of my ear buds,i have tried my earbuds on something else and they work fine..why...
I have the GC-1020 Element mp3 player..i have had it for 2 months.All of a sudden i can only hear the music out of one ear of my ear buds,i have tried my earbuds on something else and they work fine..why won't sound come through both ears anymore?
Aug 22, 2010 | Sears GC-1020 MP3 Player
My skullcandy earphones are busted
could be caused by the way you wrap them up the cords should never be wound tightly it causes a short and it just so happens that earphones are made of light weight wiring to make them seem to disapear when wearing them so what to do is instead of winding them when your done simply fold them loosely so to speak
Feb 25, 2010 | Skull Candy Ink'd Stereo Ear Bud...
Same issue - right earbud volume lower than the left
yh im having the same problem good to know its not just me
Jul 08, 2009 | Sennheiser CX 300 Consumer Headphones
My left earbuds on my JVC gummy earphones went out.
I have this problem all the time with my JVC earbuds. This may sound a little gross but it will work. I put the ear phone in my mouth and **** on the end of it pretty hard. What I have found is that sweat or even wax will plug the little hole and prevent the sound from coming out.
Nov 16, 2008 | JVC Gumy Ear Bud Headphone - Peppermint...
Lost ear phone rubber caps (phillips brand)
You can purchase new rubber caps for Philips earbuds on ebay from seller "auction2world". They are called replacement earbud cap. Unfortunately, you need to purchase the whole set of 3 different sizes.
May 17, 2008 | Lands Phones
Jaybird JF3MB Freedom Bluetooth Headphones JF3 Logo
54 people viewed this question
Top Jaybird Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Jaybird Audio Player and Recorder Expert? Answer questions, earn points and help others
