Question about Optics
Model M 1240RDAX46, serial # MFR 93799, ratio 6.44
2.5 ton,5 ton?
I JUST NEED TO KNOW WHAT MY TONNAGE IS.
Look for your model number on your condensor, outdoor unit. Your tonnage will be towards the end of it and divisable by 6. I.E. 36=3tons or 42=3.5tons. Ac units are messured by the half ton. If you have a split system I.E. heater inside and ac outside your system will be 1 - 5 tons. If this doesn't help post your model and serial number. I can then give you tonnage, age, so forth.
May 16, 2011 | Heating & Cooling
I have a Ruud AC model UACC-056jas serial number 3170 F1085 5657. Does anyone know the tonnage?
That would be a nominal 5 ton BTU unit or 56,000 btu....
At 12,000 btu/ton you can see that it is just a bit short of 5 ton but larger then 4 ton....actually about 4.75 ton....
heatman101
Apr 12, 2011 | Heating & Cooling
I HAVE A HEIL 5000 A/C CONDENSING UNIT.\r\nCAN YOU TELL ME WHAT SIZE IT IS (TON)? MODEL # CA5560 VKD2 STYLE # 60MCE-000095ZR SERIAL # L9811 50209MANF # NCA5560 VKD2 I APPRECIATE YOUR HELP. THANK YOU VERY...
It looks like you have a 60,000 BTU unit or a 5 ton unit...12,000 BTU/ton is how you figure that...
The 60 in the model number indicates the nominal btu's of the unit... the exact output could be a bit more or less depending on the air handler...
heatman101
Aug 04, 2010 | Honeywell International Heil Quaker...
Does the model no. of the compressor indicate
Yes the model will have a series of numbers that will look something like 024,030, 036,048, or 060 ... this is the btu output in thousands of the condenser...so those numbers range from 2 to 5 ton... a ton is 12,000 btu...
What Size Air Conditioner Do You Need?
http://www.fixya.com/support/r3636709-size_air_conditioner_need
heatman101
Jul 20, 2010 | Heating & Cooling
Carrier, model 50RMC024EPC3030; serial number---how many tons??
This is a 2 ton unit (24,000 BTU/HR) 50RMC024EPC3030 The proper way to size a cooling system is actually by the Heat Loss Method, but as a rough estamite generly 500-1000 sqaure feet per ton. Hope this helps
Mar 19, 2010 | Heating & Cooling
Need to know unit size
ckl60 5 ton about a 2003 model on most ac heat pumps the model number reflects the ton sized by 12000 btus per ton also as for the indoor unit cfm rating 400 cfm per ton
May 14, 2009 | Goodman CKL60AR60 Air Conditioner
I need unlock code for 1994 acura legend with bose radio serial n
What you need to do is pull your radio and get serial number and model number. If you call the dealer with this info and can prove you are owner they will give you the code usually for free.. If you go to dealer and they take it out they will charge you around $90...You might get lucky sometimes the dealership puts the sticker on the door jam by the mfr sticker itr is a 5 digit code... Good Luck
Jan 02, 2009 | 2000 Acura NSX
Optics Logo
43 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
