Question about Fujitsu Siemens Stylistic ST5022D Tablet PC
Reset eviant mt7001 tablet
Dropped tablet now screen has colored lines no picture and wont shut down
Could you give me customer service number please for eviant tablet manufacturer thanks
EVIANT CUSTOMER SERVICE:
Technical Support
1-866-935-4396
LINK:
http://www.eviant.com/frontend1/contact.asp
There is also a physical address on that page and more contact info.
good luck
Oct 04, 2016 | Tablets & eReaders
How do i recover lost files on my eviant mt7001
look for a recover program you should find one in your app store
Jul 05, 2015 | Tablets & eReaders
How do i recover lost data on my eviant mt7001
Does your device turn on, if it does do you have control of it, everything works but memory gone? Check if memory SD card is missing, at last if some how you factory reset it with out backing up your storage you lost it all, if SD card was present on that mess check it, next you should have your email account that you used to sign in, find when last time you backed your device, follow the back up steps, if you do have it. Check for any damage and I would try to use another device and use your account on that device, you'll find out real quick of your device is compromised, Out of date devices get stock in time, Good luck
I CAN NOT GET MY TABLET TO OPEN UP TO APP SCREEN, EVIANT IS THE ONLY WORD THAT WILL SHOW. HELP, HELP
You can try a hard reset.
You do not state what model but generally.
If its an Android OS you will need to try holding the power on + volume +up +down Or power on+home +volume down then Factory reset.
You will lose of your personal data.
Jan 09, 2015 | Tablets & eReaders
How do I transfer photos from eviant tablet to HP PC? The tablet plugs into the wall with no way to insert an end into my PC. The only way I've been able to transfer is thru email a few at a time.
The USER guide here http://www.qvc.com/Eviant-8-Tablet-w-8GB-Memory-Android-4.0-&-Google-Play.product.E223749.html
(Click on second set of red words below pictures to download. marked user guide in red.)
Shows you how to transfer files (photos) to your PC using a micro-usb to usb cable from your tablet to your PC.
Sep 10, 2014 | Eviant 7" 8 GB Wi-Fi Purple Tablet Android...
How to reset password for eviant tablet?
Generally speaking, if you have set a password on a device and have forgotten it, you will need to wipe/format the device to factory specifications. That means just like when you bought it.
3 RESET WAYS on ANDROID TABLETS REVIEW
Jun 04, 2014 | Tablets & eReaders
I turned the talkback feature on and now im locked out of my tablet and i can't type in my pin code
Just make a factory data reset.
To reset you tablet manually. you have to
1)switch of your tablet
2)hold volume down button and power button at the same time.
3)wait for 10 sec and you will enter into boot menu.
4)there in the boot menu you will find option named Reset factory default settings/reset user data. select that option
5) wait for resetting......
6)cheers your done.
Mar 01, 2014 | Eviant 7" 8 GB Wi-Fi Purple Tablet Android...
How to speed up eviant 7" tablet
Check your Internet speed, 2mbps is really the least you need, ookla. Com gives an accurate reading. Shut down any other running apps using the Internet, run iobit as app, use it to boost your Internet. Hope this helps.
Jan 31, 2014 | Double Power 7 inch Tablet with 8GB Memory
Lights come on but no picture - just lines on screen
Has it been dropped, squashed, or gotten wet? If so the screen is damaged or the unit is fried. Try a reset or get it repaired/ replaced.
Jan 23, 2014 | Barnes & Noble nook color eBook Reader
Fujitsu Siemens Stylistic ST5022D Tablet PC Logo
197 people viewed this question
Top Fujitsu Siemens Tablets & eReaders Experts
Matthew Spark
Matthew Spark
Martin Murray
Jason Morris
Are you a Fujitsu Siemens Tablet and eReader Expert? Answer questions, earn points and help others
