Question about Tablets & eReaders
Micro usb port damaged on bauhn tablet
The micro USB port on my Bauhn tablet model HDC-08 has come adrift when I removed the charging plug. The 'female' part of the micro-usb connection was attached to my charging lead when I removed it from my tablet
  • 24 Answers
SOURCE: TC1000 Stopped working
Whatever happened? Fixed? still not up? Trashed?
Posted on Apr 05, 2008
SOURCE: Tablet won't recognize USB drive
The guy's that can fix this are in the uk Sumo Technologies they fix all DTR products (address on DTR's website)
Posted on Feb 05, 2009
  • 22 Answers
SOURCE: My Archos 101 tablet's full sized USB port doesn't
This seems to be a widespread problem with the Archos 101 tablet. There have been 2 firmware updates since the problem was first reported, and neither seems to have fixed the issue for anybody, which strongly suggests that it is a hardware issue, in which case you'll need to do an RMA. I recommend contacting the retailer you purchased through so you can get a replacement unit or a refund.
Posted on Feb 28, 2011
  • 1623 Answers
SOURCE: my new tablet will not connect to internet. i have
open network connections on your laptop and select both the wireless adapter AND the internet connection adapter in there and right click on them and click bridge connections. Then go into the network setup wizard (XP) or network and sharing center and click connect to a network and choose adhoc connection. then open wireless settings on the coby kyros and connect to the adhoc connection on your laptop. You should then be able to connect to the internet on it
Posted on Mar 26, 2011
senate42000
SOURCE: My VIZIO Tablet 1008 micro USB charging port is looseand charging indicator comes on some times when I move the wires around. ow do I get to charge the Vtab?
I had the same problem with my vizio tablet. The port came loose after the wife and kids kept playing with it. The tablet would not charge anymore. What I had to do was open the tablet and check if the little pins that connect the Micro USB port were still soldered on the circuit board. Mine were broken off so I had to replace the whole port. I couldnt even find the OEM replacement part so I had to buy a Mico USB (style B) port off ebay and made it work.
Posted on Jul 03, 2012
My Samsung tablet won't charge when plugged in
Does it have a micro USB charger/charging port? This was the universal charging adapter most manufacturers other than Apple moved to around 5 years ago. In my experience, the charging port to charger connection can become loose and prevent charging....especially if you use the tablet or phone during charging. The best method I have found to troubleshoot the issue is to try a charger that successfully charges another device and plug it into the tablet or phone. If your device still does not charge, and especially if the connection is loose, it is most likely that your charging port is damaged. Another possible issue would be the battery itself but the charger or charging port is the most likely culprit for your issue.
Sep 08, 2017 | Samsung Tablets & eReaders
I CANNOT CHARGE THE TABLET THRU EITHER PORT- THE REGULAR CHARGING PORT OR THE USB PORT THAT I FOUND ALSO CHARGES IT. WHAT COULD BE WRONG AND WHAT ARE POSSIBLE SOLUTIONS?
could be software issue reset it would fix it:?
damage to ports both broken sounds unlikely
try usb plug into a different computer
the cables inside the tablet are loose or not connected
check for damage to ports and loose connections inside device
Jun 29, 2015 | Proscan PLT7223G 7" 4 GB Wi-Fi Black...
My CURTIS KLU LT7035J tablet only works when I have it plugged in. It won't charge and I have been trying to charge it for days ? Nothing in the manual on what to do...should I return it or is
Please ensure you are using the correct power adapter that came with the tablet. If it is the wrong voltage/amps then the charging function will protect itself. If it uses a micro USB end then try charging via a computer USB port using a USB to Micro USB cable. This should work and will possibly eliminate the Tablet from the diagnosis. DON'T try to make your own power solution from a combination of cables/adapters because it's potentially dangerous to both you and your tablet.
Dec 01, 2014 | Curtis Tablets & eReaders
Charging port loose.no longer charging on my tmax tablet
Try a different Micro-USB cable. It is usually caused by the cable's micro-USB end being loose and not the tablet's charging port. Most smartphones these days use Micro-USB so you can usually try using one of those if you have one.
Aug 04, 2014 | Tablets & eReaders
Bauhn tablet user manual
Submit your user manual request directly to Bauhn.
Jul 02, 2014 | HP 9.7 Touchpad Tablet, 1GB Memory, 32GB...
We need a plug
The charging on the tablet depends on the model.
Most including the Kocaso 776 charge via the micro USB port, and this is a standard USB port.
So all you do is purchase a micro USB to standard USB cable and plug it into the standard USB port on the charger or a PC.
Feb 07, 2014 | Kocaso 7" Capacitive Touchscreen Tablet...
Kindle fire hd tablet won't charge up
1) Plug it into a different USB port on your pc;
2) Use a different USB charger - look to see if the one supplied with your 'phone has the common Micro USB jack;
Fire's take about 14-16 hours to charge from a pc and 3-5 from the wall,
Jan 27, 2014 | Amazon Kindle Fire HD
How do i download pdf files to my bauhn android tablet?
Not sure if I can help. I could read some pdf files and not others. I downloaded Mozilla Firefox for Android Tablets and this seems to have solved my problem. Instead of going through Internet Explorer for any pdf files I now go through Mozilla Firefox.
Mar 01, 2013 | Tablets & eReaders
Tablets & eReaders Logo
60 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
