Question about Quantaray QSX 9002TM Tripod with Built-in Removable Monopod
NEED TO REPLACE LEG
I HAVE A NEW LEG BUT CAN NOT GET OLD LEG OFF
  • 685 Answers
That tripod is not repairable. Get another.
Posted on Nov 08, 2014
When I used grandfathers old table saw with ungrounded cord. It worked fine, I then plugged a jig saw into same outlet. It worked fine. When I laid the jig saw on the table saw there was a spark a
Check the plug that goes into the outlet. On modern plugs, one prong is taller than the other. The taller is the "ground" leg - the other is the "hot" leg. I bet that you just need to flip the plug over so that the other prong is in the "ground". If this works - mark the "ground" leg (or replace the plug with a newer one that has a taller "ground" leg).
Sep 16, 2014 | Saws
How do I remove front suspension strut?
first off you need a strut spring compressor . then it a simple unbolt the old and put the new one in place .
Aug 29, 2014 | 2001 Citroen Xsara Picasso
Change fork seals
you need to undo the pinch bolts on the yolks and remove the front wheel & mudguard. Undo the bolys retaining the brake caliper and swing it towards the frame downtube, secure it with string. Withdraw each fork leg and clean up with a soft rag. On each leg, remove the top bolt (slowly to release spring pressure) and pour out the fork oil and discard it. Pour in a small amount of parrafin and swill it around a bit to clean out any residue. Remove the dustcap or gaiter and put it on one side. You will now see the fork oil seal. If it has a circlip then remove it, if not, then don't bother. Prise out old seal carefully making sure not to mark the soft alloy of the lower leg or the chrome on the stantion. Rub a little fork oil onto the new seal and carefully slide it over the stantion, pushing it all the way down. Use a piece of wood to firmly push the seal into the lower leg until it sits squarely and fully into place. Replace circlip if necessary and refit dust cover. Refill each fork leg with 142 ml of 10 wieght fork oil and replace top bolt. pump the leg a few times to settle the oil and then refit the legs in the reverse order of removal. When done, pump the forks a few times, go for a cuppa whilst it settles and then you are all ready to go.
Jul 02, 2011 | 1981 Yamaha XS 400 Special
Hi I need a new infrared sensor for my TV, I'm struggling to find the part number could you help
assuming it is an infra-red sensor with 3 legs, or 3 legs and 2 other legs as stands, you should be able to use any old 3 leg IR sensor.
If it s a 2 leg one, any other generic 2 leg IR recieve diode will do. With either type, you just need to get the device back in with the same leg configuration. it is usually marked on the circuit board
Jul 05, 2010 | Philips 42PFL5603D - 42 IN. LCD HDTV
Leaking seal on front fork
leaking seals usualy require replacement you will first need to remove the front wheel then the mud gaurd haveing done that losen the pinch bolts on the top & bottom tripple clampsthis will allow you to turn &pull down on the fork legs fascilitating the removal of same once removed useing a suitable receptacle ie a tub you dont mind getting oil in remove the drain plugs from the bottom of the fork legs pushing down on the staunchions will force the oil out once you are satisfied there empty you can comence dismantling remove the top caps turn them upside down this will allow the spring to be removed at this point you will either need to use the special yamaha tool to undo the staunchion from the tube assumeing you dont have said tool you can improvise by useing an extension bar and socket to hold the internal nut use a rattle gun to undo the bolt once you haveseperated the staunchion from the leg you will be able to prise the old seals out if you do not have the correct tools to press the new seals in with the staunchion & leg together you will need to use the old seal to aid you to tap the new one in if you have to use this method I advise you to place the new seal in the freezer for a while before insertion into the leg this will shrink the seal & make it easier to fit place the new seal into the top of the leg then place one of the old seals upside down on top of the new one useing a soft faced hammer tap the new seal into place useing the old seal as a drift before comenceing reasembly take care to lubricate the lip of the seals before inserting the saunchions good luck
Mar 16, 2010 | 2005 Suzuki DR-Z 125
I need a leg for a Pot-Pourri electric 5 qt pot.
This leg is interchangeable with the Farberware electric skillet legs. I have a Farberware electric skillet in my eBay store that I'm selling for parts (I have lots of small appliance parts for sale). I could just send you the one leg if you want. Here is the link: http://stores.ebay.com/Lauras-Last-Ditch/_i.html?_nkw=farberware+electric&submit=Search&_sid=93311479
Feb 12, 2010 | Faberware Kitchen Appliances - Others
I need to replace a compact refrigerator defrost timer. No part number on the timer (not serviceable according to Frigidaire). I have a match that is the same specs except 30 minutes instead of 7...
The numbers are legs to various components on the ice box a common leg a hot leg a compressor leg and a defrost heater leg. The leg off to itself is the hot leg L1 the common leg is tucked between the defrost leg and the compressor leg, as you turn the timer by manually advancing it you will notice a big difference between the 8 hour run sequence of the compressor leg and the 21 minute run cycle of the defrost leg, so it is easy to figure out which is which. A generic timer will come with extra connectors so that you can connect it to the same basic pattern as your old one.
The most common timer has the old 2143 pattern.
Jan 20, 2010 | Refrigerators
Seals blown on front shocks
to remove seals you will need to remove each fork leg from the bike,i put the bike on the centre stand and jack under the motor to get the front wheel off the ground,after you remove the fork leg,remove the dust cover(if fitted),remove the circlip holding the old seal,you may have to stab through the old seal with a screwdriver to remove the seal from inside the leg(be carefull not to damage the chrome on the fork leg),clean around the surfaces and install the new seal making sure it goes back in dead square,refit the circlip,then refit the dust cover,replace fork tube back in bike and top up with new oil,most bikes take between 300 to 500cc of oil,but check with your local shop as all bikes are different,and you can adjust the amount of rebound damping by varying the amount of oil you put back in,..sounds complicated but quite an easy job..hope this helps
Jul 04, 2009 | 1995 Suzuki GS 500 E
Will stay blanced
you may be overloading you machine.
if not replace the old leg with new one.
just unscrew the old ones out and screw the new ones in.
May 02, 2009 | Washing Machines
How do i dismantle front forks to replace the oil seals
You just needed to.... remove front wheel, support bike on something, undo retaining bolts on forks, tap out fork legs from the top, using a soft mallet. Take out fork seals with a seal pick, (halfords) Replace old seal with new seals, in reverse order) sliding over the fork leg, tapping into place. Then put replace forks etc in reverse order (from dissassembly). Hope this helps
Feb 21, 2009 | 1992 Honda CB 750F2 Seven Fifty
Quantaray QSX 9002TM Tripod with Built-in Removable Monopod Logo
70 people viewed this question
Top Quantaray Photography Experts
R.A. Ellis
R.A. Ellis
Tony Parsons
Tony Parsons
Are you a Quantaray Photography Expert? Answer questions, earn points and help others
