Question about Nikon Callaway RAZR Laser Rangefinder
Won't register distance
Battery power is good . screen flashes but no distance registers
Why can't I register my device
Marvin, You could try registering it on a computer, or it may already be registered. Best to contact Amazon to help sort out the register error.
Check the attached links,instruction , forums and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.amazon.com/gp/help/customer/display.html?nodeId=201539930
Kindle will not register
12 major Kindle Fire problems and how to fix them
HELP Kindle won register and Amazon won help MobileRead Forums
Apr 12, 2016 | Amazon Kindle Fire HDX 7
After power surge on sharp XE-A207 cash register the unit will not turn on or display anything on screen. Unit does have power to it
Did you have good batteries in it? If they were low, locking up is a common symptom when the machine tries to rely on them to support memory during power cuts. You might need to try a master reset and re-program it
Feb 25, 2016 | Retail Supplies
HOW DO I DEREGISTER MY BASE STATION?
If you want to replace a handset or re-assign the designated handset number of a registered handset, you must de-register all the handsets and then individually register each handset.
To de-register all handsets:
Press and hold
FIND HANDSET
on the telephone base for about 10
seconds (until the IN USE light on the telephone base turns on and starts to flash), then release FIND HANDSET
Press and release
FIND HANDSET again. (You must press FIND HANDSET
while the IN USE light is still flashing. The IN USE light flashes for
approximately seven seconds.)
All system handsets show
CONNECTING...
The de-registration process
takes about 10 seconds to complete. All handsets show
NOT REGISTERED
when the de-registration completes.
If de-registration fails, you might need to reset the telephone and try again.
To reset:
Pick up the registered handset and then press
/FLASH
Press
OFF/CLEAR
and place the handset back in the telephone base.
-OR-
Unplug the power from the telephone base, then plug it back in.
note:
You cannot de-register a handset if any system handset is in use.
After de-registering, proceed with registering process:
If the handset screen does not show LOW BATTERY
or HANDSET X, you will need to charge the handset for at least five minutes before registering to the telephone base.
To register a handset:
Place the unregistered handset in the telephone base or charger. If
PRESS FIND HS 4 SEC ON BASE
does not appear on the handset screen after a few seconds, remove the handset and place it in the telephone base or charger again.
On the telephone base, press and hold
FIND HANDSET
for about four seconds (until the red IN USE light on the telephone base turns on) and then release the button. The handset shows
PLEASE WAIT...
and it takes about 10 seconds to complete the registration. The handset shows
HANDSET X REGISTERED
(X represents the handset number assigned)
and you hear a beep when the registration completes.
Nov 13, 2017 | Lands Phones
The screen displays PE, machine stops working
PE means Printer Error. your printer is stuck. call a tech
Mar 21, 2013 | Royal Cash Register 500dx
Register won't respond to any thing says low battery
Most likely the memory batteries are low. According to the manual: Leave it plugged in and replace batteries located under the register tape cover. Should solve the problem.
Feb 19, 2013 | Casio PCR-T48S Cash Register
It will not ring and the base will not register
Hi
Thanks for using FixYa. Please follow these steps to resolve the issue:
Connect the charger and then plug the power supply unit into the wall socket.
Now insert the two batteries supplied
To register your handset to a base station, place it in the main base station with the display facing upward. After approx. one minute, the handset's internal number is Displayed (e.g. 2). Successful registration is signaled by a confirmation tone. Replace the newly registered handset into the charger and leave to charge for Approximately 16 hours. The charging status icon flashes on the handset to indicate that the batteries are being charged.
To register it manually:
Press the MENU options button.
Press the DOWN button until the display shows REGISTER HS.
Press the OK button. Display shows PIN.
Enter your 4-digit Pin (original setting 0000).
Press the OK button. Display flashes REGISTER HS.
Following the user guide for the base station you are registering to place the base into registration mode.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Feb 17, 2010 | Uniden DECT 6.0 Cordless Phone ID
How can I register my GE 27911 handset?
I also had this problem and then I found a solution from another site.
Just open the handset and remove the battery for about 1 minute.
Reinstall the battery and go through the register procedure again - it will register almost immediately. just keep the handset near the base.
Jul 18, 2009 | Uniden Cordless Phone
Need help registering the GE additional cordless model 27911.
I had the same problem but I fixed it by:
1. Disconnect the battery on the handset.
2. Wait 1 minute and reconnect.
3. Register handset.
Jan 10, 2009 | Uniden Cordless Phone
Nikon Callaway RAZR Laser Rangefinder Logo
85 people viewed this question
Top Nikon Photography Experts
Bart Pulverman
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
