Question about Panasonic VIERA Televison & Video
Remote tv what is aspect button
What is this button
    Master:
  • 397 Answers
Aspect I would guess adjusts your "Aspect Ratio", the shape/proportions of the image on your screen. Commonly a choice between 16:9 and 4:3.
Posted on Mar 19, 2014
Picture too big and aspect ratio button on cable remote doesn't work
use the tv's remote to adjust the picture size under settings. Some newer cable boxes have a service menu that can be activated to set the pic right at the box but that depends on make and model.
Mar 22, 2015 | Televison & Video
My picture fills the whole screen to the point people look distorted
Look on your TV remote. Look for a button that reads "Aspect". While watching TV push the Aspect button until the picture is they way you want it.
Sep 01, 2014 | Samsung La32d400 32" Hd Lcd Wide Screen Tv...
Picture on screen is too big head of people are cut off it does not show complete picture
Use your cable or satellite tv remote to adjust the aspect ratio. If you have cable there is a button on the remote called hd zoom and it has this symbol: #. On the satellite tv remotes it usually says format or aspect. You might even have to go into the cable box/satellite tv receiver menus to adjust the aspect ratio/picture format. Once you have done so you can fine tune the picture even further with the television remote's wide/format/aspect/zoom button. Also check and make sure your television is on the right input and that your cable box/satellite tv receiver is set at the right resolution for the television 1080p/1080i/720p.
Jul 12, 2011 | RCA HD52W59 HDTV Projection Television
White flickering line across top of tv with non HD channels
It appears that when you go back to normal tv from hdtv you are able to see the overscan area. Change the aspect of your image with the appropriate button on your Vizio remote and or cable remote. Apparently the button that changes the aspect on the Vizio remote is the wide button. The cable remotes will usually have hd zoom (#), aspect or format.
Sep 28, 2010 | Vizio L32 32 in. LCD HDTV
The picture is higher than the screen meaning that the everyone on screen no longer has a neck. How do I fix it?
adjust the ASPECT RATIO of TV using the MENU button....remote control if an original will have a button on the remote to change ASPECT RATIO on TV....ZOOM button can cause that also!
May 19, 2010 | RCA HD52W58 52" TV
My 51f59 tv is zoomed in too close to see the all of the bottom
look for a button on remote called format , aspect or picture size and press it till the picture fits the screen
Feb 04, 2010 | Hitachi 51F59 51" HDTV Projection...
I'm watching football and cannot see the top score
You should adjust the aspect ratio on your cable box. Depending on your cable company there should be an aspect/HD zoom button. If this does not work go into the TV settings using the "menu" button and try to find a reference to aspect. Make sure it's set to 16:9 normal vs. stretch. You can contact Total COntrol Remotes (www.totalcontrolremotes.com) for help with this kind of issue.
Sep 06, 2009 | Vizio 42 in. LCD TV
NO REMOTE
Hi there. The actual button option that you will need to use for this adjustment will be the aspect button and, unfortunately, this button is only on the remote and not on the TV itself. If there is a control panel located on one of the sides of this set, you may be able to push the menu button here and navigate your way threw the menus screen to the aspect option. I suspect you will need the remote.
please rate and God bless..
Mar 20, 2009 | Sceptre X42GV-Komodo 42 in. LCD TV
Ilo tv
You need to change the aspect ratio of the screen. The cable box remote has an aspect ratio button and the tv remote also has an aspect ratio button or picture size button. You are probably on a zoom aspect since its too big.
Nov 13, 2008 | iLO 3200 32 in. LCD Television
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
