The cold water trickles out and it takes a hour to fill the tub. someone said the delay switch but where is it?
  • 867 Answers
Check your water supply lines. there is a small screen filter where the hose from the tap or other water supply line enters the machine. it may be dirty from mineral build up. make sure all is clean , both ends.
Posted on Jun 14, 2009
Cold water trickles in tub. Hot water fine.
remove the cold water hose from the machine that is your service line feeding into it.
a screen in the inlet were the hose attaches to is probably clogged up
May 28, 2010 | Washing Machines
The cold water trickles in to fill the tub
sounds like you have checked the water coming out of the cold water so the fill valve requires replacement
Aug 19, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Hot water stream when tub fills & how full tub gets super wash
there should be a knob connected to your water lines that come from the wall, turn the hot to the left.
Jun 22, 2009 | Estate Washing Machines
Kenmore Washer 90 series cold water trickle
Hi, You need to remove the fill hose and see what is plugging the inlet valve screen. This should make a guge difference.
Please let me knwo ig I can assist you further.
Thanks
Vic
May 23, 2009 | Kenmore 24032\24036 Top Load Washer
Dishwasher will not run after filled with water
The float switch in the tank is bad,also if water only trickles in your fill valve is going bad which will not let it fill all the way to start wash cycle. Fill tub with pot of water to raise float, if wash cycle starts,replace fill valve,if not,replace float switch.
Jan 21, 2009 | Dishwashers
Fisher pakel washer taking too long to wash clothes
How long does it take to fill the tub? if the water, on warm stteting, isn't blasting out fast or if, when set to cold, it's trickling out, your cold water valve is shot. I can help with this problem 'cause I had the same experiences you listed.
Oct 13, 2008 | Fisher and Paykel GWL11 Top Load Washer
Kenmore washing machine 80 series
check for kinks in the pipe or restrictions to the flow in the pipes before it gets to the washer, if all is ok then check the filter on the outside of the water connector on the machine for dirt
if you confirm all is clear and the flow of water is not the problem before the machine, replace the cold water solenoid
Oct 14, 2007 | Washing Machines
Maytag Performa Washing Machine Issue
switch cold water off, remove hose. there is often a gauze filter, could be at either end. this could be blocked. alse peer into the valve where the hose screws on and see if any dirt build-up
Apr 29, 2007 | Maytag Performa PAV2200
Washing Machines Logo
42 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
