Question about Bose Dual L1 Model II w/ 2 x B2 Sub & T1 Package
Can i connect 8 b2 and 4 l1 model 2 and play at the same time as dj
I want to stack up to 8 b2 bass and 4 l1 model 2
  • Bose Expert
  • 43 Answers
For each Model II Power Stand you can connect one B2, then run the bass line out to a PackLite Power Amp to power a second B2. To do what you want, you will need 4 PackLite Amps.
Bose PackLite power amplifier Model A1 Accessories L1 reg portable...
Posted on Jan 18, 2015
I need to change my powerstand for my Bose L1 model 2 system from 110v to 220V. Do you know where I could find specs on which transformer is in there now(110), and where I could buy a new one(220)?
You don't need to do that. Just get a step-down transformer. It will change your current mains supply to that of the unit. You will find them on Amazon. This way you will avoid tampering with original device. Especially if it is still covered by warranty.
Jul 11, 2015 | Bose L1 Model II System Single Bass...
How to hook up bose L1 Model II with two B2
From the Bose instruction manual (wonderful what can be achieved when one reads ;) )...
Bose manuals for L1 and B2 here:
Bose L1 Model II with B2 bass module L1 portable loudspeaker systems...
Aug 06, 2014 | Bose Audio Players & Recorders
How do I stop vibration sound from the L1??
Try asking your question in the Bose forum (there's a DJ section).
Bose L1 Musicians
Jul 12, 2014 | Bose L1 Speaker
How to hook up bose b1 module into yamaha emx 5000
The Bose B1 bass module is designed to handle up to 125 watts into 8 ohms 40-200 Hz.
The Yamaha EMX 5000 is full 500 watts, and full range. This is not a particularly good match.
EMX5000 Powered Mixers Mixers Live Sound Products Yamaha United States B1 Bass Module Bose L1 Encyclopedia FAQ Wiki
Apr 29, 2014 | Bose Audio Players & Recorders
The Tone Match unit is not receiving power
If you are using the Bose ToneMatch cable (black cable - the connectors are round barrels with square connectors). Then this should work fine.
If it doesn't then try a different cable. You can use a network Cat-5 cable.
Note - if you are connecting to an L1® Model I or L1® classic then you need an T1 Power Supply.
T1 ToneMatch Audio Engine power supply tone-match-unit-not-receiving-power-l4qeg2fyniuwsgnfiobf0ph3-1-0.png
Apr 26, 2014 | Bose L1 Model II Dual Bass System with...
Why won't both my turntables play out of my mixer?
I am guessing but it sounds like a gorse impedance mismatch. You should never connect two outputs together unless they are specifically designed for that. Since you are listing to mono why not send each output to the Base Amp the other to the cabinet. That should resolve the problem.
Mar 29, 2013 | Numark Im1 2-channel Pro Dj Mixer With...
Sro 8120 transonic mp3 keeps cutting out like its going flat when its charging a red light comes on sometimes flashes and the device will only play for a few minutes
Taken from the Quickstart User Manual
LED Light 1 (L1) - is by the earphone socket
LED Light 2 (L2) - is by the USB connector
Charging: Please switch on the player before charging. (Push the on/off switch to 'on' )
When charging the battery for the first time it is recommended that the player is charged about 8 hours. Connect the player to an active USB port using the supplied cable. The computer must remain on during the charging process.
Recharging: Recharge the player will take about 3 to 4 hours. When it's charging, L2 will turn on in red, when it's fully charged, L2 will turn to green light.
When playing music, L1 will shine.
Sep 01, 2011 | Audio Players & Recorders
I have two sp2 speakers i am using a ipod numark dj machine connected through my 2600 watt peavey amp it keeps blowing out one speaker can you tell me why
The SP2 speakers are rated at 1000 watts PROGRAM which is around 500 watts RMS MAXIMUM. You should be using an amp capable of a maximum of 500 watts a side... Your amp is WAY too big. You will have to throttle it down. The speakers have the protection for the tweeters but NOT for the woofers. At five hundred watts RMS and 8 ohms the current is: P = I^2 * R so I^2 = 500/8 = 62.5 so MAX current is 7.9 amps. I recommend you put a 8 amp FAST BLOW fuse in the speaker leads. If the fuse blows, you have saved another speaker and you are DRIVING them too hard. For greater safety make the fuse a 7.5 amp fast blow. Also get a sound meter. The max on these speakers is 125 Db at a meter distance... and in your venue you should NOT exceed 100 Db to be safe with the OSHA regulations regarding hearing protection... I suspect you are driving the speakers too hard. One side may be getting more bass. The speakers are rated down to 55 Hz. DO NOT boost bass up as you will overheat the speakers. If you are using microphones, be careful of feedback, especially that above hearing range. If you need real low bass, then get an 18 inch subwoofer. No matter, stay within safe sound levels to avoid lawsuits and hearing loss... I know several deaf musicians...
Jul 07, 2011 | Music
Round bass
get a bass amplifier and connect to the subwoofer.
Apr 14, 2008 | Mackie SWA1501 Subwoofer
Wht up dj mage asks
If you need repair for your mixer, you can always ship it to us here in NY. We offer free return shipping. We specialize in Pioneer DJ Repairs.
- OPTiC
DJ Equipment Repair & Service
A DJ Pro Audio Co.
Nov 13, 2007 | Pioneer DJM-600 Silver Professional DJ...
Bose Dual L1 Model II w/ 2 x B2 Sub & T1 Package Logo
691 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
