Question about Sony Audio Players & Recorders
Can't seem to get surround sound with my Sony STR-DG510 AV receiver to work through a Comcast RNG150 HD cable box to my Samsung UN55F6300 Snmart tv. Can anyone help!
I have but 3 HDMI ports on the receiver (output, vid2/BD and DVD) The Comcast set-top box only has 1 HDMI port. The TV has 4 HDMI ports.
  • 41 Answers
Get a 4 in 1 hdmi switcher.
Posted on Apr 05, 2014
    New Friend:
  • 87 Answers
Connect the comsat to tv directly by hdmi then use an optical cable from comsat to sony for audio.
Posted on Apr 20, 2014
4 Suggested Answers
smeago1
  • 136 Answers
SOURCE: HDMI f/ dvd, dvr, receiver and tv
best set up if you have all hdmi is to have all your components go into the receiver ie. hd cable box, dvd etc. by using the hdmi output from the player(s) to the hdmi input to the receiver. next use one hdmi cable from the receiver to the tv then your laughing.
good luck
smeags
Posted on Dec 31, 2007
SOURCE: sony str-dg510
Why dvd sound does not play on sony str-dg510?
Posted on Feb 02, 2008
  • 132 Answers
SOURCE: I'm using receiver AVR 2309 and now I would like to connect my cable TV set top box which has HDMI port with this receiver. Which HDMI port (DVD/HDP/VCR or V.AUX) on this receiver should I connect
The DVD/HDP/VCR port will give you the high definition sound properties. If not then connect the set top to your receiver via RCA cables... red/white/yellow
Posted on Jan 12, 2012
Testimonial: "Thank you very much."
No sound through yamaha htr-5750 receiver and samsung blu-ray
That's because tha hdmi is desing to play sound to the reciver you may have to use out put sound from the unit.
Dec 06, 2013 | Sony STR-DG510 Receiver
No Audio
cant use both hdmi and opti outs try sum setting in blue ray but u nee dto plug all blue ray dish directto samsung hdmi then 1 master digital out form tv to sterio digital i n ok tell samsung your output also
Jan 20, 2008 | Sony STR-DG510 Receiver
How do u reset soney reciver str-dg510 i have no sound
What preceded this? Was it working and then stopped or did it never work?
http://www.retrevo.com/support/Sony-STR-DG510-Receivers-manual/id/2526ci754/t/2/
Page 26...
Press I/O to turn off the receiver
Hold down I/O for 5 seconds (("PUSH" and "ENTER" apear on the display alternately)
Press MEMORY/ENTER. After "CLEARING" apperas on the display for a while, "CLEARED" appears.
Jan 31, 2011 | Sony STR DG510 - AV receiver - 5.1 channel...
Sony STR-DG510 hook up with BDP-S560 no sound
The Sony manual for this receiver is not wrong, it is just a little misleading.
It does in fact use HDMI but ONLY for the HIGH DEFINITION video portion of the signal, as output from the receiver to your television. High Definition Multimedia interface carries both audio and video, however, your receiver is not decoding the high definition AUDIO portion of it and passing it through the HDMI, nor is it passing any form of multichannel audio through HDMI. So you can see why the receiver is no longer available for sale from the Sony website. The HDMI connection on your receiver is redundant unless you are not using a multichannel audio format, in which case you would be using either the TV speakers or connect an additional audio cable from the TV's "audio out" back into the receiver for external speakers.
All that should be done is use the HDMI cable from your blu-ray player connected directly to your TV. That will give you your picture, and possibly a better one since the receiver will no longer be in the signal path.
Then connect either a coaxial or optical cable from the blu ray player to the receiver for your audio. You will then be able to have Dolby Digital and DTS surround formats.
Your service person was wrong.
Jan 17, 2010 | Sony STR-DG510 Receiver
We bought a house that came with a home theater system. We would like to connect a cable tv dvr box to it to be able to watch football games in hd on the big screen with the surround sound. The components...
1. Connect cable to cable HD DVR box, connect video out of cable box to Sony receiver TV video in, connect audio L and R out of cable box to Sony receiver TV audio in and connect TV out of receiver to video in of Panasonic projector 2. Connect Audio and Video out of DVD player respectively to DVD in of receiver. Good Luck :)
Oct 23, 2009 | Sony STR-DG800 Receiver
Sony STR-DG510
I think you have to run a separate audio line from the dvd to the 510, because the HDMI is only passive
Mar 12, 2008 | Sony STR-DG510 Receiver
No picture?
I called sony, even though the manuel shows that you can use a component wire to hook up the set top box and hdmi for the tv and dvd sony claims that you can not do this. The cable box must also be wired with an hdmi cable going into the video 2 port.sony claims it doesn't work using component and hdmi together because the receiver is unable to up convert. I hope this helps. I have not tried it yet (i'm at work) we'll see what happens when i get home.
Dec 25, 2007 | Sony STR-DG510 Receiver
High volume low sound
check the volume output from your components, and make sure they are not set too low
Dec 08, 2007 | Sony STR-DG510 Receiver
208 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
