Question about RCA 20F512T 20" TV
Turns on by itself
The TV turns on by itself, several times a day. Does anyone have a fix for this problem?
  • 979 Answers
Re: Turns on by itself
Hide the remote so that the set cannot "see" it. A remote control can cause these "ghostly events"..accordianman
Posted on Nov 04, 2007
0 characters
3 Points
TV turns off and immediately on again, by itself.
sounds like a defective str power regulator ic .......but my advice get a tech to resolder all the pins at the power suppy board area, there may be some open pins that triggers the on and off episodes
Jul 18, 2013 | Standard (CRT) Televisions
Sony TV turns itself off after 5 second. The timer light blinks 7 times. It fixed itself for 2 days and then broke again
U know how to solders?Resolders the FBT,the flyback transformer.It a big block of plastic with a red wire with a cap hook to a CRT(tv tube).
Jan 08, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv turns itself off . you could turn it on & immediately turns itself off or you could have it on for a while before it shuts itself off.
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Aug 12, 2009 | RCA TruFlat 27F520T 27" TV
Tv will shut off while viewing. standby light flashes.
The problem with your Sony. This is a common problem with these Sony sets.
1. How many times does the light blink? Is it consistent and continuous?
2. Does anything happen to the picture itself, or does the set just turn off?
Answer that and I can help you.
Nov 15, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
TV turns on, then immediately off again
The flyback transformer are damaged.
May 26, 2008 | RCA TruFlat 27F520T 27" TV
Turns off randomly
mine does also does yours click at random times and the screen goes out in small places for a split second?
Apr 02, 2008 | JVC AV-32020 32" TV
Samsung hln567w dlp tv
after 3 years it is a good chance that the lamp is going,,however if it plays its melody when it turns off there is a possibility thateither the lamp door switch or the thermostat are failinf
Nov 28, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung TXR3079WHX TV shuts itself off!!!
transistor bad shorted tr-power j6920 org. part#0502-001230 located near flyback.don`t no location #
Aug 24, 2007 | Samsung TXG2548 TV
Toshiba 32" HDTV 2002
The power regulators are famous for going bad. The big problem with this TV set is that unless you use the exact regulator from Toshiba, this set will fail time and time again. Even if the regulator IC has the exact same number, it will not hold up. We used to have a shop that was authorized by Toshiba, and we seen this problem many times when customers would say that they had their TV fixed by some local shop and the same problem occured several times. Good Luck
Mar 28, 2007 | Toshiba 32AF41 32" TV
TV Volume turns down by itself - Philips 29PT8319 Matchline 27"
Most likely the volume down button on the front of the TV or the switch that it activates is sticking. Should be an easy fix otherwise.
Feb 05, 2007 | Philips 27PT8320 27" TV
RCA 20F512T 20" TV Logo
52 people viewed this question
Top RCA Standard (CRT) Televisions Experts
John mullen
Are you a RCA Standard (CRT) Television Expert? Answer questions, earn points and help others
