Question about Niles Audio RCA-SM2 FG01585 Remote Control Anywhere Kit with Surface Mount Sensor
Remote does not work on niles unit
I have a niles RCA-ht2 and the remote that controls the cable box stopped working today. All other components work
How do I replace buttons on niles intellicontrol remote control?
To program you will need an IntelliControl Main System Unit, the IntelliFile II Programming Software and PC Interface, the RF/IR Test LED, and the Transfer Cable.
Sep 08, 2014 | Niles Televison & Video
Tip
Why Am I Unable To Program The RCA Remote Control To Operate My Components
Why am I unable to program the RCA remote control to operate a component? Why am I unable to program the RCA remote control to operate a component? If you are unable to program the remote control to operate a component, review the following information:
Compatibility
If none of the programming procedures work, the universal remote control may not be compatible with your components, based on the type of infrared technology and the age of the components. Some RCA universal remote controls will only work with components manufactured after 1990.
Distance
If you are testing the remote control after you have entered a code, you may be too far away from the component or you may not have the remote control aimed directly at the component. Because the remote control uses infrared (IR) technology to communicate with components, there must be an unobstructed path between the remote control and the IR sensor on the component.
Code Entry Methods
If the Direct Code Entry method was used to enter the codes for your brand and the unit is still not functioning properly, try one of the automatic code search methods instead. During automatic code search, the remote searches for the correct code to program.
Modes
For the remote control to know which component you wish to operate, you must put the remote control in the correct mode by pressing the corresponding component button.
Combo Units
To program the remote control to operate combo units, such as TV/VCR’s, TV/DVD’s, or TV/VCR/DVD’s, use the combo codes in the Code List to program the individual corresponding component buttons. Once programmed successfully, the TV button controls the TV functions on your unit, and the DVD or VCR button controls the DVD or VCR functions, respectively. The codes in the combo section should be tried first, using the Direct Code Entry method on the TV and DVD or VCR buttons. If this is unsuccessful, use one of the Code Search methods to program your combo unit.
Batteries
Make sure the batteries are new and properly installed.
on Jun 19, 2009 | RCA DIRECTV Satellite Remote Control
None of the scientific atlanta codes work to program remote. tried to find the code, still no luck. Any ideas?
To which device do you want setup codes with this remote control? Provide more details please. If you wish to get code list for Scientific Atlanta remote control, check this link.
Feb 23, 2013 | Niles Audio Niles R8L FG01446 8 Source...
I need to know how to program a RCA universal remote RCU404N
Hello
Programming method for your remote control follows:-
In order for the 4 component universal remote to control your DVD player or auxiliary component, you must program it with the code that matches your component. The DVD•AUX key can be programmed to operate a DVD player or a second TV, VCR, DBS or cable box. These instructions explain the preferred method of programming the remote-the Direct Entry method.
1. Manually turn on the component you wish to assign to the DVD•AUX key (TV, VCR, DVD, DBS System or cable box).
2. Locate the enclosed DVD code list, or the
corresponding code list for the auxiliary component (TV, VCR, DBS, or cable box).
Note: If your brand isn't listed, use one of the Code Search methods to program this remote control (See Code Search on page 9).
3. Press and hold the CODE SEARCH key until the INDICATOR LIGHT illuminates, then release the CODE SEARCH key.
4. Press and release the DVD•AUX key. The INDICATOR LIGHT will blink.
5. To program for DVD, press the VCR key. For an auxiliary component, press the corresponding component key (TV, VCR, DBS•CABLE). The INDICATOR LIGHT will blink again, then remain lit.
6. Use the number keys on the remote to enter the first code listed for your brand. After you enter a valid three-digit code, the indicator light turns off.
Note: If you enter an invalid code, the LED will flash rapidly for 2 seconds. Start over at step 3.
7. Aim the remote at your component and press the ON•OFF key. If your component turns off, you have found the correct code.
8. Enter the code in the box provided on this page for future reference.
9. If your component doesn't turn off, repeat steps 3-7 above, entering the next code for your brand. If none of the codes work or your brand is not listed, use one of the Code Search methods to program this remote (See Code Search on page 9).
Mar 18, 2011 | RCA Televison & Video
Need code for a RCA Remote for a Vizio TV
1. Turn the component on that you want to program
2. Press and hold that component key (TV, VCR/DVD, or SAT/CBL) on your remote
3.Press ON/OFF button until your unit turns off.
4. Press Stop button to program the "code" that you remote found to work your component
Oct 16, 2010 | Televison & Video
I was wondering some codes for a RCA tv/ vcr combo
have a old rca television with a build in vcr. connectec a cable box remote works only for volume and channel but power button does not work, with remote was set and stop working call cable company and was told to contact rca to recieve codes for television
Sep 30, 2009 | Philips Universal PH301S Remote Control
Cant get program codes to work on AKIA tv with rca converter box
I recently bought a used LCT2060 that had no remote. I figured my comcast cable remote would work without a problem but it didn't. So 3 universal remotes later I found my solution...a radio shack2_bing.gif universal gamer remote. It controls up to 5 components plus your xbox360, playstation and pc. The price on sale was a mere 12.97, not bad if you ask me. Hope this helped. The code that worked for the Akai2_bing.gif was 11676. Take care...
Jun 13, 2009 | RCA Universal Remote Control
I have this RCA Universal remote (RCU410WMS) and I am trying to program it to use it on a Magnavox TB110MW9 DTV Digital to Analog Converter. I've tried the code search method and nothing. Anyone with a...
RCA's site list codes 25 and 006 for Magnavox cable boxes. Maybe one of these will work for the converter. The RCA site has a link so you can look up codes. Click on "find your remote control codes here" and pick your model number, then the type of device you want to control. If the codes I gave don't work, maybe try some of the other brands of cable box codes. You might find one that will work.
May 04, 2009 | RCA Universal Remote Control
RCA RCR311B Remote Control
if It is similar to most RCA universal remotes, to get the code follow these steps(Manual code search MAy take awhile):
1:Manualy turn on the component that u want to control
2: press and hold the component key (ie TV) while holding TV press ON-OFF key(button) for three seconds until all of the components light up and release the keys(button).
3: keep pressing ON-OFF key until your component turns off.(Note may take awhile)
4: one the correct code is found hit the STOP key and it will save your component IF YOU DO NOT HIT THE STOP KEY THE CORRECT CODE WILL NOT BE STORED.
Hope this works
Oct 26, 2008 | RCA 3-Device Universal Remote
Converter box codes for rca universal remote rcr3273/3373 for zenith or lg boxes
2: press and hold the component key (ie SAT while holding SAT press ON-OFF key(button) for three seconds until all of the components light up and release the keys(button).
Hope this works
Oct 07, 2008 | RCA 3-Device Universal Remote
Niles Audio RCA-SM2 FG01585 Remote Control Anywhere Kit with Surface Mount Sensor Logo
16 people viewed this question
Top Niles Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Niles Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
