Avantree jogger bluetooth reset
After full charge, won't power on..
My kindle won t turn on
Her is a possible solution:
1. Plug into the original charger, hold the power down for a full 30 seconds, release. Let charge in this state for 12 hours.
2. Lease the device plugged into the charger, while you have the device plugged into power, press the power button for a full 40 seconds, release. Wait for 5 seconds and then press and release the power button. Did the device wake up? No, continue to step 3.
3. Plug the device into another charger, if you do not have an charger from another phone go to Staples or Radio Shack pick up a new Kindle or Universal charger, make sure you can return the charger.
4. Plug the Kindle into the new or alternate charger. Hold down the power button for 30 seconds release. Let charge for 12 full hours.
5. Unplug the Kindle from the charger.
6. Press the power button for 40 seconds - time it. Release the power button, wait for 5 seconds, then press and release the power button. The Kindle should wake up. If not, proceed to step 7.
7. If you can not wake up the Kindle from a 'hard reset' the Contact Amazon directly for a replacement.
May 25, 2013 | Amazon Kindle Fire HD
Computer just shuts off when i unplug even though shows full battery
POWER SUPPLY & BATTERY PROBLEM
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Jul 07, 2012 | Sony VAIO VPCF134FX/B F Series Notebook
How long should i charge my jump box
I'm not familiar with this model, but other boxes I've used have all had some kind of power level indicator to show their charge level. I'm sure yours does too. Charge it at least until the indicator shows it's full. You can leave the unit charging for as long as you want, actually. The charging circuitry drops to a low trickle when the unit is fully charged, and won't damage anything by overcharging. (We have one where I work. As soon as we're done jumping something it goes back on charge, and it's over three years old now.)
Aug 11, 2011 | Xantrex Technology XPower Powerpack 200...
I bought Dyson DC16 in 2008. Charged full but it only last for 1 minuet. Should I get a new charger? Is Dyson going to send me a new charger?
Your battery is losing voltage too quick. It has probably developed a 'memory'. Dyson claims that their handheld has the best suction out of all the handhelds out there. In order to maintain that claim the circuit board will shut off power to the motor when the voltage drops below adequate charge for full suction.
We need someone who can teach us to bypass that part of the circuit so it won't cut power to the motor or you need to get a new battery.
Shorting the battery like an Aircraft battery then re-charging won't fix it.
Jun 09, 2011 | Dyson DC16 Root 6 Bagless Handheld...
I have a problem in Samsung omnia B 7610.When I plug in the charger to power source it displayed the battery is full.When I plug out the battery is low and uncharged.Pl help
Ifthe cell phone battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jun 05, 2011 | Samsung Omnia Cell Phone
My dyson handheld charges fully, but keeps cutting out when using. About 7 seconds is the longest continual usage time
We need someone who can teach us to bypass that part of the circuit so it won't cut power to the motor or you need to replace the battery.
May 21, 2011 | Dyson DC16 Root 6 Bagless Handheld...
After charging,the vac cuts out after a minute or so. any help please?
Jan 11, 2011 | Dyson DC16 Root 6 Bagless Handheld...
Fully charged, filters cleaned, vacuum keeps shutting down in and then starts again only to shut off again. the 6 minute time limit is not used up.
Oct 19, 2010 | Dyson DC16 Root 6 Bagless Handheld...
With a full charge chair stops working and won"t power up
I have a Jiffy Jet3 . the problem is when I charge the batteries
the light indicator just blinks but chair doesnt run.
I just put new batteries and still doesnt run,,,thanks J.J.F.
Feb 12, 2010 | Jet 3 Ultra Power Chair
Motorzor
you simply fried your battery by overcharging it. Just get a new one, let it fully charge and fully die twice before you start normal charging. Then you will want to only charge it for about 2 to 3 hours or find a charger that has a smart chip that tells it when to stop charging once the battery is full.
May 13, 2007 | Motorola Mobility RAZR V3
142 people viewed this question
k24674
jasbo
jasbo
